I2C and multiple slave
Results 1 to 7 of 7
    Zorglub's Avatar
    Zorglub Guest
    Question I2C and multiple slave
    I have multiple applications with the 16F87.
    I would like to connect all these applications together with the I2C bus with 1 master (16F877) and all the slaves (16F87).
    How can I address the slaves independently ?
    Best regards
    Feb 2004
    Germany
    Zorglub,
    based on the information you have given the answer is:
    By simply assigning the slaves address in the I2CWRITE / I2CREAD command.
    Please see also THIS
    regards
    Ralph
    PICBasic only supports I2C Master mode for the Master PIC... you will have to write your own routines for the Slave Mode PICs.
    Feb 2004
    Germany
    Mel,
    based on the information given one could assume he already has written the slave routines.
    regards
    Ralph
    Well in that case addressing is the easiest part of all. Just assign some spare pins on the Slave PICs, ground some, and pull others up to V+ and they become the unique address for that PIC. That way, all your Slave PIC software remains the same, and when that PIC powers-up it determines it's own address. Thereafter, the Master just addresses the PICs as if they were standard I2C devices. Nothing could be simpler at that point.
    Zorglub's Avatar
    Zorglub Guest
    Smile
    Thank you,
    Is the following another solution ? in the datasheet 16F87 :
    Register SSPSR and SSPADD for chip addressing ????
    Best regards
    Italy
    Hi!
    Maybe these links will help you.
    (Search with Google for more).
    Microchip Application Note AN734:
    Using the PICmicro SSP for Slave I2C Communication
    http://www.microchip.com/stellent/id...pnote=en011798
    Picbasic Pro project for Slave I2C Communication:
    http://www.astrosurf.com/soubie/pic_as_an_i2c_slave.htm
    (See Microchip application note AN734 has errors).
    Luciano
  1. 4 bit address decoding I2C chip
    By ecoli-557 in forum General
    Last Post: - 10th June 2008, 18:26
  2. Multiple Pics accessing single EEPROM
    By Atom058 in forum mel PIC BASIC Pro
    Last Post: - 3rd February 2008, 18:22
  3. Multiple PIC talking to same I2C device
    By GrandPa in forum mel PIC BASIC Pro
    Last Post: - 7th October 2007, 01:28
  4. More I2C question with PBP
    By Qacer in forum mel PIC BASIC Pro
    Last Post: - 2nd March 2006, 22:35
  5. ds1307 from f877 to f452 not work
    By microkam in forum mel PIC BASIC Pro
    Last Post: - 7th July 2005, 01:02
