I2C-Bus Opto-Isolation
Results 1 to 6 of 6
    Italy
    If the GIF file does not open, right-click on it and save it.
    To open the GIF file use the tool Imaging for Windows which is
    part of Windows 2000 or another similar tool.
    Windows 2000:
    Start-Programs-Accessories-Imaging
    Luciano
    Stump's Avatar
    Stump Guest
    Default isolated I2C
    If the INT PIC will always act as the master, then only 3 optos are required.
    The opto connected to pin 6 of P82B96 can be left out, and pin 6
    is then connected to 5v. The clock signal does not need to be bidirectional
    unless the EXT units must act as master.
    Hangover, Germany
    I think, the SCL-signal is also bidirectional, because the slave-device holds down the SCL-signal in order to strecht the read-command until it is freed by the interruptprocess after filling the SSPBUF.
    Stump's Avatar
    Stump Guest
    Default correction
    If you use slave devices that do NOT support clock pulse stretching
    then you can eliminate one of the optos
    see Philips appnote AN255_2
    pg 45
    http://www.semiconductors.philips.co...es/AN255_2.pdf
    It appears that clock stretching in pbp can be implimented with a define
    statement "DEFINE I2C_HOLD 1"
  1. I2C Master/Slave 16F88/16F767 working code
    Last Post: - 23rd October 2012, 23:31
  2. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  3. I2C Master Slave issues.
    Last Post: - 29th March 2008, 20:33
  4. Compass module and I2C bus
    By vladimir059@hot in forum mel PIC BASIC Pro
    Last Post: - 26th December 2006, 21:29
  5. Please help with i2cslave i2c slave
    By cycle_girl in forum mel PIC BASIC Pro
    Last Post: - 1st December 2005, 14:55
