Smooth LED fading via PWM
Results 1 to 40 of 55
    Mar 2009
    Default Re: Smooth LED fading via PWM
    These are high brightness blue leds (quoted at about 25mA)
    I'm running the PIC at a voltage supply of 3.0Vand driving the LEDs directly from a PIC output pin (ie slightly less than the LED's 3.2 to 3.4V fwd voltage - so as to under drive them a little & protect the PIC - no series limiting resistor...yeah, I know contentious subject!)
    With a PWM value of 1 at 8 bits, that oiught to be very dull to the poiunt of not being able to see the LED, bit that's not the case...sure it's dull;, but it's clear that the LED is on...so I'm thinking if I up the number of steps to say 512 or even 1024, then that should allow much more granularity at the lower end of the PWM (where the LED remains rather perky still)
    So why not turn it off (0% dutycyle) when you want it to be off? Why do want to drive current thru it and NOT have it light up at all?
    Mar 2009
    Because I seek a smooth fade from max brightness through completely off.
    What I'm observing is that a duty cycle of 1 seems too discernibly 'on' still (I'd have thought you'd have to get up real close to it at such a duty cycle to see if it is on or not?), the 'jump between 0 & 1 from a brightness perspective, whilst small, is still too big which is why I'm thinking more resolution may help?
    (before you think why don't I just try it myself ...well, firstly I want to ask others if when using 256 steps of pwm, whether a duty value of 1 normally easily visibly shows the LED to be on.....and secondly, I've got to wrap my head around 10 bit HPWM bit mapping - the pesky registers are spread a little).
    Mar 2009
    Just to give you a flavour, this is a duty setting of 1...
    Now LED3 & LED6 happen to be faulty (I can't be bothered to swap them out right now - they're way duller than others and clearly have an issue), but I reckon with a duty cycle value of 1 the led brightness should actually be more their level!
    Now LEDS are notoriously difficult to photograph...the LEDS don't actually as bright as they do in the photo 'in the flesh', and these being high brightness have a lens that accutely magnifies any LED light but nevertheless I think they're too bright for a duty value of 1!
    Ah, I misunderstood - again...
    Yes, more resoultion might help but I honestly think the problem is the lack of current limiting resistors. Can you just give it a try, something lowish like 47ohms or so.
    Mar 2009
    Hi Henrik,
    As you can see, the board I'm working on a pcb I knocked up ....so a bit of hacking involved, but I'll give your suggestion a go tomorrow....I've just tried 9 bit PWM which was better but a duty value of 1 is still too visible.
    To my other question - does anyone know how to turn 512 linear values into log values (so I can put them in a LUT)
    Aug 2010
    Maryland, USA
    Hank, how fast is the "1" pulse hitting the LED? think of it this way, what is the duration of that single pulse? at what value does the LED max out to the eye? I don't think the issue is number of steps, but rather the duration of the step.
    -Bert
