A less Cumbersome way of manipulating several LEDS?
Results 1 to 16 of 16
    Mar 2009
    Default A less Cumbersome way of manipulating several LEDS?
    Hi all,
    I seek an easier way of controlling leds!
    At the minute, due to my restrictive board layout, I've several leds scattered across all the PIC's port/pins, for example...
    LED0  VAR    PortC.6
    LED1  VAR    PortB.6
    LED2  VAR    PortB.5
    LED3  VAR    PortB.4
    LED4  VAR    PortC.2
    LED5  VAR    PortC.1
    LED6  VAR    PortC.0
    LED7  VAR    PortA.2
    LED8  VAR    PortA.1
    at the minute, to say switch some leds on/off, I'm doing something like this.
    high led0
    high led1
    low  led2
    low  led3
    high led4
    ...which ok isn't too bad, but gets rather long winded - especially when you want a few different permutations.
    Forgive the naive line of questioning, but is there anyway, I can group the 'port diverse' LED mappings all together into something like a virtual Port (or logical byte/word), where I could for example do something like this....
    LEDs = %00010011
    if so, bear in mind I have 9 LEDs ...how would that work out with the above in mind?!
    In a similar vein, can I group just two specific leds together for ease of handling? (I always will want two specific LEDS to light/extinguish together - but want to treat them as one entity vs having to duplicate the commands to each port/pin per LED)
    Many thanks!
    Default Virtual Ports
    LEDs  VAR WORD
    INCLUDE "VirtualPort.bas"
    MyPortPins  macro               ; these define which bits go with which pins
        Vpin   0, PORTC,6
        Vpin   1, PORTB,6
        Vpin   2, PORTB,5
        Vpin   3, PORTB,4
        Vpin   4, PORTC,2
        Vpin   5, PORTC,1
        Vpin   6, PORTC,0
        Vpin   7, PORTA,2
        Vpin   8, PORTA,1
    Init:
    @   OutputPort  MyPortPins             ; Set Pins to Output
        LEDs = %000010011
    @   WritePort  _LEDs, MyPortPins
        PAUSE 1000
        LEDs = 0
        LEDs = LEDs + 1
        @  WritePort  _LEDs, MyPortPins    ; write pattern to Virtual Port
        PAUSE 250
    GOTO Main
    I haven't tried it on the 16F1's, but I think it should work.
    The VirtualPort.bas file is in this thread ... http://www.picbasic.co.uk/forum/show...3158#post83158
    Like 80% of everything I've done in this forum, the post got destroyed. But the file's still there.
    Mar 2009
    Default Re: Virtual Ports
    Excellent Darrel - many thanks....does it add much in the way of delay? (ie if I was sequencing 8 leds fast would this start slowing stuff up)
    Default Re: A less Cumbersome way of manipulating several LEDS?
    how fast human eye is btw? vport is nowhere near to be that slow
    Quote Originally Posted by HankMcSpank View Post
    VirtualPort will be faster than using lists of HIGH/LOW since it doesn't set the TRIS bits each and every time.
    That in itself may be a problem when running at 32Mhz and the old R-M-W issue may come into play.
    Let me know if it does and I'll change it to use the LAT registers on the 16F1's.
    The pin list macro can have multiple pins assigned to each bit.
    In this example both RC6 and RB3 would turn on and off according to bit0 of the value passed to WritePort.
        Vpin   0, PORTC,6
        Vpin   0, PORTB,3
        Vpin   1, PORTB,6
        Vpin   2, PORTB,5
    Mar 2009
    Hi Darrel,
    That's fantastic (ie two pins handled as one virtual pin...I'm figuring that the maximum number of Virtual Port bits is 8? if so, wouldn't you just know that I have 9 LEDs!)
    re VirtualPort and the TRISC settings ...hmm, maybe I can't use your funky routine after all - one thing I observed when using the HIGH/LOW command, was excessive audible clicking attributed to the port.pin switching state (I work with low level guitar signals, which often pass in close proximity to a PIC, guitar signals often get treated with enormous gain so I'm perhaps more aware/sensitive to such clicks than others!) The only way I was able to stop such clicking was to to use TRISC command instead of the high/low command, for example, this would result in clicking....
    TRISC.6 = 0
    HIGH PORTC.6
    whereas this doesn't...
    PortC.6 = 1
    TRISC.6 = 0
    ....whacky. (so to turn an LED on/off, I don't use high/low, but just set the pin as output or input)
    Why not wire them in "anti-parallel" then? One is on when pin is low, the other when pin is high and both are off when TRIS is 1.
    Mar 2009
    Because I need them to light up together....if I'm reading your suggestion correctly, only one LED can be on at a time?
    Sorry, I misunderstood that. I thought you wanted one on when the other was off. I guess I kind of took that for granted because I can't really see the point in using more than one pin. Just wire the LEDs in parallel or, which is probably better, in series. Depends on the powersupply voltage and forward voltage drop of the particular LED.
    Are these some high power blue LEDs? High current and high Vf? Is that the reason you need one pin for each LED? Please tell me what I'm missing :-)
    Mar 2009
    Yes, I'm using high brightness blue leds (fwd voltage 3.2V, my PSU is 4V) in parallel drawing about 20mA, therefore two = 40ma...too much for one PIC pin...hence wanting to treat two pins as one virtual pin in code. But it's no big deal....thought I'd ask - and as ever there is something that exists that can be brought into play, except that I need to control the pin on/off via TRISC to avoid clicking so I can't personally use it.
    Maybe something like this? Not very swanky, but should work.
    LED VAR WORD
    LED = %XXXXX111111111 'ALL LEDS ON
    GOSUB LED_OUT
    LED = %XXXXX000000000 'ALL LEDS OFF
    GOSUB LED_OUT
    Goto Main
    LED_OUT:
    PORTC.6 = LED.0
    PORTB.6 = LED.1
    PORTB.5 = LED.2
    PORTB.4 = LED.3
    PORTC.2 = LED.4
    PORTC.1 = LED.5
    PORTC.0 = LED.6
    PORTA.2 = LED.7
    PORTA.1 = LED.8
    Jan 2006
    Istanbul
    Since you are driving LEDs, why not MIBAM ?
    Mar 2009
    Quote Originally Posted by sayzer View Post
    I have a common dim function in place already (via a PWM driven mosfet)...I don't really need dimming per pin
    Mar 2009
    Hi Mark, Apologies...I missed your earlier contribution...that looks like something along the lines of what I need...I'll give it a try over the weekend - many thanks!
    Oct 2009
    Utah, USA
    You probably realize this... but you will need a pause, of some time delay, after each "GOSUB LED_OUT", in Mark's example. In order for your eye to see the LED's ON or OFF or they may just appear to be flickering at half brighteness.
    Also the "X's" in the example will not compile... need to use "0's". At least they don't compile using microcodestudio.
    LED VAR WORD
    LED = %0000000111111111 'ALL LEDS ON
    GOSUB LED_OUT
    PAUSE 500 'or delay of your choosing
    LED = %0000000000000000 'ALL LEDS OFF
    GOSUB LED_OUT
    PAUSE 1000 'or delay of your choosing
    Goto Main
    LED_OUT:
    PORTC.6 = LED.0
    PORTB.6 = LED.1
    PORTB.5 = LED.2
    PORTB.4 = LED.3
    PORTC.2 = LED.4
    PORTC.1 = LED.5
    PORTC.0 = LED.6
    PORTA.2 = LED.7
    PORTA.1 = LED.8
    good luck!!
    Dwight
    Heckler, you are right on all accounts.
    In the digital world "X" means "don't care". A 1 or 0 will not cause a state change.
    Sorry for the confusion. In PBP you can drop the leading zeros in a binary variable.
    This %000000111111111 would equal %111111111.
    Best regards
