Smooth LED fading via PWM
Results 1 to 40 of 55
    Mar 2009
    Default Re: Smooth LED fading via PWM
    Quote Originally Posted by Charlie View Post
    Counting from 0 to 255, with the LED on from 0 to 1 then off from 1 to 255 should work nicely, and extending to 512 should make it dimmer yet, I agree. I'd use resistors, but what you are doing "should" work too. The only part of what you are doing that is different from what I've seen work in the past is having the fundamental of the cycle at 32 KHz. It might work, but I've had issues in the past trying to switch LEDs too fast - you might want to drop that down to a couple hundred Hz. But like most of the suggestions, this is only a guess.
    The only reason I run the frequency so high, is because the hpwm carrier *always* manages to permeate its way into the guitar signal (remember this is small signal stuff, that gets amplified by the guitar amp!)...so you always end up with an audible whine in the background.....with the hpwm at 31khz, the problem is still there, but only dogs can hear it!
    It does all work at the high frequency...I will revisit this value of '1' (out of 256 vlaues) 'being a bit too bright' issue....but not until my next breadboard session.
    Mar 2009
    so I'm running out of program memory, I'm presently using the subroutine below to lookup a counter value (count1 below) to get a preset hpwm value (duty)....
    Smooth_fade:
    Lookup count1, [ _
      0,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1, _
      1,1,1,1,1,1,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,3, _
      3,3,3,3,3,3,3,3,3,3,3,3,4,4,4,4,4,4,4,4,4,4,4,5,5,5, _
      5,5,5,5,5,6,6,6,6,6,6,6,7,7,7,7,7,7,8,8,8,8,8,8,9,9, _
      9,9,10,10,10,10,10,11,11,11,11,12,12,12,13,13,13,13, _
      14,14,14,15,15,15,16,16,16,17,17,18,18,18,19,19,20,  _
      20,20,21,21,22,22,23,23,24,24,25,26,26,27,27,28,29,  _
      29,30,31,31,32,33,33,34,35,36,36,37,38,39,40,41,42,  _
      42,43,44,45,46,47,48,50,51,52,53,54,55,57,58,59,60,  _
      62,63,64,66,67,69,70,72,74,75,77,79,80,82,84,86,88,  _
      90,91,94,96,98,100,102,104,107,109,111,114,116,119,  _
      122,124,127,130,133,136,139,142,145,148,151,155,158, _
      161,165,169,172,176,180,184,188,192,196,201,205,210, _
      214,219,224,229,234,239,244,250,255], duty
    ,....now since I've not much program space left , is there any way I can win some room back by for example stuffing the above 256 bytes into EEPROM and then look up the values similar to above? (EEPROM is a bit of a new area to me...I've never had to bother with it before!)
    If so....would you be so helpful to put me on the right track? (I'm figuring the 256 bytes will need writing into the PIC at the time of programming it & from thereon afterwards it can be read from EEPROM while the program is running?)
    Hi Hank,
    You use DATA to store the constants to EEPROM at program time. Then you use READ to retreive them at runtime. Something like:
    Data 0,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1, _
    Smooth_fade:
      Read Count1, duty
    Mar 2009
    Hi Henrik,
    Great, many thanks ....simple enough & it works a treat!
    Weirdly even though I imported all those values to Excel to check there are 256 entries (there are) - I got an error when I came to compile (stack overflow)....I took one entry out & then it compiled ok. Hey ho....but I just got rid of one of the multitude of 1s in there.
    Many thanks....I've a bit more room to "breathe" in my bloaty program again
    Mar 2009
    For this specifically LED it might work and as long as the voltage is absolutely stable.
    But I insist on using a current source. You will be able to control the brightness for a really 0 to 100%.
    Even for a test it is interesting.
    I have a client that for more than a year is refering to his power (chinese) LEDs as 24Volts... And I reply with the current of your LEDs is....
    If my calculations are right, when sinking current, my 16f1828 is working out at about 52 Ohms of series resistance per pin - now whether the resistance comes by way of a resistor, or the resistive properties of the silicon inside the PIC IO driving circuitry...resistance is resistance?
    V Supply = 3.268V
    V drop measured across blue LED = 2.931V
    remianing V drop across PIC pin = 3.268V-2.931V = 0.337V
    Current through LED (inferred by measuring current into whole circuit - 11 LEDS - then taking a little off (3mA for the PIC) & dividing by 11 = 6.4mA
    Resistance of PIC pin R = V/I =....or 0.337V/0.0064A = 52.65 Ohms.
    So why not simply treat the PIC's pin as a series 52 ohm resistor for the purposes of LED current calculations? (ie what am I missing?)
    Mar 2009
    So if I want to store a (ser defined) setting that will remembered after the battery/power source has been removed from the PIC ..is EEPROM is my only option?
    If so, I have a problemette...I presently have 256 bytes that already goes into EEPROM at program time..
    ok, my first problem is, there's 256 bytes there...which maxes my EEPROM out. (16F1828)
    Now assuming i have no other way of storing a user chosen varaiable after the power has been removed (other than EEPROM), THEN I suppose I will need to forsake one of the 256 bytes in that table above ...therefore 255 bytes + 1 byte that the user chooses (& gets stored away when he presses a switch).
    But how do I control all of this. In other words if I trim the above from 256 bytes, to 255 bytes to free up one byte of EEPROM space, then the 255 bytes will go straight into EEPROM as it does now ....but how do I store the remaining (user defined) byte in the last available slot of EEPROM?
    Sorry for n00by flavour here...but a prolific search didn't yield much that I can digest/apply to this conundrum.
    Aug 2010
    Maryland, USA
    Hank do you have any code space left?
    -Bert
    May 2006
    Del Rio, TX, USA
    How about something like this:
    Data 1,1,1,1,1,1,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,3, _
    Smooth_fade:
        IF Count1 = 0 THEN
             duty = 0
             IF Count1 < 26 THEN
                 duty = 1
                 Read Count1-25, duty
    WriteUserByte:
        WRITE 255, UserByte
    ReadUserByte:
        READ 255, UserByte
    Now you have the upper 25 EEPROM addresses to use. More space could be saved by using similar logic. But this hopefully gets the point across.
    Good luck,
    May 2006
    Del Rio, TX, USA
    My math was a little off, the line for the reading of the EEPROM should be
    READ count1-26, duty
    As a side note, you could make it really simple just by leaving the original table as-is and using this:
    Smooth_fade:
         IF Count1 = 0 THEN
              duty = 0
              Read Count1, duty
    WriteUserByte:
         WRITE 0, UserByte
    ReadUserByte:
         READ 0, UserByte
    Mar 2009
    Bert.. re putting my table into program memory....it's still a work in progress and with only 400 bytes left...it only takes a couple of debug commands and I'm over the limit :-(
    Byte_Butcher ...that's a good lead!
    SteveB..... if I'm reading your code right, it's what Byte_butcher proposed? (& is good clawback of EEPROM)
    I'll have a dabble later....many thanks for the input.
    May 2006
    Del Rio, TX, USA
    Quote Originally Posted by HankMcSpank View Post
    Yes, I took the suggestion from Byte_Butcher and fleshed it out a little.
