Scrolling thermo
Results 1 to 40 of 56
    Dec 2008
    Ploiesti, ROMANIA
    Default Scrolling thermo
    Hi ! I made this schematic : http://solderslingers.com/cart/index...&products_id=1 and work very fine ! So, since I am "0" in Atmel programming, I try to write my own program for PIC, using PBP (here am I to "1" level and example from this forum- Thanks to Mr.D.J.Welburn !
    But...of course, I need help. Only 4 columns are lighting and the characters are ...strange, non-readable. It's some "moving" on my led matrix, but sure it's something wrong. I need help ! Thanks in advance !
    @ DEVICE pic16F628A, intOSC_osc_noclkout, WDT_OFF, PWRT_OFF, BOD_OFF, MCLR_ON
    define osc 4
    INTCON    = 0
    TRISA= %00000000
    TRISB= %10000000
    DQ          var  PortB.7
    CMCON=7                                 ' Disable comparators
    eeprom 0, [%00111110,%01010001,%01001001,%01000101,%00111110] '0
    eeprom 5, [%00000000,%01000010,%01111111,%01000000,%00000000] '1
    eeprom 10,[%01000010,%01100001,%01010001,%01001001,%01000110] '2
    eeprom 15,[%00100001,%01000001,%01000101,%01001011,%00110001] '3
    eeprom 20,[%00011000,%00010100,%00010010,%01111111,%00010000] '4
    eeprom 25,[%00100111,%01000101,%01000101,%01000101,%00111001] '5
    eeprom 30,[%00111100,%01001010,%01001001,%01001001,%00110000] '6
    eeprom 35,[%00000001,%01110001,%00001001,%00000101,%00000011] '7
    eeprom 40,[%00110110,%01001001,%01001001,%01001001,%00110110] '8
    eeprom 45,[%00000110,%01001001,%01001001,%00101001,%00011110] '9
        counter        var    byte
        scan         var    byte
        scroll        var    byte
        leddata        var    byte[36]    'Column Data for display 36 columns
      temperature     var  Word   'reading from sensor
      Sign            var  BIT
        tempA        var    byte        'Stores First digit (High)
        tempB        var    byte        'stores Second digit (Mid)
        tempC        var    byte        'stores Third digit (low)
    DS18B20_12bit     CON %01111111
    START:
        CLEAR        'Clear all varibles
    ' Init Sensor 1
     OWOUT DQ, 1, [$CC, $4E, 0, 0, DS18B20_12bit]
     OWOut DQ, 1, [$CC, $48]                   ' Start temperature conversion
     OWOut DQ, 1, [$CC, $B8]
     OWOut DQ, 1, [$CC, $BE]
     Pause 50
     OWIn DQ, 2, [temperature.byte0, temperature.byte1]
     Pause 50
        'leddata locations 0-7 are blank so that data scrolls onto display
        'leddata locations 8-12 1st digit (leading digit)
        'leddata location  13 blank column between digits
        'leddata locations 14-18 2nd digit
        'leddata location  19 blank column between digits
        'leddata locations 20 & 21 Decimal Point
        'leddata locations 23 - 27 3rd digit (last digit)
        'leddata locations 28 blank column between digits
        'leddata locations 29 - 34 Degrees C symbol
        'leddata location  35 is a blank column at end to clear display as it scrolls
        leddata [20] = %11000000    ' DECIMAL POINT
        leddata [21] = %11000000
        leddata [29] = %00000011    ' degrees c
        leddata [30] = %00000011
        leddata [31] = %00111000
        leddata [32] = %01000100
        leddata [33] = %01000100
        leddata [34] = %01000100
     OWOut DQ, 1, [$CC, $44]
         Sign = temperature.15
         temperature= ABS(temperature)
         temperature=((temperature >> 4)*100) + ((temperature & $F) * 100 >> 4)
         if sign then temperature= -temperature
        tempA = temperature DIG 2
        tempB = temperature DIG 1
        tempC = temperature DIG 0
        IF tempA = 0 THEN    ' if 1st digit is 0 then skip so display dosnt display 09.5c
            GOTO skipdigit    ' it will display 9.5c instead
        FOR counter = 0 TO 4
            READ tempA*5+counter,leddata [counter+8]     'stores 1st digit in leddata locations 8,9,10,11,12
        NEXT counter
    skipdigit:
            READ tempB*5+counter,leddata [counter+14]    'stores 2nd digit in leddata locations 14,15,16,17,18
        NEXT
            READ tempC*5+counter,leddata [counter+23]    'stores 3rd digit in leddata locations 23,24,25,26,27
        NEXT
    LOOP:
    FOR scroll = 0 TO 35
        FOR scan = 0 TO 15
            PORTA = 1
            FOR counter = 0 TO 7
                PORTB = leddata [counter]
                PAUSEUS 1500
                PORTB = 0
                PORTA = PORTA * 2
            NEXT
        NEXT
        FOR counter = 0 TO 34
            leddata [counter] = leddata [counter+1]
        NEXT
    NEXT
    GOTO START
    Last edited by fratello; - 6th September 2011 at 14:50. Reason: Forgot Proteus file...
    Feb 2005
    Holmfirth England
    Default Re: Scrolling thermo
    Just ran a simulation in isis. First thing I notice is that porta.4 does not seem to be working. Don't know if that is just the simulator though.
    Will take a closer look at your code
    Sep 2009
    Maybe pull up resistor is missing?
    Aug 2008
    Portugal
    Hi;
    In PIC16F628A the RA4 Pin is open drain, so you wll need a pull up resistor.
    Thanks and Regards;
    Gadelhas
    Dec 2008
    Ploiesti, ROMANIA
    Working soft in simulation !!!
    Dec 2008
    Ploiesti, ROMANIA
    Mr.Arrati say : " PortA.4 is a Schmitt Trigger input and an open drain output. You will need an additional NPN transistor with a pull down resistor to make column 5 working.". So... can I use PortA.5 instead PortA.4 ? How ? Using "MCLR off" and ?!
    Aug 2008
    Portugal
    Quote Originally Posted by fratello View Post
    You can only use RA5 as Input with MCLR off
    Thanks and Regards;
    Gadelhas
