Change variable allocation to save code space
Results 1 to 12 of 12
Threaded View
  1. #10
    Dec 2007
    Paris
    Default Re: Change variable allocation to save code space
    Oh yeah, coming from hardware development as a hobby I am very excited to start mastering a bit more microcontrollers. Makes a whole new world of possibilities!
    Now my code is working absolutely flawlessly. I have not much reason to change it but I'd like to learn about possibilities to further shrink the code as it seems to be very redundant right now... with my latest optimizations it compiles with around 3150 words so there is still some free space.
    Project is a LED sign that I have designed for a friend. There are now 52 different animations that are all listed in the table below. The names at the top of the matrix are the subroutine that needs to be called to execute the corresponding animation
    And the full program:
    '*  Name    : Tattoosign.pbp                                               *
    '*  Author  : Antoine Bercovici                                            *
    '*  Date    : 08/08/2011                                                   *
    '*  Version : 1.0                                                          *
    __config _HS_OSC & _WDT_ON & _MCLRE_ON & _BOREN_OFF & _LVP_OFF & _CP_ON
    DEFINE OSC 20
    DEFINE LOADER_USED 1
    clear
    'Init for PIC16F648A
    CMCON = %00000111 'Disable comparator module
    TRISA = %00000000 'All PortA is output
    TRISB = %00000001 'All PortB is output, PortB.0 is input
    INTCON = %00010000 'Enable Interrupt on PortB.0
    OPTION_REG.6 = 0 'Interrupt on falling edge 1->0 transition
    'I/O port declaration
    DATShift    VAR PORTA.2
    CLKShift    VAR PortB.1
    STRShift    VAR PortB.3
    PushButton  VAR PortB.0
    'Variable declaration
    ShiftCounter VAR BYTE
    PWMCounter VAR Byte
    AnimationCounter VAR BYTE
    AnimationSpeed VAR WORD
    AnimationStyle VAR BYTE
    AnimationNumber VAR BYTE
    StoredAnimationSpeed VAR BYTE
    SpeedCounter VAR WORD
    ButtonCounter VAR BYTE
    PhaseCounter VAR BYTE
    Buffer VAR BYTE
    DemoMode VAR BIT
    DemoCounter VAR WORD
    LEDPattern VAR BYTE[76]
    Phase VAR BYTE[16]
    RedSegment1 VAR LEDPattern[23]
    RedSegment2 VAR LEDPattern[21]
    RedSegment3 VAR LEDPattern[15]
    RedSegment4 VAR LEDPattern[12]
    RedSegment5 VAR LEDPattern[6]
    RedSegment6 VAR LEDPattern[4]
    RedSegment7 VAR LEDPattern[26]
    RedSegment8 VAR LEDPattern[17]
    RedSegment9 VAR LEDPattern[19]
    RedSegment10 VAR LEDPattern[10]
    RedSegment11 VAR LEDPattern[8]
    RedSegment12 VAR LEDPattern[2]
    RedSegment13 VAR LEDPattern[0]
    RedSegment14 VAR LEDPattern[30]
    RedSegment15 VAR LEDPattern[28]
    RedSegment16 VAR LEDPattern[35]
    RedSegment17 VAR LEDPattern[38]
    RedSegment18 VAR LEDPattern[36]
    RedSegment19 VAR LEDPattern[33]
    RedSegment20 VAR LEDPattern[55]
    RedSegment21 VAR LEDPattern[53]
    RedSegment22 VAR LEDPattern[43]
    RedSegment23 VAR LEDPattern[46]
    RedSegment24 VAR LEDPattern[44]
    RedSegment25 VAR LEDPattern[41]
    RedSegment26 VAR LEDPattern[48]
    RedSegment27 VAR LEDPattern[56]
    RedSegment28 VAR LEDPattern[58]
    RedSegment29 VAR LEDPattern[62]
    RedSegment30 VAR LEDPattern[60]
    RedSegment31 VAR LEDPattern[74]
    RedSegment32 VAR LEDPattern[64]
    RedSegment33 VAR LEDPattern[66]
    RedSegment34 VAR LEDPattern[70]
    RedSegment35 VAR LEDPattern[68]
    GreenSegment1 VAR LEDPattern[24]
    GreenSegment2 VAR LEDPattern[22]
    GreenSegment3 VAR LEDPattern[20]
    GreenSegment4 VAR LEDPattern[13]
    GreenSegment5 VAR LEDPattern[7]
    GreenSegment6 VAR LEDPattern[5]
    GreenSegment7 VAR LEDPattern[27]
    GreenSegment8 VAR LEDPattern[25]
    GreenSegment9 VAR LEDPattern[18]
    GreenSegment10 VAR LEDPattern[11]
    GreenSegment11 VAR LEDPattern[9]
    GreenSegment12 VAR LEDPattern[3]
    GreenSegment13 VAR LEDPattern[1]
    GreenSegment14 VAR LEDPattern[31]
    GreenSegment15 VAR LEDPattern[29]
    GreenSegment16 VAR LEDPattern[51]
    GreenSegment17 VAR LEDPattern[39]
    GreenSegment18 VAR LEDPattern[37]
    GreenSegment19 VAR LEDPattern[32]
    GreenSegment20 VAR LEDPattern[50]
    GreenSegment21 VAR LEDPattern[54]
    GreenSegment22 VAR LEDPattern[52]
    GreenSegment23 VAR LEDPattern[47]
    GreenSegment24 VAR LEDPattern[45]
    GreenSegment25 VAR LEDPattern[40]
    GreenSegment26 VAR LEDPattern[49]
    GreenSegment27 VAR LEDPattern[72]
    GreenSegment28 VAR LEDPattern[59]
    GreenSegment29 VAR LEDPattern[63]
    GreenSegment30 VAR LEDPattern[61]
    GreenSegment31 VAR LEDPattern[75]
    GreenSegment32 VAR LEDPattern[73]
    GreenSegment33 VAR LEDPattern[67]
    GreenSegment34 VAR LEDPattern[71]
    GreenSegment35 VAR LEDPattern[69]
    TattooSegment1 VAR LEDPattern[14]
    TattooSegment2 VAR LEDPattern[16]
    TattooSegment3 VAR LEDPattern[34]
    TattooSegment4 VAR LEDPattern[42]
    TattooSegment5 VAR LEDPattern[57]
    TattooSegment6 VAR LEDPattern[65]
    Phase1 VAR Phase[1]
    Phase2 VAR Phase[2]
    Phase3 VAR Phase[3]
    Phase4 VAR Phase[4]
    Phase5 VAR Phase[5]
    Phase6 VAR Phase[6]
    Phase7 VAR Phase[7]
    Phase8 VAR Phase[8]
    Phase9 VAR Phase[9]
    Phase10 VAR Phase[10]
    Phase11 VAR Phase[11]
    Phase12 VAR Phase[12]
    Phase13 VAR Phase[13]
    Phase14 VAR Phase[14]
    Phase15 VAR Phase[15]
    Phase16 VAR Phase[16]
    'Init the interrupt handling system
    INCLUDE "DT_INTS-14.bas" 'Base Interrupt System
    INCLUDE "ReEnterPBP.bas" 'Include if using PBP interrupts
    INT_LIST  macro     ; IntSource,          Label,  Type, ResetFlag?
            INT_Handler     INT_INT,   _ButtonInterrupt,   PBP,  Yes
    wsave VAR BYTE $70 SYSTEM 'alternate save location for W, for DT_INTS use
    'Program start
    ShiftCounter = 0
    AnimationCounter = 0
    SpeedCounter = 255
    ButtonCounter = 0
    DemoMode = 0
    DemoCounter = 0
    AnimationNumber = 51
    READ 0, AnimationStyle
    READ 1, StoredAnimationSpeed
    IF PushButton = 0 THEN
        DemoMode = 1
        AnimationStyle = 0
        StoredAnimationSpeed = 5
    @ INT_ENABLE INT_INT ; enable Button interrupt
    'Main program loop
    MainLoop:
    Gosub AnimationUpdate
    GOSUB DisplayLoop
    GOTO MainLoop
    'Do one display loop
    DisplayLoop:
    FOR PWMCounter = 0 TO 8 'There are 9 PWM shades from 0 (all off) to 8 (all on)
        FOR ShiftCounter = 79 TO 0 STEP - 1
            IF LedPattern[ShiftCounter] > PWMCounter THEN
                LOW DATShift
                HIGH DATShift
            HIGH CLKShift
            LOW CLKShift
        Next ShiftCounter
        HIGH STRShift
        LOW STRShift
    NEXT PWMCounter
    'Update one step for animation status
    AnimationUpdate:
    IF DemoMode = 1 THEN
        DemoCounter = DemoCounter + 1
        IF DemoCounter >= 1200 THEN
            DemoCounter = 0
            AnimationStyle = AnimationStyle + 1
            IF AnimationStyle > AnimationNumber THEN AnimationStyle = 0
    LOOKUP StoredAnimationSpeed, [6, 8, 10, 12, 14, 17, 21, 27, 33, 50, 80, 160, 0], AnimationSpeed
    IF AnimationStyle > 31 THEN AnimationSpeed = AnimationSpeed * 2
    IF SpeedCounter >= AnimationSpeed THEN
        SpeedCounter = 0
        IF AnimationSpeed > 0 THEN AnimationCounter = AnimationCounter + 1
        IF AnimationCounter >= 16 THEN AnimationCounter = 0 'There are 16 steps for an animation loop
    SpeedCounter = SpeedCounter + 1
    IF AnimationStyle <= 27 THEN GOSUB MonoGradient
    IF AnimationStyle >= 28 AND AnimationStyle <= 31 THEN GOSUB PolyGradient
    IF AnimationStyle >= 32 AND AnimationStyle <= 37 THEN GOSUB NarrowColorBanding
    IF AnimationStyle >= 38 THEN GOSUB MediumColorBanding
    GOSUB TurnAllOff
    Select CASE AnimationStyle
        CASE 1
            GOSUB TurnRedON
        Case 2
            GOSUB TurnGreenON
        CASE 3
            GOSUB TurnRedON
            GOSUB TurnGreenON
        CASE 4, 5
            GOSUB RedGradient
        CASE 6, 7
            GOSUB GreenGradient
        CASE 8, 9
            GOSUB RedGradient
            GOSUB GreenGradient
        CAsE 10, 11
            GOSUB TurnGreenON
            GOSUB RedGradient
        CASE 12, 13
            GOSUB TurnRedON
            GOSUB GreenGradient
        CASE 14, 15
            GOSUB VerticalRedGradient
        CASE 16, 17
            GOSUB VerticalGreenGradient
        CASE 18, 19
        CASE 20, 21
            GOSUB TurnGreenON
        CASE 22, 23
            GOSUB TurnRedON
        CASE 24
            GOSUB MonoRedGradient
        CASE 25
            GOSUB MonoGreenGradient
        CASE 26
        CASE 27
            GOSUB MonoRedAntiGradient
        Case 28, 29
            GOSUB GreenGradient
            GOSUB RedAntiGradient
        CASE 30, 31
            GOSUB VerticalRedAntiGradient
        CASE 32
            GOSUB RedGradient
        CASE 33
            GOSUB GreenGradient
        CASE 34
            GOSUB RedGradient
            GOSUB GreenGradient
        CASE 35
            GOSUB TurnGreenON
            GOSUB RedGradient
        CASE 36
            GOSUB TurnRedON
            GOSUB GreenGradient
        CASE 37, 38, 39
            GOSUB GreenGradient
            GOSUB RedShortAntiGradient
        CASE 40, 41
            GOSUB RedGradient
        CASE 42, 43
            GOSUB GreenGradient
        CASE 44, 45
            GOSUB RedGradient
            GOSUB GreenGradient
        CASE 46, 47
            GOSUB TurnGreenON
            GOSUB RedGradient
        CASE 48, 49
            GOSUB TurnRedON
            GOSUB GreenGradient
        CASE 50, 51
            GOSUB GreenGradient
            GOSUB RedMediumAntiGradient
    END SELECT
    GOSUB TurnTATTOOon
    'Monochromatic gradient Right
    MonoGradient:
    FOR PhaseCounter = 0 TO 15
        LOOKUP AnimationCounter + PhaseCounter, [0, 1, 2, 3, 4, 5, 6, 7, 8, 7, 6, 5, 4, 3, 2, 1, 0, 1, 2, 3, 4, 5, 6, 7, 8, 7, 6, 5, 4, 3, 2, 1], Buffer
        GOSUB GradientDirection
    NEXT PhaseCounter
    'Polychromatic gradient
    PolyGradient:
        LOOKUP AnimationCounter + PhaseCounter, [0, 2, 4, 6, 8, 8, 8, 8, 8, 8, 8, 8, 8, 6, 4, 2, 0, 2, 4, 6, 8, 8, 8, 8, 8, 8, 8, 8, 8, 6, 4, 2], Buffer
    NEXT PhaseCounter
    'Narrow color banding
    NarrowColorBanding:
        Buffer = AnimationCounter + PhaseCounter
        IF Buffer.0 = 0 THEN
            Buffer = 0
            Buffer = 8
        Phase[PhaseCounter + 1] = Buffer
    NEXT PhaseCounter
    'Medium color banding
    MediumColorBanding:
        IF Buffer.1 = 0 THEN
            Buffer = 0
            Buffer = 8
    NEXT PhaseCounter
    'Gradient Direction is left or right
    GradientDirection:
    IF AnimationStyle.0 = 0 THEN
        Phase[16 - PhaseCounter] = Buffer
    'Turn all LEDs off
    TurnAllOff:
    FOR ShiftCounter = 0 TO 75
        LedPattern[ShiftCounter] = 0
    Next ShiftCounter
    'Turn TATTOO on
    TurnTATTOOon:
    TattooSegment1 = 8
    TattooSegment2 = 8
    TattooSegment3 = 8
    TattooSegment4 = 8
    TattooSegment5 = 8
    TattooSegment6 = 8
    'TATTOO Gradient
    'TATTOOGradient:
    'TattooSegment1 = Phase1
    'TattooSegment2 = Phase1
    'TattooSegment3 = Phase1
    'TattooSegment4 = Phase1
    'TattooSegment5 = Phase1
    'TattooSegment6 = Phase1
    'TATTOO shift
    'TATTOOShift:
    'TattooSegment2 = Phase2
    'TattooSegment3 = Phase3
    'TattooSegment4 = Phase4
    'TattooSegment5 = Phase5
    'TattooSegment6 = Phase6
    'RETURN
    'Turn Green segments on
    TurnGreenOn:
    GreenSegment1 = 8
    GreenSegment2 = 8
    GreenSegment3 = 8
    GreenSegment4 = 8
    GreenSegment5 = 8
    GreenSegment6 = 8
    GreenSegment7 = 8
    GreenSegment8 = 8
    GreenSegment9 = 8
    GreenSegment10 = 8
    GreenSegment11 = 8
    GreenSegment12 = 8
    GreenSegment13 = 8
    GreenSegment14 = 8
    GreenSegment15 = 8
    GreenSegment16 = 8
    GreenSegment17 = 8
    GreenSegment18 = 8
    GreenSegment19 = 8
    GreenSegment20 = 8
    GreenSegment21 = 8
    GreenSegment22 = 8
    GreenSegment23 = 8
    GreenSegment24 = 8
    GreenSegment25 = 8
    GreenSegment26 = 8
    GreenSegment27 = 8
    GreenSegment28 = 8
    GreenSegment29 = 8
    GreenSegment30 = 8
    GreenSegment31 = 8
    GreenSegment32 = 8
    GreenSegment33 = 8
    GreenSegment34 = 8
    GreenSegment35 = 8
    'Turn Red segments on
    TurnRedOn:
    RedSegment1 = 8
    RedSegment2 = 8
    RedSegment3 = 8
    RedSegment4 = 8
    RedSegment5 = 8
    RedSegment6 = 8
    RedSegment7 = 8
    RedSegment8 = 8
    RedSegment9 = 8
    RedSegment10 = 8
    RedSegment11 = 8
    RedSegment12 = 8
    RedSegment13 = 8
    RedSegment14 = 8
    RedSegment15 = 8
    RedSegment16 = 8
    RedSegment17 = 8
    RedSegment18 = 8
    RedSegment19 = 8
    RedSegment20 = 8
    RedSegment21 = 8
    RedSegment22 = 8
    RedSegment23 = 8
    RedSegment24 = 8
    RedSegment25 = 8
    RedSegment26 = 8
    RedSegment27 = 8
    RedSegment28 = 8
    RedSegment29 = 8
    RedSegment30 = 8
    RedSegment31 = 8
    RedSegment32 = 8
    RedSegment33 = 8
    RedSegment34 = 8
    RedSegment35 = 8
    'Green gradient 45°
    GreenGradient:
    GreenSegment1 = Phase1
    GreenSegment2 = Phase2
    GreenSegment3 = Phase3
    GreenSegment4 = Phase4
    GreenSegment5 = Phase5
    GreenSegment6 = Phase6
    GreenSegment7 = Phase3
    GreenSegment8 = Phase4
    GreenSegment9 = Phase5
    GreenSegment10 = Phase6
    GreenSegment11 = Phase7
    GreenSegment12 = Phase8
    GreenSegment13 = Phase9
    GreenSegment14 = Phase9
    GreenSegment15 = Phase10
    GreenSegment16 = Phase11
    GreenSegment17 = Phase12
    GreenSegment18 = Phase13
    GreenSegment19 = Phase14
    GreenSegment20 = Phase13
    GreenSegment21 = Phase14
    GreenSegment22 = Phase15
    GreenSegment23 = Phase16
    GreenSegment24 = Phase1
    GreenSegment25 = Phase2
    GreenSegment26 = Phase16
    GreenSegment27 = Phase1
    GreenSegment28 = Phase2
    GreenSegment29 = Phase3
    GreenSegment30 = Phase4
    GreenSegment31 = Phase4
    GreenSegment32 = Phase5
    GreenSegment33 = Phase6
    GreenSegment34 = Phase7
    GreenSegment35 = Phase8
    'Red gradient 45°
    RedGradient:
    RedSegment1 = Phase1
    RedSegment2 = Phase2
    RedSegment3 = Phase3
    RedSegment4 = Phase4
    RedSegment5 = Phase5
    RedSegment6 = Phase6
    RedSegment7 = Phase3
    RedSegment8 = Phase4
    RedSegment9 = Phase5
    RedSegment10 = Phase6
    RedSegment11 = Phase7
    RedSegment12 = Phase8
    RedSegment13 = Phase9
    RedSegment14 = Phase9
    RedSegment15 = Phase10
    RedSegment16 = Phase11
    RedSegment17 = Phase12
    RedSegment18 = Phase13
    RedSegment19 = Phase14
    RedSegment20 = Phase13
    RedSegment21 = Phase14
    RedSegment22 = Phase15
    RedSegment23 = Phase16
    RedSegment24 = Phase1
    RedSegment25 = Phase2
    RedSegment26 = Phase16
    RedSegment27 = Phase1
    RedSegment28 = Phase2
    RedSegment29 = Phase3
    RedSegment30 = Phase4
    RedSegment31 = Phase4
    RedSegment32 = Phase5
    RedSegment33 = Phase6
    RedSegment34 = Phase7
    RedSegment35 = Phase8
    'Red gradient 45° Antiphase
    RedAntiGradient:
    RedSegment1 = Phase9
    RedSegment2 = Phase10
    RedSegment3 = Phase11
    RedSegment4 = Phase12
    RedSegment5 = Phase13
    RedSegment6 = Phase14
    RedSegment7 = Phase11
    RedSegment8 = Phase12
    RedSegment9 = Phase13
    RedSegment10 = Phase14
    RedSegment11 = Phase15
    RedSegment12 = Phase16
    RedSegment13 = Phase1
    RedSegment14 = Phase1
    RedSegment15 = Phase2
    RedSegment16 = Phase3
    RedSegment17 = Phase4
    RedSegment18 = Phase5
    RedSegment19 = Phase6
    RedSegment20 = Phase5
    RedSegment21 = Phase6
    RedSegment22 = Phase7
    RedSegment23 = Phase8
    RedSegment24 = Phase9
    RedSegment25 = Phase10
    RedSegment26 = Phase8
    RedSegment27 = Phase9
    RedSegment28 = Phase10
    RedSegment29 = Phase11
    RedSegment30 = Phase12
    RedSegment31 = Phase12
    RedSegment32 = Phase13
    RedSegment33 = Phase14
    RedSegment34 = Phase15
    RedSegment35 = Phase16
    'Red gradient 45° with 1 step Antiphase
    RedShortAntiGradient:
    RedSegment1 = Phase2
    RedSegment2 = Phase3
    RedSegment3 = Phase4
    RedSegment4 = Phase5
    RedSegment5 = Phase6
    RedSegment6 = Phase7
    RedSegment7 = Phase4
    RedSegment8 = Phase5
    RedSegment9 = Phase6
    RedSegment10 = Phase7
    RedSegment11 = Phase8
    RedSegment12 = Phase9
    RedSegment13 = Phase10
    RedSegment14 = Phase10
    RedSegment15 = Phase11
    RedSegment16 = Phase12
    RedSegment17 = Phase13
    RedSegment18 = Phase14
    RedSegment19 = Phase15
    RedSegment20 = Phase14
    RedSegment21 = Phase15
    RedSegment22 = Phase16
    RedSegment24 = Phase2
    RedSegment25 = Phase3
    RedSegment27 = Phase2
    RedSegment28 = Phase3
    RedSegment29 = Phase4
    RedSegment30 = Phase5
    RedSegment31 = Phase5
    RedSegment32 = Phase6
    RedSegment33 = Phase7
    RedSegment34 = Phase8
    RedSegment35 = Phase9
    'Red gradient 45° with 2 step Antiphase
    RedMediumAntiGradient:
    RedSegment1 = Phase3
    RedSegment2 = Phase4
    RedSegment3 = Phase5
    RedSegment4 = Phase6
    RedSegment5 = Phase7
    RedSegment6 = Phase8
    RedSegment7 = Phase5
    RedSegment8 = Phase6
    RedSegment9 = Phase7
    RedSegment10 = Phase8
    RedSegment11 = Phase9
    RedSegment12 = Phase10
    RedSegment13 = Phase11
    RedSegment14 = Phase11
    RedSegment15 = Phase12
    RedSegment16 = Phase13
    RedSegment17 = Phase14
    RedSegment18 = Phase15
    RedSegment19 = Phase16
    RedSegment20 = Phase15
    RedSegment21 = Phase16
    RedSegment23 = Phase2
    RedSegment24 = Phase3
    RedSegment25 = Phase4
    RedSegment26 = Phase2
    RedSegment27 = Phase3
    RedSegment28 = Phase4
    RedSegment29 = Phase5
    RedSegment30 = Phase6
    RedSegment31 = Phase6
    RedSegment32 = Phase7
    RedSegment33 = Phase8
    RedSegment34 = Phase9
    RedSegment35 = Phase10
    'Vertical Green gradient
    VerticalGreenGradient:
    GreenSegment2 = Phase1
    GreenSegment3 = Phase1
    GreenSegment4 = Phase1
    GreenSegment5 = Phase1
    GreenSegment6 = Phase1
    GreenSegment7 = Phase2
    GreenSegment8 = Phase2
    GreenSegment9 = Phase2
    GreenSegment10 = Phase2
    GreenSegment11 = Phase2
    GreenSegment12 = Phase2
    GreenSegment13 = Phase2
    GreenSegment14 = Phase3
    GreenSegment15 = Phase3
    GreenSegment16 = Phase3
    GreenSegment17 = Phase3
    GreenSegment18 = Phase3
    GreenSegment19 = Phase3
    GreenSegment20 = Phase4
    GreenSegment21 = Phase4
    GreenSegment22 = Phase4
    GreenSegment23 = Phase4
    GreenSegment24 = Phase4
    GreenSegment25 = Phase4
    GreenSegment26 = Phase5
    GreenSegment27 = Phase5
    GreenSegment28 = Phase5
    GreenSegment29 = Phase5
    GreenSegment30 = Phase5
    GreenSegment31 = Phase6
    GreenSegment32 = Phase6
    GreenSegment34 = Phase6
    GreenSegment35 = Phase6
    'Vertical Red gradient
    VerticalRedGradient:
    RedSegment7 = Phase2
    RedSegment8 = Phase2
    RedSegment9 = Phase2
    RedSegment10 = Phase2
    RedSegment11 = Phase2
    RedSegment12 = Phase2
    RedSegment13 = Phase2
    RedSegment14 = Phase3
    RedSegment15 = Phase3
    RedSegment17 = Phase3
    RedSegment18 = Phase3
    RedSegment19 = Phase3
    RedSegment20 = Phase4
    RedSegment21 = Phase4
    RedSegment22 = Phase4
    RedSegment23 = Phase4
    RedSegment24 = Phase4
    RedSegment26 = Phase5
    RedSegment27 = Phase5
    RedSegment28 = Phase5
    RedSegment34 = Phase6
    RedSegment35 = Phase6
    'Vertical Red gradient Antiphase
    VerticalRedAntiGradient:
    RedSegment2 = Phase9
    RedSegment3 = Phase9
    RedSegment4 = Phase9
    RedSegment5 = Phase9
    RedSegment6 = Phase9
    RedSegment7 = Phase10
    RedSegment8 = Phase10
    RedSegment9 = Phase10
    RedSegment10 = Phase10
    RedSegment11 = Phase10
    RedSegment17 = Phase11
    RedSegment18 = Phase11
    RedSegment19 = Phase11
    RedSegment20 = Phase12
    RedSegment21 = Phase12
    RedSegment22 = Phase12
    RedSegment23 = Phase12
    RedSegment24 = Phase12
    RedSegment25 = Phase12
    RedSegment26 = Phase13
    RedSegment27 = Phase13
    RedSegment28 = Phase13
    RedSegment29 = Phase13
    RedSegment30 = Phase13
    RedSegment31 = Phase14
    RedSegment32 = Phase14
    RedSegment34 = Phase14
    RedSegment35 = Phase14
    'Monochromatic Green gradient
    MonoGreenGradient:
    GreenSegment7 = Phase1
    GreenSegment8 = Phase1
    GreenSegment9 = Phase1
    GreenSegment10 = Phase1
    GreenSegment11 = Phase1
    GreenSegment12 = Phase1
    GreenSegment13 = Phase1
    GreenSegment14 = Phase1
    GreenSegment25 = Phase1
    GreenSegment28 = Phase1
    GreenSegment29 = Phase1
    GreenSegment30 = Phase1
    GreenSegment31 = Phase1
    GreenSegment32 = Phase1
    GreenSegment33 = Phase1
    GreenSegment34 = Phase1
    GreenSegment35 = Phase1
    'Monochromatic Red gradient
    MonoRedGradient:
    'Monochromatic Red gradient antiphase
    MonoRedAntiGradient:
    RedSegment7 = Phase9
    RedSegment8 = Phase9
    RedSegment9 = Phase9
    RedSegment10 = Phase9
    RedSegment15 = Phase9
    RedSegment16 = Phase9
    RedSegment17 = Phase9
    RedSegment18 = Phase9
    RedSegment19 = Phase9
    RedSegment20 = Phase9
    RedSegment21 = Phase9
    RedSegment22 = Phase9
    RedSegment23 = Phase9
    RedSegment25 = Phase9
    RedSegment26 = Phase9
    RedSegment28 = Phase9
    RedSegment29 = Phase9
    RedSegment30 = Phase9
    RedSegment31 = Phase9
    RedSegment32 = Phase9
    RedSegment33 = Phase9
    'Button Interrupt Handler
    ButtonInterrupt:
    @ INT_DISABLE  INT_INT ; disable Button interrupts
    GOSUB TurnAllOff
    GOSUB DisplayLoop
    REPEAT
        PAUSE 100
        ButtonCounter = ButtonCounter + 1
    UNTIL PushButton = 1 OR ButtonCounter = 10
    IF ButtonCounter >= 10 THEN
        StoredAnimationSpeed = StoredAnimationSpeed + 1
        IF StoredAnimationSpeed > 12 THEN StoredAnimationSpeed = 0
        WRITE 1, StoredAnimationSpeed
        WRITE 0, AnimationStyle
    ButtonCounter = 0
    SpeedCounter = 255
    @ INT_ENABLE  INT_INT ; enable Button interrupts
    @ INT_RETURN
