MAPLAB X and PBP 2.60C
Results 1 to 3 of 3
    Jul 2011
    Hawaii
    Default MAPLAB X and PBP 2.60C
    I have installed MPLAB X and have downloaded the MPLAB X plugin and installed into MPLAB X for PBP language highlighting. I do not see any context highlighting. Can this be done with PBP 2.60C or must I use PBP3 ?
    When I do a build of my current project I get the following :
    make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf
    make[1]: Entering directory `/c/Users/Martin/MPLABXProjects/zigbee_digi_1.X'
    make -f nbproject/Makefile-default.mk dist/default/production/zigbee_digi_1.X.production.cof
    make[2]: Entering directory `/c/Users/Martin/MPLABXProjects/zigbee_digi_1.X'
    mkdir -p build/default/production/_ext/967472793
    C:\\PBP\\PBPW.EXE -ampasmx -k# -os -p18f26j11 ../../Documents/MCSP/My\ Programs/ZB\ Test/ZB_6.pbp
    PICBASIC PRO(TM) Compiler 2.60C, (c) 1998, 2011 microEngineering Labs, Inc.
    All Rights Reserved.
    make[2]: *** [build/default/production/_ext/967472793/ZB_6\.cof] Error 1
    make[1]: *** [.build-conf] Error 2
    make: *** [.build-impl] Error 2
    ERROR: Unable to execute mpasmx.make[2]: Leaving directory `/c/Users/Martin/MPLABXProjects/zigbee_digi_1.X'
    make[1]: Leaving directory `/c/Users/Martin/MPLABXProjects/zigbee_digi_1.X'
    BUILD FAILED (exit value 2, total time: 1s)
    Default Re: MAPLAB X and PBP 2.60C
    Downkoad PBP3 demo an try. Sure enough new PBP is stated as MPLAB-X compatible.
    What's the hype 'round MPLAB-X btw?
    Jul 2011
    Hawaii
    Hi Steve.
    I installed the PBP3 demo and have it now integrated with MPLAB X except for the syntax highlighting feature. I have the plugin for PBP installed though but no highlighting showing up. Now compiles and can program with the ICD 3. Not sure what all the hype is as of yet. Just jumping in to see whats there. Still on the path of discovery yet.
    - Martin
