RA5/MCLR input in 16f88
Results 1 to 6 of 6
    Kacho, you can produce what looks like a reset by inserting these lines of code where you need the reset to occur:
    clear
    @ clrf PCLATH
    @ goto 0
    It will nor reset the hardware registers but clear all user variables and start the probram from scratch as if it was just reset.
    kacho's Avatar
    kacho Guest
    Thanks Dave,
    the question is that :could I change with
    if button > 5 sec then @DEVICE MCLR_OFF .... and later
    If button > 10 sec. then @DEVICE MCLR_ON
    or this is possible only in the initial declarations ?
    Thxs
    i don't believe it's gonna work. These setting are only for the PIC programmer at programming time.
    Talking
    A simple clear is to jump to the beginning of the program if pin 5 = xxx
    with very little work , you do what you want for clearing registers ...
    Now, If your program fails, then it's a programming problem ... not a hardware problem.
    Remenber chips never do errors ...
  1. Sony LanC Program
    By l_gaminde in forum Code Examples
    Last Post: - 25th September 2009, 19:51
  2. LED "capacitance" won't get lower
    Last Post: - 3rd May 2007, 21:31
  3. Timing input pulses and re-outputting them
    Last Post: - 28th February 2007, 02:50
  4. 16f88 - pin RA4 as analog input
    Last Post: - 15th December 2006, 14:55
  5. 16F88 reading Analog Input
    By thunderstrike44 in forum mel PIC BASIC Pro
    Last Post: - 30th August 2004, 23:41
