Scrolling thermo - Page 2
Page 2 of 2 FirstFirst 12
Results 41 to 56 of 56
  1. #41
    Aug 2010
    Maryland, USA
    Default Re: Scrolling thermo
    Do you mean how do you display 4 digits on an 8x8 display without scrolling? That I don't think you can do and still be able to read it.
    Maybe I just don't understand the question
    -Bert
  2. #42
    Dec 2008
    Ploiesti, ROMANIA
    Sorry for my poor english...
    So, If set tens hour : on matrix appears (without scrolling) tens hour digit only.
    If set hour : on matrix appears (without scrolling) hour digit only.
    etc, etc.
    Otherwise I can't setting the clock, because I don't see what happens ...
  3. #43
    Dec 2008
    Ploiesti, ROMANIA
    I DID IT !
    Full working () version of scroll-thermo-clock, using PIC16F877A. With buttons for setting hours/minutes !
    Enjoy !
    LE : The answer on my previous question:
        portb=0
        portd=0
        pause 1
        FOR counter = 0 TO 4
            READ oraa*5+counter,leddata [counter]
        NEXT
            PORTB=%11111111
            PORTD = 1
               PORTB = leddata [counter]
               PORTD = PORTD * 2
            leddata [counter] = leddata [counter+1]
            NEXT
  4. #44
    Aug 2010
    Maryland, USA
    Awesome!!!!!!!!
    -Bert
  5. #45
    Dec 2008
    Ploiesti, ROMANIA
    Bug of setting hours (23-->0) solved :
                    '    Decrement Units Hours
            If CounterC=1 then
                if setdechour=2 then
                  IF SetHour=0 THEN
                     SetHour= 3
                     SetHour=SetHour-1
                  Endif
                  if sethour=0 then
                    sethour=9
                    sethour=sethour-1
    and
                    '    Increment Units Hours
            If CounterC=1 then
                if SetDecHour=2  then
                    if SetHour=3 then
                        SetHour=0
                        SetHour=SetHour+1
                    if SetHour=9 then
                       SetHour=0
                       SetHour=SetHour+1
                Endif
    This is it ! Best regards !
  6. #46
    Dec 2008
    Ploiesti, ROMANIA
    Just connect RD7 to matrix and having 8 columns instead 7 . No software update required.Name:  update (Custom).jpg
  7. #47
    Dec 2008
    Ploiesti, ROMANIA
    Soft update : if hour < 10 then not show first 0.
    if oraa = 0 then
        leddata [counter+41] = %11111111
        next
            READ oraa*5+counter,leddata [counter+41]      'stores tens hours digit in leddata locations
        NEXT
    Feb 2007
    I use 4k7 pullup resistors on the I2C bus, as i read somewhere that its a bit fussy with 10K....dont know how true this is
  9. #49
    Dec 2008
    Ploiesti, ROMANIA
    Now I intend to use two 5x7 led matrix, since some ports of PIC (16F877A) are free...
    Please, I need help : how can making scroll in this case ?
    Note : PortB are lines (7) ; PortC are columns from 0 to 7 ; PortD are columns from 8 to 15.
  10. #50
    Dec 2008
    Ploiesti, ROMANIA
    I found a way...but I think it's not the BETTER way .
        '    Display RTC & temp.
    LOOPing:
    FOR scroll = 0 TO 70
        FOR scan = 0 TO 7
            PORTB=%11111111
            PAUSE 1
            PORTc = 1
            PORTd = 1
            FOR counter = 0 TO 15
                  pause 1
                    if counter > 7 then
                        PORTD = PORTD * 2
                        portc = portc * 2
            NEXT
        NEXT
        FOR counter = 0 TO 70
        NEXT
    NEXT
    LED's on column 7 (PortD 0) are, sometimes, on ... What @##%$@ is this ?
  11. #51
    Thanks for making this an article!
    http://www.picbasic.co.uk/forum/cont...ng-thermometer
  12. #52
    Dec 2008
    Ploiesti, ROMANIA
    My first working variant of scroll-thermo-clock :
    Used : 16F877A, DS1307, home-made LED's matrix (7x7) and DS18B20 (missing in video, don't have anyone ).
    Different code from previous example (because of my custom matrix). Enjoy !
  13. #53
    There was a problem with the web site when the article was first published. It appears to be fixed now.
    Thanks Dan for re-posting the article.
  14. #54
    Apr 2010
    Quote Originally Posted by fratello View Post
    Just connect RD7 to matrix and having 8 columns instead 7 . No software update required.Attachment 6076
    what are the values of X1 and X2,?
  15. #55
    Dec 2008
    Ploiesti, ROMANIA
    X1=32768 KHz (see app note for DS1307) ; X2=4MHz (see second line of program file).
  16. #56
    Apr 2010
    thanks lot for the fast reply n giving all instructions to build this without hiding..
    by the way ur final video shows 0.0 c because missing of thermo saensor??
    can u upload a new video with full functionality..?
    reg
    krish69
