Decoding OBDII Comms
Results 1 to 13 of 13
    Default Re: Decoding OBDII Comms
    Thanks for the ideas so far.
    Here is some more refined data for a few functions.
    'MPI_MDL Temp C
    '$9C = 21C
    '$88 = 29C
    '$83 = 31C
    '$6B = 40C
    '$67 = 42C
    'DC-DC Converter Temp C
    '$97 = 22C
    '$7F = 33C
    '$77 = 36C
    '$76 = 37C
    '$72 = 39C
    Any ideas on these two?
    Some new data to fox you from an Air Fuel ratio sensor.
    The data from the car (left number) converts to the AF (Right number).
    255=7.31
    224=8.36
    192=9.71
    160=11.65
    128=14.56
    96=19.41
    64=29.12
    32=58.24
    16=116.48
    8=232.96
    4=465.92
    2=931.85
    1=1863.70
    It looks like a typical wideband 02 sensor response with a very steep rise at the end.
    I need to establish a formula (if possible) from this data so I can convert the data into the AF.
    Now I could capture every value from 0-255 and get exact numbers for each value but that will take a lot of time, and then I would have to do a lookup table for the normal operating range. I could just gather 128 data points from 64 to 192, that encompases the AF range 29.12 - 9.71 which i'm sure covers my cars operating area.
    How can I do it without using a look up table? Formula?
