Quick and dirty candle effect with PIC12F675
Results 1 to 3 of 3
    Aug 2011
    Guadalajara, México
    Default Quick and dirty candle effect with PIC12F675
    For best results use a clear amber LED, you can embbed the LED using a tube as cast and pouring molten parafin...
    '*  Name    : RGB12F675                                         *
    '*  Author  : Ivan Rosales, Guadalajara México                  *
    '*  Notice  : Copyright (c) 2011 Ivan Rosales                   *
    '*  Date    : 31/08/2011                                        *
    '*  Notes   : Efecto de Vela en Pin 5 (GP2)                     *
    '*          : Utilizar preferentemente LED Ambar                *
    @ Device PIC12F675,WDT_ON,PWRT_ON,PROTECT_OFF,MCLR_OFF,BOD_OFF
    ansel=0             'No usar ADC's las entradas serán digitales
    cmcon=7             'No usar comparadores analógicos
    trisio=%001011      'GP2 Será salida
    DEFINE OSCCAL_1K 1  'Auto-Calibración del reloj interno
    'Definiciones
    Vela var GPIO.2
    Luz var byte
    X var byte
    Ciclos con 25
    'Programa
    Pral:
    random luz
    luz=luz//(255-ciclos)
    if luz<120 then luz=luz+50
    for x=1 to ciclos
    pwm vela, luz+x, 1
    next
    goto pral
    Apr 2003
    Cambridge - UK
    Default Re: Quick and dirty candle effect with PIC12F675
    Thanks for your code example. It would be great if you could include a schematic. Because there is no shematic i cant put this in the User Projects section, but i have put the code example in the wiki here
    Thank you for your contribution
    Aug 2011
    Guadalajara, México
    The schematic could not be more simple
    As an alternative you can omit the switch and use an old USB cable to provide the the 5vdc (usually RED cable) and the Ground (usually BLACK cable) this way you can have a romantic companion for your computer...
    5vdc (Vdd)
        +          PIC12F675
        |    _/       ___
        '--o/  o----o|°  |o------------------.
                   -o|   |o-  Amber (Clear)  |
                   -o|   |o-     LED         |
                   -o|___|o------>|----------o
                                           GND
