Scrolling thermo
Results 1 to 40 of 56
    Dec 2008
    Ploiesti, ROMANIA
    Default Re: Scrolling thermo
    I made this schematic and I re-write the code for using DS1307. But ...
    Time it's scrolling "00:00" , without any changes... Please HELP !
    ;         test for scroll - clock - thermometer
    ;               using DS1307 & DS18B20
    @ DEVICE pic16F628A, intOSC_osc_noclkout, WDT_OFF, PWRT_OFF, BOD_OFF, MCLR_OFF
    define osc 4
    INTCON    = 0
    TRISA   = %00100000                 ' CATODES TO PORTA
    TRISB   = %10000001                 ' ANODES  TO PORTB
    CMCON   = 7
    DQ     var  PortB.7
    SDA Var PORTA.5 ' DS1307 SDA pin #5
    SCL Var PORTB.0 ' DS1307 SCL pin #6
    DEFINE I2C_SLOW 1                           ;without this nothing work !
    DEFINE I2C_HOLD 1                           ;without this nothing work !
    DEFINE I2C_SCLOUT 1                         ;without this nothing work !
     eeprom 0, [%10100001,%01111010,%01110110,%01101110,%10100001]      '0
     eeprom 5, [%11111111,%01111101,%00000000,%01111111,%11111111]      '1
     eeprom 10,[%01111101,%00111110,%01101110,%01110110,%01111001]      '2
     eeprom 15,[%10111101,%01111110,%01110110,%01110110,%10101001]      '3
     eeprom 20,[%11100111,%11101011,%11101101,%00000000,%11101111]      '4
     eeprom 25,[%10111000,%01111010,%01111010,%01111010,%10100110]      '5
     eeprom 30,[%10100001,%01110110,%01110110,%01110110,%10101101]      '6
     eeprom 35,[%11111110,%00001110,%11110110,%11111010,%11111100]      '7
     eeprom 40,[%10001001,%01110110,%01110110,%01110110,%10001001]      '8
     eeprom 45,[%11111001,%01110110,%01110110,%01110110,%10001001]      '9
        counter           var      byte
        scan              var      byte
        scroll            var      byte
        leddata           var      byte[75]    'Column Data for display 70 columns
        temperature       var      Word        'reading from sensor
        Sign              var      BIT
        tempA             var      byte        'Stores First digit (High)
        tempB             var      byte        'stores Second digit (Mid)
        tempC             var      byte        'stores Third digit (low)
        n                 var      byte
    DB       Var BYTE[8] ' Data byte array
    RTCSec   Var DB[0]   ' alias individual bytes in array
    RTCMin   Var DB[1]
    RTCHour  Var DB[2]
    RTCDay   Var DB[3]
    RTCDate  Var DB[4]
    RTCMonth Var DB[5]
    RTCYear  Var DB[6]
    RTCCtrl  Var DB[7]
        oraa    var byte
        orab    var byte
        minutea var byte
        minuteb var byte
        ttime   var word
    DS18B20_12bit     CON %01111111
    gosub write_1307
    START:
     CLEAR
     gosub read_1307
    ' Init Sensor
     OWOUT DQ, 1, [$CC, $4E, 0, 0, DS18B20_12bit]
     OWOut DQ, 1, [$CC, $48]
     OWOut DQ, 1, [$CC, $B8]
     OWOut DQ, 1, [$CC, $BE]
     Pause 50
     OWIn DQ, 2, [temperature.byte0, temperature.byte1]
     Pause 50
     OWOut DQ, 1, [$CC, $44]
        Sign = temperature.15
        temperature= ABS(temperature)
        temperature=((temperature >> 4)*100) + ((temperature & $F) * 100 >> 4)
        if sign then temperature= -temperature
        ; temperature=2340         ; UNCOMMENT FOR DISPLAY TEST
        tempA = temperature DIG 3
        tempB = temperature DIG 2
        tempC = temperature DIG 1
        ; ttime = 2345              ; just for test
     ;   oraa = ttime dig 3
     ;   orab = ttime dig 2
     ;   minutea = ttime dig 1
     ;   minuteb = ttime dig 0
       oraa = ((RTCHour>>4)& $01)        ; ?????????????????????????
       orab =  (RTCHour & $0f)           ; ?????????????????????????
       minutea = ((RTCMin>>4)& $0f)      ; ?????????????????????????
       minuteb =  (RTCMin & $0f)         ; ?????????????????????????
     if tempA = 0 then
        FOR counter = 0 TO 4
        leddata [counter+8] = %11111111
        next
        for counter = 0 to 4
            READ tempA*5+counter,leddata [counter+8]     'stores 1st digit in leddata locations 8,9,10,11,12
        NEXT
            READ tempB*5+counter,leddata [counter+14]    'stores 2nd digit in leddata locations 14,15,16,17,18
        NEXT
            READ tempC*5+counter,leddata [counter+23]    'stores 3rd digit in leddata locations 23,24,25,26,27
        NEXT
            READ oraa*5+counter,leddata [counter+41]
        NEXT
            READ orab*5+counter,leddata [counter+47]
        NEXT
            READ minutea*5+counter,leddata [counter+57]    'stores minut digit in leddata locations 41,42,43,44,45
        NEXT
            READ minuteb*5+counter,leddata [counter+63]    'stores minut digit in leddata locations 41,42,43,44,45
        NEXT
        'leddata locations 0-7 are blank so that data scrolls onto display
        'leddata locations 8-12 1st digit (leading digit)
        'leddata location  13 blank column between digits
        'leddata locations 14-18 2nd digit
        'leddata location  19 blank column between digits
        'leddata locations 20 & 21 Decimal Point
        'leddata locations 23 - 27 3rd digit (last digit)
        'leddata locations 28 blank column between digits
        'leddata locations 29 - 34 Degrees C symbol
        'leddata location  35 is a blank column at end to clear display as it scrolls
    for n=0 to 7
    leddata [n] = %11111111
    next n
        leddata [13] = %11111111
        leddata [19] = %11111111
        leddata [20] = %00111111    ' DECIMAL POINT
        leddata [21] = %00111111
        leddata [22] = %11111111
        leddata [28] = %11111111
        leddata [29] = %11111100    ' degrees c
        leddata [30] = %11111100
        leddata [31] = %11100011
        leddata [32] = %10111101
        leddata [33] = %10111101
        leddata [34] = %10111101
        leddata [35] = %11111111
        leddata [36] = %11111111
        leddata [37] = %11111111
        leddata [38] = %11111111
        leddata [39] = %11111111
        leddata [40] = %11111111
            leddata [46] = %11111111
            leddata [52] = %11111111
            leddata [53] = %11111111
            leddata [54] = %10111011
            leddata [55] = %11111111
            leddata [56] = %11111111
            leddata [62] = %11111111
            leddata [68] = %11111111
            leddata [69] = %11111111
            leddata [70] = %11111111
            leddata [71] = %11111111
            leddata [72] = %11111111
            leddata [73] = %11111111
            leddata [74] = %11111111
            leddata [75] = %11111111
    LOOPing:
    FOR scroll = 0 TO 70
        FOR scan = 0 TO 10
            PORTA=%11111111
            PAUSE 1
            PORTb = 1
            FOR counter = 0 TO 7
                PORTa = leddata [counter]
                PAUSE 1
                PORTb = PORTb * 2
            NEXT
        NEXT
        FOR counter = 0 TO 70
            leddata [counter] = leddata [counter+1]
        NEXT
    NEXT
    GOTO START
    Write_1307:
        ' Set time & date to  11:59:00, Day 2, Date:Month:Year 30:08:2007
        I2CWRITE SDA,SCL,$D0,$00,[$00,$59,$51,$02,$30,$08,$27,$90] ' Write to DS1307
        pause 10
    read_1307:                          ' Read time Secs,Mins,Hours,Day,Date,Month,Year,Control
        I2CREAD SDA,SCL,$D1,$00,[STR DB\8] ' Read 8 bytes from DS1307
    Dec 2008
    Ploiesti, ROMANIA
    I try with this variant of code
            pause 50
        If RTCHour.6=1 then           ' Work-Out 12 or 24 hour Display for Hours
            CounterA=(RTCHour>>4)&$01
            CounterA=(RTCHour>>4)&$03
            CounterA=CounterA*10+(RTCHour&$0F)
        If RTCHour.6=1 then            ' Display Hours appropriately for 12 or 24 hour Mode
            oraa = CounterA
            oraa = CounterA Dig 1 : orab = CounterA Dig 0
        minutea =(RTCMin>>4)&$0F : minuteb = RTCMin&$0F
    but still "00:00" time I have ...
    Dec 2008
    Ploiesti, ROMANIA
    I made this change
         I2CRead SDA,SCL,$D1,$00,[ RTCSec,RTCMin,RTCHour,RTCDay,RTCDay,RTCMonth,RTCYear,RTCCtrl]
    and now the time is "20:20" ! The clock still don't run ...
    Aug 2008
    Portugal
    You must put a crystal on the DS1307 ( 32.768Khz)
    Thanks and Regards;
    Gadelhas
    Dec 2008
    Ploiesti, ROMANIA
    Thanks...but Proteus dont need him. The clock works fine...just the scroll don't look the "real" time ; it's stuck on "20:20"
    I try many variants, without results. I can't find the way to store real clock in my variables : oraa,orab,minutea & minuteb ...
    Aug 2010
    Maryland, USA
    I dont think you can have SDA connected to MCLR.
    -Bert
    Dec 2008
    Ploiesti, ROMANIA
    Thanks cncmachineguy ! Indeed MCLR cannot be SDA.
    Working variant, but just 5 columns ....
    ;         Working variant for scroll - clock - thermometer
    define osc 4
    INTCON    = 0
    TRISA   = 000000                 ' CATODES TO PORTA
    TRISB   = 000000                ' ANODES  TO PORTB
    CMCON   = 7
    DQ     var  PortB.7
    SDA Var PORTB.6  ' DS1307 SDA pin #5
    SCL Var PORTB.5  ' DS1307 SCL pin #6
     eeprom 0, [100001,111010,110110,101110,100001]      '0
     eeprom 5, [111111,111101,000000,111111,111111]      '1
     eeprom 10,[111101,111110,101110,110110,111001]      '2
     eeprom 15,[111101,111110,110110,110110,101001]      '3
     eeprom 20,[100111,101011,101101,000000,101111]      '4
     eeprom 25,[111000,111010,111010,111010,100110]      '5
     eeprom 30,[100001,110110,110110,110110,101101]      '6
     eeprom 35,[111110,001110,110110,111010,111100]      '7
     eeprom 40,[001001,110110,110110,110110,001001]      '8
     eeprom 45,[111001,110110,110110,110110,001001]      '9
        counter           var      byte
        scan              var      byte
        scroll            var      byte
        Sign              var      BIT
        n                 var      byte
    RTCMin   Var DB[1]
    RTCHour  Var DB[2]
    RTCDay   Var DB[3]
    RTCDate  Var DB[4]
    RTCMonth Var DB[5]
    RTCYear  Var DB[6]
    RTCCtrl  Var DB[7]
        ore     var word
        minute  var word
        oraa    var byte
        orab    var byte
        minutea var byte
        minuteb var byte
    DS18B20_12bit     CON 111111
    gosub write_1307
    START:
     CLEAR
    ' Init Sensor
     Pause 50
     Pause 50
     if tempA = 0 then
        leddata [counter+8] = 111111
        next
        NEXT
        NEXT
        NEXT
       gosub read_1307
        oraa =  ore dig 1
        orab =  ore dig 0
        minutea =  minute dig 1
        minuteb =  minute dig 0
            READ oraa*5+counter,leddata [counter+41]        'stores hours digit 1 in leddata locations
        NEXT
            READ orab*5+counter,leddata [counter+47]        'stores hours digit 0 in leddata locations
        NEXT
            READ minutea*5+counter,leddata [counter+57]    'stores minutes digit 1 in leddata locations
        NEXT
            READ minuteb*5+counter,leddata [counter+63]    'stores minutes digit 0 in leddata locations
        NEXT
        'e.t.c.
    for n=0 to 7
    leddata [n] = 111111
    next n
        leddata [13] = 111111
        leddata [19] = 111111
        leddata [20] = 111111    ' DECIMAL POINT
        leddata [21] = 111111
        leddata [22] = 111111
        leddata [28] = 111111
        leddata [29] = 111100    ' degrees c
        leddata [30] = 111100
        leddata [31] = 100011
        leddata [32] = 111101
        leddata [33] = 111101
        leddata [34] = 111101
        leddata [35] = 111111
        leddata [36] = 111111
        leddata [37] = 111111
        leddata [38] = 111111
        leddata [39] = 111111
        leddata [40] = 111111
        leddata [46] = 111111
        leddata [52] = 111111
        leddata [53] = 111111
        leddata [54] = 111011
        leddata [55] = 111111
        leddata [56] = 111111
        leddata [62] = 111111
        leddata [68] = 111111
        leddata [69] = 111111
        leddata [70] = 111111
        leddata [71] = 111111
        leddata [72] = 111111
        leddata [73] = 111111
        leddata [74] = 111111
        leddata [75] = 111111
    LOOPing:
        FOR scan = 0 TO 10
            PORTA=111111
            PAUSE 1
            PORTb = 1
                PAUSE 1
                PORTb = PORTb * 2
            NEXT
        NEXT
        NEXT
    NEXT
    GOTO START
    Write_1307:
        I2CWRITE SDA,SCL,$D0,$00,[$59,$30,$9,$7,$14,$2,$10,$90] ' Write to DS1307
        pause 10
    ore     = (db[2] & $F )+((db[2]>>4)*10)                 ' Hex to Dec hour
    minute  = (db[1] & $F )+((db[1]>>4)*10)                 ' Hex to Dec minutes
    I think I will "upgrade" to 16F886 or 16F57 (more I/O pins) ...
