There is no inherent feedback on a step-motor so without some kind of reference switch (or position encoder etc) it's not possible to know where "home" is.
Here's a somewhat expanded version of the code. It's a bit more "modular" than earlier, you can select drive-type and just set the direction and number of steps before calling the Drive subroutine. I've not tested it here (no hardware) so you're on your own there if you decide to use it.
As you might see, I've added a FindHome routined which moves one step at a time until it finds the switch. Just remove it if you're not going to use it.
/Henrik.Code:'**************************************************************** '* Name : StepIndexer.pbp * '* Author : Henrik Olsson * '* Notice : Copyright (c) 2011 Henrik Olsson * '* : All Rights Reserved * '* Date : 2011-09-07 * '* Version : 1.0 * '* Notes : Very simple step motor indexer for unipolar drive.* '* : * '**************************************************************** Direction VAR BYTE ' Forward=1, Back=254 Distance VAR WORD ' Number of steps to move DriveType VAR BYTE ' WaveDrive=0, HiTorque=1, HalfStep=2 StepCount VAR WORD ' Counts the number of steps moved Delay VAR BYTE ' Delay between steps HomeSwitch VAR PORTA.0 ' Reference/home switch connected here Index VAR BYTE ' Index "pointer" used for the lookup tables. Temp var BYTE ' General purpose FORWARD CON 1 BACK CON 254 WaveDrive CON 0 HiTorque CON 1 HalfStep CON 2 TRISB = 0 ' All PortB pins are outputs. TRISA.0 = 1 ' Reference/home switch connected to RA0 pause 1000 CLEAR DriveType = HiTorque ' Use the two phase on high torque mode '--------------------------------------------------------------------------- FindHome: ' Take one step at a time untill the reference switch connected ' to PortA.0 is found, stop there. Direction = FORWARD ' Move forward Distance = 1 ' step by step Delay = 20 ' at roughly 50Hz While HomeSwitch = 0 GOSUB Drive Wend '--------------------------------------------------------------------------- Pause 2500 Cycle: Direction = FORWARD ' Go forward... Distance = 512 ' for 512 steps... Delay = 20 ' at roughly 50Hz... Gosub Drive ' do it Pause 2500 Direction = BACK ' Go back... Distance = 512 ' for 512 steps... Delay = 10 ' at roughly 100Hz... GOSUB DRIVE ' do it. Pause 2500 Goto Cycle '--------------------------------------------------------------------------- Drive: ' Move Distance number of steps. Direction gets added to Index each iteration, ' this makes Index count up (when direction=FORWARD (1)) or down ' (when direction=BACK (254)). Then, depending on the desired drive type we ' either mask the lower two or lower three bits in temp and use those as the ' actual pointer into the Lookup-tables for the three different drive sequences ' (Wave drive, Hi-Torque and Half step). The result of the table lookup is put ' on PortB. For StepCount = 1 to Distance Index = Index + DIRECTION Select Case DriveType Case WaveDrive Temp = Index & 3 Lookup Temp, [1, 2, 4, 8], PortB Case HiTorque Temp = Index & 3 Lookup Temp, [3, 6, 12, 9], PortB Case HalfStep Temp = Index & 7 Lookup Temp, [1, 3, 2, 6, 4, 12, 8, 9], PortB END SELECT Pause Delay NEXT Return '---------------------------------------------------------------------------
