Step motor control
Results 1 to 23 of 23
    May 2010
    Default Re: Step motor control
    THANKS,I mean only some switch can make this,I think in write code not impossible,Thks anyway!
    There is no inherent feedback on a step-motor so without some kind of reference switch (or position encoder etc) it's not possible to know where "home" is.
    Here's a somewhat expanded version of the code. It's a bit more "modular" than earlier, you can select drive-type and just set the direction and number of steps before calling the Drive subroutine. I've not tested it here (no hardware) so you're on your own there if you decide to use it.
    As you might see, I've added a FindHome routined which moves one step at a time until it finds the switch. Just remove it if you're not going to use it.
    '*  Name    : StepIndexer.pbp                                   *
    '*  Author  : Henrik Olsson                                     *
    '*  Notice  : Copyright (c) 2011 Henrik Olsson                  *
    '*  Date    : 2011-09-07                                        *
    '*  Notes   : Very simple step motor indexer for unipolar drive.*
    Direction   VAR BYTE    ' Forward=1, Back=254
    Distance    VAR WORD    ' Number of steps to move
    DriveType   VAR BYTE    ' WaveDrive=0, HiTorque=1, HalfStep=2
    StepCount   VAR WORD    ' Counts the number of steps moved
    Delay       VAR BYTE    ' Delay between steps
    HomeSwitch  VAR PORTA.0 ' Reference/home switch connected here
    Index       VAR BYTE    ' Index "pointer" used for the lookup tables.
    Temp        var BYTE    ' General purpose
    FORWARD     CON 1
    BACK        CON 254
    WaveDrive   CON 0
    HiTorque    CON 1
    HalfStep    CON 2
    TRISB = 0               ' All PortB pins are outputs.
    TRISA.0 = 1             ' Reference/home switch connected to RA0
    CLEAR
    DriveType = HiTorque   ' Use the two phase on high torque mode
    FindHome:
    ' Take one step at a time untill the reference switch connected
    ' to PortA.0 is found, stop there.
      Direction = FORWARD   ' Move forward
      Distance = 1          ' step by step
      Delay = 20            ' at roughly 50Hz
      While HomeSwitch = 0
         GOSUB Drive
      Wend
    Pause 2500
    Cycle:
      Direction = FORWARD   ' Go forward...
      Distance = 512        ' for 512 steps...
      Delay = 20            ' at roughly 50Hz...
      Gosub Drive           ' do it
      Pause 2500
      Direction = BACK      ' Go back...
      Delay = 10            ' at roughly 100Hz...
      GOSUB DRIVE           ' do it.
      Pause 2500
    Goto Cycle
    Drive:
    ' Move Distance number of steps. Direction gets added to Index each iteration,
    ' this makes Index count up (when direction=FORWARD (1)) or down
    ' (when direction=BACK (254)). Then, depending on the desired drive type we
    ' either mask the lower two or lower three bits in temp and use those as the
    ' actual pointer into the Lookup-tables for the three different drive sequences
    ' (Wave drive, Hi-Torque and Half step). The result of the table lookup is put
    ' on PortB.
      For StepCount = 1 to Distance
         Index = Index + DIRECTION
         Select Case DriveType
           Case WaveDrive
              Temp = Index & 3
              Lookup Temp, [1, 2, 4, 8], PortB
           Case HiTorque
              Temp = Index & 3
              Lookup Temp, [3, 6, 12, 9], PortB
           Case HalfStep
              Temp = Index & 7
              Lookup Temp, [1, 3, 2, 6, 4, 12, 8, 9], PortB
            END SELECT
         Pause Delay
      NEXT
