Smooth LED fading via PWM
Results 1 to 40 of 55
    May 2006
    Del Rio, TX, USA
    Default Re: Smooth LED fading via PWM
    How about something like this:
    Data 1,1,1,1,1,1,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,3, _
      3,3,3,3,3,3,3,3,3,3,3,3,4,4,4,4,4,4,4,4,4,4,4,5,5,5, _
      5,5,5,5,5,6,6,6,6,6,6,6,7,7,7,7,7,7,8,8,8,8,8,8,9,9, _
      9,9,10,10,10,10,10,11,11,11,11,12,12,12,13,13,13,13, _
      14,14,14,15,15,15,16,16,16,17,17,18,18,18,19,19,20,  _
      20,20,21,21,22,22,23,23,24,24,25,26,26,27,27,28,29,  _
      29,30,31,31,32,33,33,34,35,36,36,37,38,39,40,41,42,  _
      42,43,44,45,46,47,48,50,51,52,53,54,55,57,58,59,60,  _
      62,63,64,66,67,69,70,72,74,75,77,79,80,82,84,86,88,  _
      90,91,94,96,98,100,102,104,107,109,111,114,116,119,  _
      122,124,127,130,133,136,139,142,145,148,151,155,158, _
      161,165,169,172,176,180,184,188,192,196,201,205,210, _
      214,219,224,229,234,239,244,250,255
    Smooth_fade:
        IF Count1 = 0 THEN
             duty = 0
             IF Count1 < 26 THEN
                 duty = 1
                 Read Count1-25, duty
    WriteUserByte:
        WRITE 255, UserByte
    ReadUserByte:
        READ 255, UserByte
    Now you have the upper 25 EEPROM addresses to use. More space could be saved by using similar logic. But this hopefully gets the point across.
    Good luck,
    May 2006
    Del Rio, TX, USA
    My math was a little off, the line for the reading of the EEPROM should be
    READ count1-26, duty
    As a side note, you could make it really simple just by leaving the original table as-is and using this:
    Smooth_fade:
         IF Count1 = 0 THEN
              duty = 0
              Read Count1, duty
    WriteUserByte:
         WRITE 0, UserByte
    ReadUserByte:
         READ 0, UserByte
    Mar 2009
    Bert.. re putting my table into program memory....it's still a work in progress and with only 400 bytes left...it only takes a couple of debug commands and I'm over the limit :-(
    Byte_Butcher ...that's a good lead!
    SteveB..... if I'm reading your code right, it's what Byte_butcher proposed? (& is good clawback of EEPROM)
    I'll have a dabble later....many thanks for the input.
    May 2006
    Del Rio, TX, USA
    Quote Originally Posted by HankMcSpank View Post
    Yes, I took the suggestion from Byte_Butcher and fleshed it out a little.
    California, USA
    I've gotta go stack wood, so this is quickk and needs fixing, but this is the sort of thing I was thinking:
    count = count + 1
    If count < 33 then address = 1                   'all "counts" less than 33 point to address 1
            if count < 1 then
            address = 0                                     'unless count is 0. Then it points to address 0
            else address = count - 33                     'all counts above 33 get offset down so they pick up the sequence starting at address 2
    steve
    edited to add:
    Never mind, Steve B already did it.
    Mar 2009
    IS there a rapido way of seeing the whole contents of EEPROM?
    I'm storing a user determined byte, using this type of way..
    DEFAULT_CONFIG  DATA 1
    default_config_shadow var byte
    default_config_shadow = 101010              '
    WRITE default_config_shadow, default_config   'write the above to EEPROM
    read default_config, default_config_shadow
    DEBUG "def_shadow=",BIN default_config_shadow,13,10
    then immdeiately afterwards, I lob another 254 bytes into EEprom too...
    data   1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1, _
    1,1,1,1,1,1,1,1,1,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2, _
    2,2,2,3,3,3,3,3,3,3,3,3,3,3,3,3,4,4,4,4,4,4,4,4,4, _
    4,4,5,5,5,5,5,5,5,5,6,6,6,6,6,6,6,7,7,7,7,7,7,8,8, _
    8,8,8,8,9,9,9,9,10,10,10,10,10,11,11,11,11,12,12,12, _
    13,13,13,13,14,14,14,15,15,15,16,16,16,17,17,18,18,18, _
    19,19,20,20,20,21,21,22,22,23,23,24,24,25,26,26,27,27,28, _
    29,29,30,31,31,32,33,33,34,35,36,36,37,38,39,40,41,42,42, _
    43,44,45,46,47,48,50,51,52,53,54,55,57,58,59,60,62,63,64, _
    66,67,69,70,72,74,75,77,79,80,82,84,86,88,90,91,94,96,98, _
    100,102,104,107,109,111,114,116,119,122,124,127,130,133,136, _
    139,142,145,148,151,155,158,161,165,169,172,176,180,184,188, _
    192,196,201,205,210,214,219,224,229,234,239,244,250,255
    just wondering how that all gets accounted for in EEprom, because I'm sure there's going to be some impact with the way I read that table type data back (eg is my user defined bye stored in EEPROM memory slot0, with the rest filling sequentially afterwards?) I was previously using a counter variable to look up/reference the the data stored in EEprom, but now I'm wondering if I need to offset it by 1? (due to the user stored byte in Eeprom too ....or can I store the one user defined byte at the end of the EEPRM...the last slot)
    can I look at EEprom via the Pickit2 (I had a dabble but it wasn't obvious to read!)
    Many thanks.
    Hi Hank,
    First off all, it seems as if your WRITE statement is "reversed", you should do WRITE Adress, Value but to me it seems you have it the other way around, ie. writing whatever is in default_config to adress 42 (101010) when I think you actually want the value 42 written to adress 0, or 1 perhaps.
    Second, I think (pretty sure) you should be able to read the EEPROM with the PICKit2, I only have a PK3 but if you can't figure it out I'll have a go later. With that said you could dump the EEPROM content over a serial line (if you have one) with something like:
    Count VAR BYTE
    Result VAR BYTE
    For Count = 0 to 255
      Read Count, Result
      HSEROUT ["EEPROM Location: ", DEC3 Count, ": ", DEC RESULT,13]
    NEXT
    Third, if the first location in EEPROM (location 0) is reserved for that "userbyte" of data then you should start your DATA table with something like DATA @1, 1, 1, 1... Which will put the first entry at location 1 instead of location 0.
    Finally, remeber that DATA isn't something that executes when the program runs, it only tells the compiler/assembler to put that data in the ".hex image" so that the programmer (your PICKit2) can program the values into EEPROM together with the actual program. WRITE, on the other hand is a runtime command and does write to the EEPROM when the program executes.
    Hope that helps.
