Smooth LED fading via PWM
Results 1 to 40 of 55
    Default Re: Smooth LED fading via PWM
    Hi Hank,
    First off all, it seems as if your WRITE statement is "reversed", you should do WRITE Adress, Value but to me it seems you have it the other way around, ie. writing whatever is in default_config to adress 42 (101010) when I think you actually want the value 42 written to adress 0, or 1 perhaps.
    Second, I think (pretty sure) you should be able to read the EEPROM with the PICKit2, I only have a PK3 but if you can't figure it out I'll have a go later. With that said you could dump the EEPROM content over a serial line (if you have one) with something like:
    Count VAR BYTE
    Result VAR BYTE
    For Count = 0 to 255
      Read Count, Result
      HSEROUT ["EEPROM Location: ", DEC3 Count, ": ", DEC RESULT,13]
    NEXT
    Third, if the first location in EEPROM (location 0) is reserved for that "userbyte" of data then you should start your DATA table with something like DATA @1, 1, 1, 1... Which will put the first entry at location 1 instead of location 0.
    Finally, remeber that DATA isn't something that executes when the program runs, it only tells the compiler/assembler to put that data in the ".hex image" so that the programmer (your PICKit2) can program the values into EEPROM together with the actual program. WRITE, on the other hand is a runtime command and does write to the EEPROM when the program executes.
    Hope that helps.
    Mar 2009
    A great answer Henrik (good spot on my erroneous write too!)
    That was a top heads up wrt ....DATA @1, ""
    and goes some way to resolving the confusion I have wrt managing where the written Eeprom data commences being stored! Presumably I can tuck the user defined byte (called default_config) away at the very last slot of eeprom with...
    DEFAULT_CONFIG  DATA 255
    & then place the other 255 bytes below that?
    ... I'll revisit this after the kids are off to bed, but that was a great reply & gives me plenty to get my teeth into - thanks. (PS I haven't forgot about the DDS stuff you did ...I really want to revisit that as soon as I'm finished this melarkey!)
    Hi Hank,
    No, not really....
    Defalt_Config DATA 255
    Will store the value 255 at location 0 in EEPROM and give that location the label or name Default_Config. If you want a value to be stored at location 255 you need to use
    DATA @255, 42
    Or possibly (not clear to me how the label thing it works)
    Default_Config DATA @255, 42[code]
    and then when the user changes that value you do
    userValue VAR BYTE
    WRITE 255, userValue
    or possibly (still not clear how that "label" works)
    userValue VAR BYTE
    WRITE Default_Config, userValue
    Sorry if I'm confusing you...
    Mar 2009
    Ok Henrik...I've just used your 'read the EEprom serially out onto my PC screen' (rather than try to work how to look at the data with the pickit2 itself) - it worked a treat....and certainly alleviates some angst as to "I wonder what's what inside the Eeprom space)
    And I was clearly wrong with respect to getting my user defined byte tucked away to slot 255, this is obviously what I needed...
    WRITE 255, default_config_shadow
    (definitely a case of RTFM!)
    Anyway, I've learnt something from this little jaunt - I'm happy :-) (tks Henrik)
    Edit: Oops - just seen your reply (was obviously typing mine while you were replying) ...anyway, the penny has dropped here!
    May 2006
    Del Rio, TX, USA
    Hank,
    Something to tuck away in your cranium while working with the EEPROM: It has a limited number of write cycles.
    I can't remember the number of write cycles, but you will NEVER wear it out just by reprograming it. (EDIT: The 18F4620 is rated minimum 100K and typical 1M write cycles)
    But you could wear it out if you repeatedly write a value during the operaitons of your code. So only make the WRITE when the user actually changes the vaule.
    Last edited by SteveB; - 21st September 2011 at 22:30. Reason: Added info on write cycle ratings
    Mar 2009
    Thanks Steve ...fortunately, this is likely to be a one shot selectable option (ie set & forget) - I doubt it'll ever be updated more than a few times.
    Sep 2005
    Campbell, CA
    I have to admit that I haven't read all the posts, but I noticed one thing awhile "up". PLEASE don't drive a LED directly from a PIC pin! LEDs are not 'lamps'. LEDs ARE DIODES! It is CURRENT, not voltage that lights them. Since they are a diode, if you put a slowly rising voltage across them, they (at first) draw no current whatsoever. Then, when they get to the diode forward voltage (which is determined by the technology of the LED), all of the sudden, they light. So, you can have no light at all at 2.2V, and burn them up at 2.3V. If a LED with a forward voltage of 2.3V was connected to a 3V source, it wouldn't last long. So why do they work when you connect them directly to PIC pins? It is because the PIC pins have very small FETs driving them, and they have an "effective" resistance. That is, they cannot supply a huge amount of current. This current-limiting allows both the PIC and the LED to survive.
    You have seen the LED flashlights that have nothing but white LEDs and 3 - AAA batteries. No resistor. The forward voltage of most white LEDs is between 3.1 and 4V (Wikipedia). The 3 batteries in series produce about 4.5V. It all works because batteries are not perfect power sources, they have an Equivalent Series Resistance (ESR) that acts like a resistor in series with the battery. This ESR allows things to work - kind of. But have you ever noticed that while you expected the LED flashlights to work forever - they don't? They fail because the makers don't put in a little extra resistance in the leads of each LED to balance the LEDs and to control the current.
    Back to PICs: The PIC pins outputs are not really resistors. They may act somewhat like resistors, but they are not. The "resistance" of the pin can vary quite a bit over Vcc variations and from device to device and even pin-to-pin. As a result, the results can be unpredictable. Please put a resistor (at least) in series with your LED.
    Charles Linquist
    Mar 2009
    Quote Originally Posted by Charles Linquis View Post
    I agree they're not what we'd deem traditional resistors...but for supply of 3.268V to the (blue) LED, I'm seeing 0.337V dropped across the PIC pin - that equates to a series DC resistance in any language. I take your point about variations (though I'm not seeing it pin to pin). So with the PIC pin V drop, that only leaves about 2.95V for the blue LED (with a rated fwd voltage of about 3.2V) ...there's not much chance a blue LED will blow with just 2.95V across it (the current through it is fairly meagre at that voltage level). Fear not, I appreciate your input (& concern), but seriously...this isn't a production run - this is for my own use (& a couple of mates if my project-ette turns out to my liking) ...simply towards learning about PICs & pushing my own (small!) boundaries...I posted up my earlier findings for interest (wrt actual real world IO pin resistance) as opposed to evangelising to others about going 'resistorless'!
    I do wonder though since 50 ohms is a surprisingly high figure, just how many factor the PIC's pin resistance in when calculating a LED resistor value? (I suspect not many) ...the resistance certainly can't be disregarded becuase certainly with relatively low value resistors normally in play for LEDs, the PIC pin's inherent resistance is gonna severely skew the desired end result.
    Sep 2005
    Campbell, CA
    I generally use 2N7002's for driving things like that. They are great, logic-level N-channel FETs that have a pretty low ON resistance. Cheap too.
    Charles Linquist
    Jan 2006
    Istanbul
    Only if using PWM on a PIC pin , you can directly drive a transistor base without a resistor.
    That will save you one component (resistor) and also space on PCB.
    If you use Mosfet with PWM, you can also directly drive the gate without resistor. But this time, you need to have a resistor between the gate and GND. This resistor is not needed if not using PWM.
    Quote Originally Posted by sayzer View Post
    Hi sayzer - I've been working on driving up to 10 LEDs with a BS170 MOSFET and have connected the PIC pin directly to the gate of the 'FET. I had seen a circuit diagram with a resistor connecting the PIC -> gate to end, but then heard that this wasn't needed. What size resistor should I use?
    Mar 2009
    Since I'm sinking current into the pin, I'm using a common (ie shared by all pins) P Channel Mosfet (with something like .2 Ohm 'on' resistance) & inverted PWM on the ECCP module ....it works well.
    For any N-Channel small MosFet needs (up to 2A) have a look at the Si2308 too. It is working fine from 4.5 Volts with Rds of 0.192 and Id of 2.1 Amp.
    And the best P-Channel Power Mosfet I have find maybe is the SUM110P04-05-E3. Usually the P-channel have high Rds and low Id specs.
