Step motor control
Results 1 to 23 of 23
    May 2010
    Default Re: Step motor control
    this is schema:
    Yes, if the motor/gearbox requires 4096 steps to turn one revolution the first piece of code will move 360 degrees forward and then 360 degrees back. There are 4 "steps" each time thru the FOR-NEXT loop so 512*4=4096.
    In the second piece of code it'll move 1440 degrees forward and then 1440 degrees back.
    May 2010
    thks,but sorry I don't understood,is not problem to write code to I tested,pls.
    May 2010
    Can you looking this page,
    my motor is ST-28.MAYBE YOU FIND ANSWER!
    http://www.khwelling.nl/cnc/hardware/motor_test.html
    May 2008
    Italy
    You can improve your motor performance in two ways:
    1) Use half step sequence ( here a sample code)
    HStep           var byte    [8]     ' Half step sequence array
    B0              var byte
    C0              var byte
    P0              var byte
    W0              var word
    TRISB = 0
    P0 = 50   ' incrementing the delay will reduce the motor speed  (max 255)
    C0 = 0
    B0 = 0
    HalfMode:
    If C0 = 0 then gosub CW
    C0 = C0 + 1
    if C0 = 2 then C0 = 0
    If C0 = 1 then gosub CCW
    for W0 = 0 to 8192   ' one turn of the gear shaft ( 64 motor turns)
    PortB = HStep[B0]
    B0 = B0+1
    if B0 = 8 then B0=0
    pause P0
    next W0
    Goto HalfMode
    CW:        ' half step sequence (clockwise)
    HStep[0] = 1
    HStep[1] = 3
    HStep[2] = 2
    HStep[3] = 6
    HStep[4] = 4
    HStep[5] = 12
    HStep[6] = 8
    HStep[7] = 9
    CCW:       ' half step sequence (counter clockwise)
    HStep[0] = 9
    HStep[1] = 8
    HStep[2] = 12
    HStep[3] = 4
    HStep[4] = 6
    HStep[5] = 2
    HStep[6] = 3
    HStep[7] = 1
    2) Use a constant current setup to your motor. The simple way is to use a LM317 configured as costant current supply. See the attached schematic (Resistor 33 Ohms 1 watt. Use 24 V dc as an input to the LM317)
    cheers
    Al.
    May 2010
    Thks,all for help!!!
    I tired testing all code,I hope I do something!
    Just one question,
    Is possible make some code in picbasic,
    When I start step motor,to start every time to one position,
    example:
    If step motor work some,go to left,go to right,.......
    and I stop power,and turn again,is possible,motor back in some start position,and continue work some function!
    May 2008
    Italy
    Check this thread http://www.picbasic.co.uk/forum/showthread.php?t=12248 perhaps you will Find what you need!
    Cheers
    Al.
