Smooth LED fading via PWM
Page 1 of 2 12 LastLast
Results 1 to 40 of 55
    Mar 2009
    Default Smooth LED fading via PWM
    Ok, so I'm dabbling with LEDS...fading an LED smoothly until its completely off is proving to be a little irksome for me.
    Up until now, I've been using 8 bit PWM, but now I'm starting to think 8 bit PWM just isn't gonna cut it - why? Becuase even with a duty value of just 1, the LED albeit very dull, is still quite visible...I'd have thought it being switched on only 1/256th of the time would have resulted in a very hard to see LED? (or have I likely got some setting wrong?)
    Next...since we all see logarithmically, apparently a linear LED fade will just not do, I found some values on the net for a log fade (256 values), but such relatively lowish resolution makes for some rather large step jumps...
    Smooth_fade:
    Lookup count1, [ _
      0,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1, _
      1,1,1,1,1,1,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,3, _
      3,3,3,3,3,3,3,3,3,3,3,3,4,4,4,4,4,4,4,4,4,4,4,5,5,5, _
      5,5,5,5,5,6,6,6,6,6,6,6,7,7,7,7,7,7,8,8,8,8,8,8,9,9, _
      9,9,10,10,10,10,10,11,11,11,11,12,12,12,13,13,13,13, _
      14,14,14,15,15,15,16,16,16,17,17,18,18,18,19,19,20,  _
      20,20,21,21,22,22,23,23,24,24,25,26,26,27,27,28,29,  _
      29,30,31,31,32,33,33,34,35,36,36,37,38,39,40,41,42,  _
      42,43,44,45,46,47,48,50,51,52,53,54,55,57,58,59,60,  _
      62,63,64,66,67,69,70,72,74,75,77,79,80,82,84,86,88,  _
      90,91,94,96,98,100,102,104,107,109,111,114,116,119,  _
      122,124,127,130,133,136,139,142,145,148,151,155,158, _
      161,165,169,172,176,180,184,188,192,196,201,205,210, _
      214,219,224,229,234,239,244,250,255], duty
    ....how do I work out the log values for say 512 entries or 1024 entries (ok, so this is more a maths question tan a PICBASIC, but I suck at maths!)
    Jan 2006
    Istanbul
    Default Re: Smooth LED fading via PWM
    Oter than the math part, I can say two things about some LEDs.
    I have regular & cheap 120degree ultra-LEDs and datasheet says they are 15mA. These new era ultra-LEDs are quite bright even at 0.1mA.
    Diriving these LEDs with a serial resistor and with PWM may not give you a nice smooth fade effect as they are so much sensitive to current.
    So, I would look at their datasheet and see what voltage they are driven.
    Then, I would run the PIC at the same voltage, and drive them directly by the pin with no resistor.
    Say, the LED is 3.2V, then run the PIC at 3.2V.
    This way, you will see the full fade effect.
    However, if you are using different LEDs with different voltage levels on the same circuit, you will have to work on the circuit to get the same method work.
    Usually, Red LEDs are 2.10V and Green ones are 3.20V (depending on the brand some are up to 3.70V).
    If you are using Power LEDs, then the world is completely different.
    Mar 2009
    These are high brightness blue leds (quoted at about 25mA)
    I'm running the PIC at a voltage supply of 3.0Vand driving the LEDs directly from a PIC output pin (ie slightly less than the LED's 3.2 to 3.4V fwd voltage - so as to under drive them a little & protect the PIC - no series limiting resistor...yeah, I know contentious subject!)
    With a PWM value of 1 at 8 bits, that oiught to be very dull to the poiunt of not being able to see the LED, bit that's not the case...sure it's dull;, but it's clear that the LED is on...so I'm thinking if I up the number of steps to say 512 or even 1024, then that should allow much more granularity at the lower end of the PWM (where the LED remains rather perky still)
    So why not turn it off (0% dutycyle) when you want it to be off? Why do want to drive current thru it and NOT have it light up at all?
    Mar 2009
    Because I seek a smooth fade from max brightness through completely off.
    What I'm observing is that a duty cycle of 1 seems too discernibly 'on' still (I'd have thought you'd have to get up real close to it at such a duty cycle to see if it is on or not?), the 'jump between 0 & 1 from a brightness perspective, whilst small, is still too big which is why I'm thinking more resolution may help?
    (before you think why don't I just try it myself ...well, firstly I want to ask others if when using 256 steps of pwm, whether a duty value of 1 normally easily visibly shows the LED to be on.....and secondly, I've got to wrap my head around 10 bit HPWM bit mapping - the pesky registers are spread a little).
    Mar 2009
    Just to give you a flavour, this is a duty setting of 1...
    Now LED3 & LED6 happen to be faulty (I can't be bothered to swap them out right now - they're way duller than others and clearly have an issue), but I reckon with a duty cycle value of 1 the led brightness should actually be more their level!
    Now LEDS are notoriously difficult to photograph...the LEDS don't actually as bright as they do in the photo 'in the flesh', and these being high brightness have a lens that accutely magnifies any LED light but nevertheless I think they're too bright for a duty value of 1!
    Ah, I misunderstood - again...
    Yes, more resoultion might help but I honestly think the problem is the lack of current limiting resistors. Can you just give it a try, something lowish like 47ohms or so.
    Mar 2009
    Hi Henrik,
    As you can see, the board I'm working on a pcb I knocked up ....so a bit of hacking involved, but I'll give your suggestion a go tomorrow....I've just tried 9 bit PWM which was better but a duty value of 1 is still too visible.
    To my other question - does anyone know how to turn 512 linear values into log values (so I can put them in a LUT)
    Aug 2010
    Maryland, USA
    Hank, how fast is the "1" pulse hitting the LED? think of it this way, what is the duration of that single pulse? at what value does the LED max out to the eye? I don't think the issue is number of steps, but rather the duration of the step.
    -Bert
    Mar 2009
    Hi Bert,
    I'm using a HPWM frequency of 31.25KHZ (8Mhz clock & HPWM PR2 value of 63), so I'm figuring a duty value of 1 should only result in a pulse width of approx 125ns ?
    1. Bright LEDs light even with nA current. I had a 5 meter LED stripe that some of the LEDs were ON while not connected to any power source!!! (Yeah, from static charge).
    2. LEDs are not like lamps, so you cannot control them by a simple PWM idea. LEDs are current dependant devices so, you have to control them by current source and NOT by voltage as you do now.
    My suggestion is not to bother with more resolution an try to control, by PWM, the current of the LEDs. Then you will have the exact same effect like simple filament lamps.
    Mar 2009
    I reckon this is the issue here....high brightness leds, with a lens that intensifies even the smallest amount of light = looks too 'on' even when almost off!
    Yeah, I know led's are current driven devices, but what gives...if the rated forward voltage is say 3.4V, but I run them at 3.1V regulated (because they yield sufficient brightness even at that voltage level)..then PWM principles ought to work fine (in fact, PWM does work just fine without the resistor...I'm running it here now!)....& there's always the internal series resistance of the PIC OP pin (5 ohms? not a lot, but resistance nevertheless)
    For this specifically LED it might work and as long as the voltage is absolutely stable.
    But I insist on using a current source. You will be able to control the brightness for a really 0 to 100%.
    Even for a test it is interesting.
    I have a client that for more than a year is refering to his power (chinese) LEDs as 24Volts... And I reply with the current of your LEDs is....
    Mar 2009
    Just going off tack a little (still intend breadboarding this up so I can easily inster leds to suit - but for now stuck with my PCB).
    I want the PIC pins to sink surrent, therefore I rejigged everything to have all the LED cathodes pointing at the pin, with all the anodes commoned and a P channel mosfet switching 3.2V to the anodes (via HPWM on the mosfet gate).
    Something took me aback a little, with a duty value of 255, my leds were still *just* lit (remember we are talking reverse now, so a value of 255 is essentially 0), I changed the duty value to 256 & then the leds switched off ...therefore for all I thought I was using 8 bit/256 values (PR2=63 @8Mhhz, no pre/post ) I was actually using 257 values (and therefore a value 0f 255 sorta equalled 1)...this sucks cos obviously 257th value needs 9 bits! Now I know 255 is almost 256 so as not to worry that much....but is there any way of setting up the HPWM so that 100% duty = 255 exactly?
    (BTW I've since inverted the PIC's HPWM ouput so now a value of 0 = the supply voltage & 255 = 0, which has solved my problem of the LEDs not totally extinguishing at a value of 255)
    Hi Hank,
    I would think PR2=64 would make the resolution an even 8 bits, have you tried that?
    Mar 2009
    No I haven't tried it, but according to Mr E's multicalc, a PWM PR2 value of 64 yields @8Mhz gives 259 steps, with a value of 258 yielding a duty of 99.23%
    Unless I'm missing something obvious (highly likely!), I'd have thought it'd be simpler to set a HPWM PR2 number that gives exactly 256 steps (therefore a max duty value of 255)
    Hi Hank,
    Hmm, you might be right. It just seems that a PR2 of 64 would be more "even" since 64*4=256. On the other hand, 63 is 111111 in binary and if we stick the two lower counter bits to that we 11111111 which is 255 and then a dutycycle value of 255 "should" be 100%.
    You are "splitting" the dutycycle value, putting the 6 high bits in CCPR1L and the two low bits in CCP1CON.5 and .4 right?
    Mar 2009
    Hi Hank,
    Yes I am. Here's what I'm seeing...
    PR2 = 62 ....... 253 is final value (giving 254 steps ....0-253 etc)
    PR2 = 63 ....... 256 is final value (giving 257 steps)
    PR2 = 64 ....... 260 is final value (giving 261 steps)
    I'm rather surprised that there's no obvious HPWM setting which would give exactly 256 steps (0-255), but I guess for most, 255 is as near 256 so as not to worry so a setting of PR2=63 should suffice.
    Dec 2010
    Static charge is by nature static and won't power LEDs. Do you have a wireless router? There is a known issue with early LED Christmas lights illuminating by acting as rectifying antennae. I have a set - turn off my wireless router and they extinguish. Of course, you might live next door to a ham operator as well... but walking across the carpet won't do it.
    Dec 2010
    Counting from 0 to 255, with the LED on from 0 to 1 then off from 1 to 255 should work nicely, and extending to 512 should make it dimmer yet, I agree. I'd use resistors, but what you are doing "should" work too. The only part of what you are doing that is different from what I've seen work in the past is having the fundamental of the cycle at 32 KHz. It might work, but I've had issues in the past trying to switch LEDs too fast - you might want to drop that down to a couple hundred Hz. But like most of the suggestions, this is only a guess.
    Mar 2009
    Quote Originally Posted by Charlie View Post
    The only reason I run the frequency so high, is because the hpwm carrier *always* manages to permeate its way into the guitar signal (remember this is small signal stuff, that gets amplified by the guitar amp!)...so you always end up with an audible whine in the background.....with the hpwm at 31khz, the problem is still there, but only dogs can hear it!
    It does all work at the high frequency...I will revisit this value of '1' (out of 256 vlaues) 'being a bit too bright' issue....but not until my next breadboard session.
    Mar 2009
    so I'm running out of program memory, I'm presently using the subroutine below to lookup a counter value (count1 below) to get a preset hpwm value (duty)....
    Smooth_fade:
    Lookup count1, [ _
    ,....now since I've not much program space left , is there any way I can win some room back by for example stuffing the above 256 bytes into EEPROM and then look up the values similar to above? (EEPROM is a bit of a new area to me...I've never had to bother with it before!)
    If so....would you be so helpful to put me on the right track? (I'm figuring the 256 bytes will need writing into the PIC at the time of programming it & from thereon afterwards it can be read from EEPROM while the program is running?)
    Hi Hank,
    You use DATA to store the constants to EEPROM at program time. Then you use READ to retreive them at runtime. Something like:
    Data 0,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1, _
    Smooth_fade:
      Read Count1, duty
    Mar 2009
    Hi Henrik,
    Great, many thanks ....simple enough & it works a treat!
    Weirdly even though I imported all those values to Excel to check there are 256 entries (there are) - I got an error when I came to compile (stack overflow)....I took one entry out & then it compiled ok. Hey ho....but I just got rid of one of the multitude of 1s in there.
    Many thanks....I've a bit more room to "breathe" in my bloaty program again
    Mar 2009
    If my calculations are right, when sinking current, my 16f1828 is working out at about 52 Ohms of series resistance per pin - now whether the resistance comes by way of a resistor, or the resistive properties of the silicon inside the PIC IO driving circuitry...resistance is resistance?
    V Supply = 3.268V
    V drop measured across blue LED = 2.931V
    remianing V drop across PIC pin = 3.268V-2.931V = 0.337V
    Current through LED (inferred by measuring current into whole circuit - 11 LEDS - then taking a little off (3mA for the PIC) & dividing by 11 = 6.4mA
    Resistance of PIC pin R = V/I =....or 0.337V/0.0064A = 52.65 Ohms.
    So why not simply treat the PIC's pin as a series 52 ohm resistor for the purposes of LED current calculations? (ie what am I missing?)
    Mar 2009
    So if I want to store a (ser defined) setting that will remembered after the battery/power source has been removed from the PIC ..is EEPROM is my only option?
    If so, I have a problemette...I presently have 256 bytes that already goes into EEPROM at program time..
    ok, my first problem is, there's 256 bytes there...which maxes my EEPROM out. (16F1828)
    Now assuming i have no other way of storing a user chosen varaiable after the power has been removed (other than EEPROM), THEN I suppose I will need to forsake one of the 256 bytes in that table above ...therefore 255 bytes + 1 byte that the user chooses (& gets stored away when he presses a switch).
    But how do I control all of this. In other words if I trim the above from 256 bytes, to 255 bytes to free up one byte of EEPROM space, then the 255 bytes will go straight into EEPROM as it does now ....but how do I store the remaining (user defined) byte in the last available slot of EEPROM?
    Sorry for n00by flavour here...but a prolific search didn't yield much that I can digest/apply to this conundrum.
    Aug 2010
    Maryland, USA
    Hank do you have any code space left?
    -Bert
    Mar 2009
    Hi Bert,
    Yes, it's getting tight, but about 400 bytes left....
    Aug 2010
    Maryland, USA
    Seems like the easy way out will be to store all or part of your table in code. Maybe that is DAT? Then you have some EEeprom left. Next up, how about compressing that data somewhat. Maybe use 2 bytes for each unique number. Ie
    10,1,8,2
    So the 10 means there are 10 1's 8 2's and so forth. But since I don't know how you are using the data it's hard to guess at that.
    As for writing the user variable to EEPROM, there is a command for that. Can't think ou it off the top of my head.
    -Bert
    Aug 2010
    Maryland, USA
    Hank, just skimmed over the post and I see I have steered you back to where you were. Sorry for that. How are you usin the data? Maybe we can compress it. Are you using it in order or random access?
    -Bert
    Aug 2008
    Portugal
    Maybe the WRITE command.......
    Thanks and Regards;
    Gadelhas
    California, USA
    I think instead of having 31 consecutive memory locations that contain a "1", I'd just store the first 1 and arrange my code so that when it looks up those locations they all point to the one slot that actually contains the "1".
    May 2006
    Del Rio, TX, USA
    How about something like this:
    Data 1,1,1,1,1,1,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,3, _
    Smooth_fade:
        IF Count1 = 0 THEN
             duty = 0
             IF Count1 < 26 THEN
                 duty = 1
                 Read Count1-25, duty
    WriteUserByte:
        WRITE 255, UserByte
    ReadUserByte:
        READ 255, UserByte
    Now you have the upper 25 EEPROM addresses to use. More space could be saved by using similar logic. But this hopefully gets the point across.
    Good luck,
    May 2006
    Del Rio, TX, USA
    My math was a little off, the line for the reading of the EEPROM should be
    READ count1-26, duty
    As a side note, you could make it really simple just by leaving the original table as-is and using this:
    Smooth_fade:
         IF Count1 = 0 THEN
              duty = 0
              Read Count1, duty
    WriteUserByte:
         WRITE 0, UserByte
    ReadUserByte:
         READ 0, UserByte
    Mar 2009
    Bert.. re putting my table into program memory....it's still a work in progress and with only 400 bytes left...it only takes a couple of debug commands and I'm over the limit :-(
    Byte_Butcher ...that's a good lead!
    SteveB..... if I'm reading your code right, it's what Byte_butcher proposed? (& is good clawback of EEPROM)
    I'll have a dabble later....many thanks for the input.
    May 2006
    Del Rio, TX, USA
    Quote Originally Posted by HankMcSpank View Post
    Yes, I took the suggestion from Byte_Butcher and fleshed it out a little.
    California, USA
    I've gotta go stack wood, so this is quickk and needs fixing, but this is the sort of thing I was thinking:
    count = count + 1
    If count < 33 then address = 1                   'all "counts" less than 33 point to address 1
            if count < 1 then
            address = 0                                     'unless count is 0. Then it points to address 0
            else address = count - 33                     'all counts above 33 get offset down so they pick up the sequence starting at address 2
    steve
    edited to add:
    Never mind, Steve B already did it.
    Mar 2009
    IS there a rapido way of seeing the whole contents of EEPROM?
    I'm storing a user determined byte, using this type of way..
    DEFAULT_CONFIG  DATA 1
    default_config_shadow var byte
    default_config_shadow = 101010              '
    WRITE default_config_shadow, default_config   'write the above to EEPROM
    read default_config, default_config_shadow
    DEBUG "def_shadow=",BIN default_config_shadow,13,10
    then immdeiately afterwards, I lob another 254 bytes into EEprom too...
    data   1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1, _
    1,1,1,1,1,1,1,1,1,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2, _
    2,2,2,3,3,3,3,3,3,3,3,3,3,3,3,3,4,4,4,4,4,4,4,4,4, _
    4,4,5,5,5,5,5,5,5,5,6,6,6,6,6,6,6,7,7,7,7,7,7,8,8, _
    8,8,8,8,9,9,9,9,10,10,10,10,10,11,11,11,11,12,12,12, _
    13,13,13,13,14,14,14,15,15,15,16,16,16,17,17,18,18,18, _
    19,19,20,20,20,21,21,22,22,23,23,24,24,25,26,26,27,27,28, _
    29,29,30,31,31,32,33,33,34,35,36,36,37,38,39,40,41,42,42, _
    43,44,45,46,47,48,50,51,52,53,54,55,57,58,59,60,62,63,64, _
    66,67,69,70,72,74,75,77,79,80,82,84,86,88,90,91,94,96,98, _
    100,102,104,107,109,111,114,116,119,122,124,127,130,133,136, _
    139,142,145,148,151,155,158,161,165,169,172,176,180,184,188, _
    192,196,201,205,210,214,219,224,229,234,239,244,250,255
    just wondering how that all gets accounted for in EEprom, because I'm sure there's going to be some impact with the way I read that table type data back (eg is my user defined bye stored in EEPROM memory slot0, with the rest filling sequentially afterwards?) I was previously using a counter variable to look up/reference the the data stored in EEprom, but now I'm wondering if I need to offset it by 1? (due to the user stored byte in Eeprom too ....or can I store the one user defined byte at the end of the EEPRM...the last slot)
    can I look at EEprom via the Pickit2 (I had a dabble but it wasn't obvious to read!)
    Many thanks.
    Hi Hank,
    First off all, it seems as if your WRITE statement is "reversed", you should do WRITE Adress, Value but to me it seems you have it the other way around, ie. writing whatever is in default_config to adress 42 (101010) when I think you actually want the value 42 written to adress 0, or 1 perhaps.
    Second, I think (pretty sure) you should be able to read the EEPROM with the PICKit2, I only have a PK3 but if you can't figure it out I'll have a go later. With that said you could dump the EEPROM content over a serial line (if you have one) with something like:
    Count VAR BYTE
    Result VAR BYTE
    For Count = 0 to 255
      Read Count, Result
      HSEROUT ["EEPROM Location: ", DEC3 Count, ": ", DEC RESULT,13]
    NEXT
    Third, if the first location in EEPROM (location 0) is reserved for that "userbyte" of data then you should start your DATA table with something like DATA @1, 1, 1, 1... Which will put the first entry at location 1 instead of location 0.
    Finally, remeber that DATA isn't something that executes when the program runs, it only tells the compiler/assembler to put that data in the ".hex image" so that the programmer (your PICKit2) can program the values into EEPROM together with the actual program. WRITE, on the other hand is a runtime command and does write to the EEPROM when the program executes.
    Hope that helps.
    Mar 2009
    A great answer Henrik (good spot on my erroneous write too!)
    That was a top heads up wrt ....DATA @1, ""
    and goes some way to resolving the confusion I have wrt managing where the written Eeprom data commences being stored! Presumably I can tuck the user defined byte (called default_config) away at the very last slot of eeprom with...
    DEFAULT_CONFIG  DATA 255
    & then place the other 255 bytes below that?
    ... I'll revisit this after the kids are off to bed, but that was a great reply & gives me plenty to get my teeth into - thanks. (PS I haven't forgot about the DDS stuff you did ...I really want to revisit that as soon as I'm finished this melarkey!)
