Scrolling thermo
Results 1 to 40 of 56
    Dec 2008
    Ploiesti, ROMANIA
    Default Re: Scrolling thermo
    This is schematic who work fine in Proteus. In "real life" , despite modification of scroll timming (pause 500 to 5000 !), the led's are always ON !!! Any idea ?
    Thanks !
    Aug 2008
    Portugal
    Hi;
    I cannot compile that source code. What is the "LOOP" for?? This is a reserved word, you cannot compile the code with this word on a label. And i'm always getting illegal opcode.
    What are you using to compile? Mpasm? or PBP?
    Thanks and Regards;
    Gadelhas
    Aug 2008
    Portugal
    Got it;
    Since I'm using MPASM needed to change the config line;
    @ __config _INTOSC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_OFF & _BODEN_OFF & _MCLRE_ON
    Also like i said before needed to delete the "LOOP" label also, since its a reserved word.
    Thanks and Regards;
    Gadelhas
    LOOP is a reserved word for new version of PBP (2.60 and latter if my memory serves me well) you can replace it with a REPEAT/UNTILL, WHILE/WEND loop.
    Quote Originally Posted by fratello View Post
    Thanks !
    Are they FULL ON or dimmed? I feel they will be dimmed, it's a kind of ghost probably you'll need to add some delay after you turn them off, after the PORTB=0 line
    Turn some LED ON, wait a little bit, turn them OFF, wait a little, do it again.
    Dec 2008
    Ploiesti, ROMANIA
    I will try this code today, later...
    LOOPing:
    FOR scroll = 0 TO 35
        FOR scan = 0 TO 15
            PORTb = 1
            porta=1
            FOR counter = 0 TO 7
                PORTA = leddata [counter]
                PAUSE 10
                PORTb = PORTb * 2
            NEXT
        NEXT
        FOR counter = 0 TO 34
            leddata [counter] = leddata [counter+1]
        NEXT
    NEXT
    GOTO START
    I find another ...mistake (?) : line 2 do not appear on matrix ! What a hell it's going ?!
    Dec 2008
    Ploiesti, ROMANIA
    Tens of variants and no result ! Nobody has a clue ?
    Aug 2005
    You might have to play with your FOSC setting to enable I/O mode on RA6&RA7.
    Sphere.
    Dec 2008
    Ploiesti, ROMANIA
    With schematic from post #8 :
    ; working variant ; anode to portB, catode to portA
    @ DEVICE pic16F628A, intOSC_osc_noclkout, WDT_OFF, PWRT_OFF, BOD_OFF, MCLR_off
    define osc 4
    INTCON    = 0
    TRISA   = %00000000
    TRISB   = %10000000
    CMCON   = 7                         ' Disable comparators
    DQ     var  PortB.7
     eeprom 0, [%10100001,%01111010,%01110110,%01101110,%10100001]      '0
     eeprom 5, [%11111111,%01111101,%00000000,%01111111,%11111111]      '1
     eeprom 10,[%01111101,%00111110,%01101110,%01110110,%01111001]      '2
     eeprom 15,[%10111101,%01111110,%01110110,%01110110,%10101001]      '3
     eeprom 20,[%11100111,%11101011,%11101101,%00000000,%11101111]      '4
     eeprom 25,[%10111000,%01111010,%01111010,%01111010,%10100110]      '5
     eeprom 30,[%10100001,%01110110,%01110110,%01110110,%10101101]      '6
     eeprom 35,[%11111110,%00001110,%11110110,%11111010,%11111100]      '7
     eeprom 40,[%10001001,%01110110,%01110110,%01110110,%10001001]      '8
     eeprom 45,[%11111001,%01110110,%01110110,%01110110,%10001001]      '9
        counter           var      byte
        scan              var      byte
        scroll           var      byte
        leddata           var      byte[36]    'Column Data for display 36 columns
    temperature    var    Word      'reading from sensor
      Sign         var    BIT
        tempA             var      byte        'Stores First digit (High)
        tempB             var      byte        'stores Second digit (Mid)
        tempC             var      byte        'stores Third digit (low)
        n            var    byte
    DS18B20_12bit     CON %01111111
    START:
     CLEAR        'Clear all varibles
    ' Init Sensor 1
     OWOUT DQ, 1, [$CC, $4E, 0, 0, DS18B20_12bit]
     OWOut DQ, 1, [$CC, $48]                   ' Start temperature conversion
     OWOut DQ, 1, [$CC, $B8]
     OWOut DQ, 1, [$CC, $BE]
     Pause 50
     OWIn DQ, 2, [temperature.byte0, temperature.byte1]
     Pause 50
    for n=0 to 7
    leddata [n] = %11111111
    next n
        leddata [13] = %11111111
        leddata [19] = %11111111
        leddata [20] = %00111111    ' DECIMAL POINT
        leddata [21] = %00111111
        leddata [22] = %11111111
        leddata [28] = %11111111
        leddata [29] = %11111100    ' degrees c
        leddata [30] = %11111100
        leddata [31] = %11100011
        leddata [32] = %10111101
        leddata [33] = %10111101
        leddata [34] = %10111101
        leddata [35] = %11111111
     OWOut DQ, 1, [$CC, $44]
         Sign = temperature.15
         temperature= ABS(temperature)
         temperature=((temperature >> 4)*100) + ((temperature & $F) * 100 >> 4)
         if sign then temperature= -temperature
        tempA = temperature DIG 3
        tempB = temperature DIG 2
        tempC = temperature DIG 1
        IF tempA = 0 THEN
        for counter = 0 to 4
        leddata [counter+8] = %11111111
        next                                            ' if 1st digit is 0 then skip so display dosnt display 09.5c
            GOTO skipdigit                                ' it will display 9.5c instead
        FOR counter = 0 TO 4
            READ tempA*5+counter,leddata [counter+8]     'stores 1st digit in leddata locations 8,9,10,11,12
        NEXT counter
    skipdigit:
            READ tempB*5+counter,leddata [counter+14]    'stores 2nd digit in leddata locations 14,15,16,17,18
        NEXT
            READ tempC*5+counter,leddata [counter+23]    'stores 3rd digit in leddata locations 23,24,25,26,27
        NEXT
    LOOPing:
        FOR scan = 0 TO 35
            PORTb = 1
                PORTa = leddata [counter]
                PAUSE 1
                PORTb = PORTb * 2
            NEXT
        NEXT
        NEXT
    NEXT
    GOTO START
    Maybe I put here tomorrow link to video (Y...tube).
    Dec 2008
    Ploiesti, ROMANIA
    How I promise...
    Note : The pullup resistor on RA4 it's 4k7.
