I am so DUMB !!! The file I wrote and I try to compile has the name "16F877A.bas" ! So idiot !!!
Works fine...now ! Thank You all ! Sorry for my stupidity.
Code:'**************************************************************** '* Name : test scroll-clock-thermometer-16F877A '**************************************************************** @ DEVICE pic16F877A, XT_OSC, WDT_ON, PWRT_ON, BOD_ON DEFINE OSC 4 OPTION_REG.7 = 0 ADCON1 = 7 CMCON=7 PORTA = %00000001 'Set all INPUTS to 0 except RA0 = DQ TRISA = %00000001 'Set PORTA RA0-RA5 PORTB = %00000000 'Set all outputs to 0 (off) TRISB = %00000000 'Set PORTB to all output PORTC = %00000000 'Set all outputs to 0 (off) TRISC = %00000000 'Set PORTC to all output PORTD = %00000000 TRISD = %00000000 DQ var PortA.0 SDA Var PORTC.1 ' DS1307 SDA pin #5 SCL Var PORTC.0 ' DS1307 SCL pin #6 ...etc...
