Step motor control
Results 1 to 23 of 23
    May 2010
    Default Re: Step motor control
    How do you think you loaded?
    I tried to test it and no-load, but it is the same.
    problem is that when running the operation is complete, not return to the same starting point, but perhaps the real fault of a few steps, and I really should be the precise.
    Going by your code it seems that you have a unipolar motor (6 wires) and 4 switches (transistors or whatever). If so, using pulsout is not the best way since there will be a short delay between each pulsout statement where no current is flowing in any of the coils. When no current is flowing the torque drops and the rotor can "jump" to the closest natural step (magnetic pole).
    Delay VAR BYTE
    i VAR WORD
    TRISB = 0  ' All outputs.
    Delay = 10   ' ~100steps / second
    For i = 1 to 1000    '1000 steps forward.
      PORTB = %00000001
      Pause Delay
      PORTB = %00000010
      Pause Delay
      PORTB = %00000100
      Pause Delay
      PORTB = %00001000
      Pause Delay
    NEXT
    Pause 2500
    For i = 1 to 1000    '1000 steps reverse.
      PORTB = %00001000
      Pause Delay
      PORTB = %00000100
      Pause Delay
      PORTB = %00000010
      Pause Delay
      PORTB = %00000001
      Pause Delay
    NEXT
    Now, there are other ways to "produce" the step sequence than this rather crude one but try this and see if it helps.
    May 2010
    Thks for help HenrikOlsson,
    is work but is not precision,make mistake every 5-6 circle working.
    I use this step motor,ST-28 have 5 wire uni polar step motor,
    this is specification:
    Rated voltage: 12VDC
    Current: 32mA
    Resistance/phase: 280
    Fases: 4
    Angle/step: 5.625 deg
    Gear ratio: 1:64
    detent torque: 350gfcm (0.034Nm)
    pull-in torque: 6360g (0.059Nm)
    max. starting pulse rate:700pps
    max. slewing pulse rate:1400pps
    max. speed: 20.5 rpm
    steps/rev: 2048 (tested!!)
    connector order:
    B2: Blue
    B1: Pink
    A2: Yellow
    A1: Orange
    GND: Red
    And one more question in your code I will see you dont use this like in my code:
    Delay VAR BYTE
    i VAR WORD
    PORTB = %00000001
    Pause Delay
    PORTB = %00000010
    Pause Delay
    PORTB = %00000100
    Pause Delay
    PORTB = %00001000
    Pause Delay
    NEXT here dont have i whay
    Pause 2500
    PORTB = %00001000
    Pause Delay
    PORTB = %00000100
    Pause Delay
    PORTB = %00000010
    Pause Delay
    PORTB = %00000001
    Pause Delay
    NEXT
    and tell is when I change speed of motor maybe I must change some number of steps,of some else... I dont now!!!
    May 2008
    Italy
    Can you post the wiring diagram?
    Al.
    It's not easy to say what the problem is. It might be that you need to start even slower than ~100Hz and then ramp up the step frequency, in order to see if that is the case increase the pause time between each step to something like 25ms.
    The above is also the answer to how you change the speed. There's the DELAY variable which, in my example gets assigned the value of 10. Between each step there's a delay of 10ms, change that and the motor speed changes.
    A schematic of how you have it wired would help too. Usually you run step motors at much higher voltage than what they are rated for and then limit the current. For unipolar drive this was usually done by big series resistors. In todays bipolar drives it's done thru chopping/PWM.
    With PBP you don't need to specify anything with the NEXT statement. It automatically belongs to the FOR that is "closest to it". You CAN definitely add a variable to the NEXT for added clarity but it's not needed.
    Finally, you say the motor has a step angle of 5.625 degrees, that's 360/5.625=64 steps/rev. Then you have a gearbox with a ratio of 1:64, so 64*64 is 4096 and not 2048 as you've stated....something isn't correct there but it's not related to your problem so it doesn't really matter right now.
    May 2010
    HI,
    do you now what is hapend,
    when I write this code:
    Delay VAR BYTE
    i VAR WORD
    For i = 1 to 512
    PORTB = %00000001
    Pause Delay
    PORTB = %00000010
    Pause Delay
    PORTB = %00000100
    Pause Delay
    PORTB = %00001000
    Pause Delay
    NEXT
    Pause 1500
    For i = 1 to 512
    PORTB = %00001000
    Pause Delay
    PORTB = %00000100
    Pause Delay
    PORTB = %00000010
    Pause Delay
    PORTB = %00000001
    Pause Delay
    NEXT
    My motor turn round 360 degrees, and back - 360 degrees ,1 time!!!
    and when I write this code:
    Delay VAR BYTE
    i VAR WORD
    For i = 1 to 4096
    PORTB = %00000001
    Pause Delay
    PORTB = %00000010
    Pause Delay
    PORTB = %00000100
    Pause Delay
    PORTB = %00001000
    Pause Delay
    NEXT
    Pause 1500
    For i = 1 to 4096
    PORTB = %00001000
    Pause Delay
    PORTB = %00000100
    Pause Delay
    PORTB = %00000010
    Pause Delay
    PORTB = %00000001
    Pause Delay
    NEXT
    my motor turn round 360 degrees,and back - 360 degrees, 4 time is correct?
    May 2010
    this is schema:
    Yes, if the motor/gearbox requires 4096 steps to turn one revolution the first piece of code will move 360 degrees forward and then 360 degrees back. There are 4 "steps" each time thru the FOR-NEXT loop so 512*4=4096.
    In the second piece of code it'll move 1440 degrees forward and then 1440 degrees back.
