Smooth LED fading via PWM
Results 1 to 40 of 55
Threaded View
  1. #27
    Mar 2009
    Default Re: Smooth LED fading via PWM
    Ok Henrik...I've just used your 'read the EEprom serially out onto my PC screen' (rather than try to work how to look at the data with the pickit2 itself) - it worked a treat....and certainly alleviates some angst as to "I wonder what's what inside the Eeprom space)
    And I was clearly wrong with respect to getting my user defined byte tucked away to slot 255, this is obviously what I needed...
    WRITE 255, default_config_shadow
    (definitely a case of RTFM!)
    Anyway, I've learnt something from this little jaunt - I'm happy :-) (tks Henrik)
    Edit: Oops - just seen your reply (was obviously typing mine while you were replying) ...anyway, the penny has dropped here!
