Silly little LED flasher
Results 1 to 3 of 3
    Sep 2005
    Campbell, CA
    Default Silly little LED flasher
    I don't know why anyone else might need this, but who knows?
    I needed a warning LED to light up when there was a problem, and I needed to indicate the nature of the problem with the number of flashes. I couldn't just let the program sit around while it flashed, I needed it to run in the background.
    And since people who count flashes expect nice, even-spaced flashes, I couldn't just rely on program loops (at least in my case, where some loops take longer than others).
    So here is the result. I uses Timer 1 to flash a led at a 1 Hz rate. Just give the variable "MakeFlash" a number, and it will flash ON that many times, then hold the LED ON for 5 periods, and start all over again. If you clear MakeFlash, the flashing stops.
    Since it is interrupt-driven, it runs entirely in the background.
    Let us hope it formats better on the forum than it does on my screen.
    Warn           VAR PORTD.5
    MakeFlash      VAR BYTE
    DoFlash        VAR BYTE
    CounterF       VAR WORD
    T1Counter      VAR BYTE
    FlashFlag      VAR BIT
    WaitCounter    VAR BYTE
    InFlashRoutine VAR BIT
    CR             CON 13
    LF             CON 10
    ONN            CON 1
    OFFF           CON 0
    CounterF =0
    T1Counter = 0
    FlashFlag = 0
    WaitCounter = 0
    inFlashRoutine = 0
        INCLUDE "DT_INTS-18.bas"         ; Base Interrupt System
        INCLUDE "ReEnterPBP-18.bas"     ; Include if using PBP interrupts
    INT_LIST  macro        ; IntSource,    Label,  Type, ResetFlag?
              INT_Handler    TMR1_INT,  _FlashLEDs, PBP,   yes
    INT_CREATE
    GOTO OverInt
    FlashLEDs:
       PIR1.0 = 0 ; Clear INT flag
       IF !InFlashRoutine THEN
          IF MakeFlash THEN
             DoFlash = MakeFlash + 1    ; Transfer contents to working varible that the INT can change
             InFlashRoutine = 1         ; Let system know that we are actively flashing now.
             ; The MakeFlash "+1" is used if you don't count the HOLD time as a flash
             Warn = OFFF
       T1Counter = T1Counter + 1      ; Effectively divides interrupt period by 10
       IF T1Counter < 10 THEN GOTO EndRoutine
       T1Counter = 0  ; Clear interrupt counter
       IF DoFlash > 0 THEN         ; Should we still be flashing?
           FlashFlag = 1             ; Set once we enter routine so we know we were previously flashing
           IF Warn = OFFF THEN
               Warn = ONN
               DoFlash = DoFlash - 1  ; Keep track of the times we have flashed
               GOTO EndRoutine
               Warn = OFFF        ; Turn it off
            IF FlashFlag = 1 THEN     ; When we are done flashing, we need to hold the LED ON for a period
                                      ; so mere mortals can determint the difference
                Warn = ONN
                WaitCounter = WaitCounter + 1
                IF WaitCounter > 5 THEN
                    FlashFlag = 0
                    WaitCounter = 0
                    InFlashRoutine = 0
                WaitCounter = 0    ; Just to make certain it gets cleared
    EndRoutine:
    @ INT_ENABLE TMR1_INT
    @ INT_RETURN
    OverInt:
       HSEROUT ["Hello World"]
       TMR1H = 0
       TMR1L = 0
       PIR1.0 = 0
       T1CON = %00110001  ; Turns it on, /8 prescaler, load 8 bits at a time
       MakeFlash = 5 ;   Just for test
    Top:
         PAUSE 20000
         MakeFlash = 0
         GOTO Top
    Charles Linquist
    Default Re: Silly little LED flasher
    Nice job Charles.
    Apr 2003
    Cambridge - UK
    Published in the code examples section, thank you for taking time to post this code example.
    http://www.picbasic.co.uk/forum/cont...le-LED-flasher
