Smooth LED fading via PWM
Results 1 to 40 of 55
    Default Re: Smooth LED fading via PWM
    Hi Hank,
    You use DATA to store the constants to EEPROM at program time. Then you use READ to retreive them at runtime. Something like:
    Data 0,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1, _
      1,1,1,1,1,1,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,3, _
      3,3,3,3,3,3,3,3,3,3,3,3,4,4,4,4,4,4,4,4,4,4,4,5,5,5, _
      5,5,5,5,5,6,6,6,6,6,6,6,7,7,7,7,7,7,8,8,8,8,8,8,9,9, _
      9,9,10,10,10,10,10,11,11,11,11,12,12,12,13,13,13,13, _
      14,14,14,15,15,15,16,16,16,17,17,18,18,18,19,19,20,  _
      20,20,21,21,22,22,23,23,24,24,25,26,26,27,27,28,29,  _
      29,30,31,31,32,33,33,34,35,36,36,37,38,39,40,41,42,  _
      42,43,44,45,46,47,48,50,51,52,53,54,55,57,58,59,60,  _
      62,63,64,66,67,69,70,72,74,75,77,79,80,82,84,86,88,  _
      90,91,94,96,98,100,102,104,107,109,111,114,116,119,  _
      122,124,127,130,133,136,139,142,145,148,151,155,158, _
      161,165,169,172,176,180,184,188,192,196,201,205,210, _
      214,219,224,229,234,239,244,250,255
    Smooth_fade:
      Read Count1, duty
    Mar 2009
    Hi Henrik,
    Great, many thanks ....simple enough & it works a treat!
    Weirdly even though I imported all those values to Excel to check there are 256 entries (there are) - I got an error when I came to compile (stack overflow)....I took one entry out & then it compiled ok. Hey ho....but I just got rid of one of the multitude of 1s in there.
    Many thanks....I've a bit more room to "breathe" in my bloaty program again
    Mar 2009
    For this specifically LED it might work and as long as the voltage is absolutely stable.
    But I insist on using a current source. You will be able to control the brightness for a really 0 to 100%.
    Even for a test it is interesting.
    I have a client that for more than a year is refering to his power (chinese) LEDs as 24Volts... And I reply with the current of your LEDs is....
    If my calculations are right, when sinking current, my 16f1828 is working out at about 52 Ohms of series resistance per pin - now whether the resistance comes by way of a resistor, or the resistive properties of the silicon inside the PIC IO driving circuitry...resistance is resistance?
    V Supply = 3.268V
    V drop measured across blue LED = 2.931V
    remianing V drop across PIC pin = 3.268V-2.931V = 0.337V
    Current through LED (inferred by measuring current into whole circuit - 11 LEDS - then taking a little off (3mA for the PIC) & dividing by 11 = 6.4mA
    Resistance of PIC pin R = V/I =....or 0.337V/0.0064A = 52.65 Ohms.
    So why not simply treat the PIC's pin as a series 52 ohm resistor for the purposes of LED current calculations? (ie what am I missing?)
    Mar 2009
    So if I want to store a (ser defined) setting that will remembered after the battery/power source has been removed from the PIC ..is EEPROM is my only option?
    If so, I have a problemette...I presently have 256 bytes that already goes into EEPROM at program time..
    ok, my first problem is, there's 256 bytes there...which maxes my EEPROM out. (16F1828)
    Now assuming i have no other way of storing a user chosen varaiable after the power has been removed (other than EEPROM), THEN I suppose I will need to forsake one of the 256 bytes in that table above ...therefore 255 bytes + 1 byte that the user chooses (& gets stored away when he presses a switch).
    But how do I control all of this. In other words if I trim the above from 256 bytes, to 255 bytes to free up one byte of EEPROM space, then the 255 bytes will go straight into EEPROM as it does now ....but how do I store the remaining (user defined) byte in the last available slot of EEPROM?
    Sorry for n00by flavour here...but a prolific search didn't yield much that I can digest/apply to this conundrum.
    Aug 2010
    Maryland, USA
    Hank do you have any code space left?
    -Bert
    Mar 2009
    Hi Bert,
    Yes, it's getting tight, but about 400 bytes left....
    Aug 2010
    Maryland, USA
    Seems like the easy way out will be to store all or part of your table in code. Maybe that is DAT? Then you have some EEeprom left. Next up, how about compressing that data somewhat. Maybe use 2 bytes for each unique number. Ie
    10,1,8,2
    So the 10 means there are 10 1's 8 2's and so forth. But since I don't know how you are using the data it's hard to guess at that.
    As for writing the user variable to EEPROM, there is a command for that. Can't think ou it off the top of my head.
    -Bert
    May 2006
    Del Rio, TX, USA
    How about something like this:
    Data 1,1,1,1,1,1,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,3, _
    Smooth_fade:
        IF Count1 = 0 THEN
             duty = 0
             IF Count1 < 26 THEN
                 duty = 1
                 Read Count1-25, duty
    WriteUserByte:
        WRITE 255, UserByte
    ReadUserByte:
        READ 255, UserByte
    Now you have the upper 25 EEPROM addresses to use. More space could be saved by using similar logic. But this hopefully gets the point across.
    Good luck,
    May 2006
    Del Rio, TX, USA
    My math was a little off, the line for the reading of the EEPROM should be
    READ count1-26, duty
    As a side note, you could make it really simple just by leaving the original table as-is and using this:
    Smooth_fade:
         IF Count1 = 0 THEN
              duty = 0
              Read Count1, duty
    WriteUserByte:
         WRITE 0, UserByte
    ReadUserByte:
         READ 0, UserByte
    Mar 2009
    Bert.. re putting my table into program memory....it's still a work in progress and with only 400 bytes left...it only takes a couple of debug commands and I'm over the limit :-(
    Byte_Butcher ...that's a good lead!
    SteveB..... if I'm reading your code right, it's what Byte_butcher proposed? (& is good clawback of EEPROM)
    I'll have a dabble later....many thanks for the input.
    May 2006
    Del Rio, TX, USA
    Quote Originally Posted by HankMcSpank View Post
    Yes, I took the suggestion from Byte_Butcher and fleshed it out a little.
    California, USA
    I've gotta go stack wood, so this is quickk and needs fixing, but this is the sort of thing I was thinking:
    count = count + 1
    If count < 33 then address = 1                   'all "counts" less than 33 point to address 1
            if count < 1 then
            address = 0                                     'unless count is 0. Then it points to address 0
            else address = count - 33                     'all counts above 33 get offset down so they pick up the sequence starting at address 2
    steve
    edited to add:
    Never mind, Steve B already did it.
    Mar 2009
    IS there a rapido way of seeing the whole contents of EEPROM?
    I'm storing a user determined byte, using this type of way..
    DEFAULT_CONFIG  DATA 1
    default_config_shadow var byte
    default_config_shadow = 101010              '
    WRITE default_config_shadow, default_config   'write the above to EEPROM
    read default_config, default_config_shadow
    DEBUG "def_shadow=",BIN default_config_shadow,13,10
    then immdeiately afterwards, I lob another 254 bytes into EEprom too...
    data   1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1, _
    1,1,1,1,1,1,1,1,1,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2, _
    2,2,2,3,3,3,3,3,3,3,3,3,3,3,3,3,4,4,4,4,4,4,4,4,4, _
    4,4,5,5,5,5,5,5,5,5,6,6,6,6,6,6,6,7,7,7,7,7,7,8,8, _
    8,8,8,8,9,9,9,9,10,10,10,10,10,11,11,11,11,12,12,12, _
    13,13,13,13,14,14,14,15,15,15,16,16,16,17,17,18,18,18, _
    19,19,20,20,20,21,21,22,22,23,23,24,24,25,26,26,27,27,28, _
    29,29,30,31,31,32,33,33,34,35,36,36,37,38,39,40,41,42,42, _
    43,44,45,46,47,48,50,51,52,53,54,55,57,58,59,60,62,63,64, _
    66,67,69,70,72,74,75,77,79,80,82,84,86,88,90,91,94,96,98, _
    100,102,104,107,109,111,114,116,119,122,124,127,130,133,136, _
    139,142,145,148,151,155,158,161,165,169,172,176,180,184,188, _
    192,196,201,205,210,214,219,224,229,234,239,244,250,255
    just wondering how that all gets accounted for in EEprom, because I'm sure there's going to be some impact with the way I read that table type data back (eg is my user defined bye stored in EEPROM memory slot0, with the rest filling sequentially afterwards?) I was previously using a counter variable to look up/reference the the data stored in EEprom, but now I'm wondering if I need to offset it by 1? (due to the user stored byte in Eeprom too ....or can I store the one user defined byte at the end of the EEPRM...the last slot)
    can I look at EEprom via the Pickit2 (I had a dabble but it wasn't obvious to read!)
    Many thanks.
