Serial UART and Interupts on a 16F87X
Results 1 to 14 of 14
    Default Re: Serial UART and Interupts on a 16F87X
    Ok probably I am wrong again:
    DISABLE
    RECEIVE:
    I think Disable should go inside this sub directory
    like
    RECEIVE:
    DISABLE
    Cause if you goto receive then do not you sail past the disable?
    Also you have if then loops for condition 1:6,
    where does it go if NOT 1:6?
    WW6PAC
    Aug 2011
    If it is not 1 thru 6 then it loops back to the start. I will look at this again in the AM as I start work early.
    I put an ENABLE after the RESUME. Does that in itself not restart the checking for an interupt? But maybe I need a GOTO loop just after that. I noticed I missed a goto loop just after the ENABLE. Looks like it has no where to go! Maybe that is what I missed.
    DO I need to set the option reg for a rising edge for the incomming serial?
    Scott
    Aug 2011
    I also agree that the disable goes inside, but all the code I see eaxamples of always put it just before the subroutine, so that is what I did.
    Aug 2010
    Maryland, USA
    Ok maybe a better way for me to explain is this:
    Think about the ISR as a subroutine. As such it MUST be returned from. In the case of ON INTERRUPT, this is the RESUME statement. But in your case you jump past the resume with the GOTO's in the ISR. I don't know if the interrupt get re-enabled, but I don't think so because of this. You have 2 choices IMHO.
    1. make all the goto's gosub's in the IF's, then change the GOTO loop in each RELAY action to return.
    2 This is my favorite:
    Loop:
    HSEROUT stuff
    IF Relay > 0 then
       If relay = 1 then outr1
       If relay = 2 then outr2
       If ....
    Endif
    Then in each outr routine, set relay = 0 before you goto loop.
    Last thing, Don't use loop for a label. It is reserved in later releases of PBP.
    -Bert
    I never use ON INTERRUPT so I don't know if you have to clear the interrupt flag before resuming (the USART flag clears itself when reading the RXREG but the interruptflag). Apart from that I think Bert is on it. You get to the interrupt, then you GOTO one of the Outx routines and then you END....
    ENABLE/DISABLE are not normal "PBP commands" that executes at runtime. They are directives to the compiler to tell it where to start/stop inserting commands to poll the interrupt flag. In this case it doesn't matter if you put ENABLE before or after the Receive: label since ENABLE is not a command that executes at runtime.
    Aug 2011
    Ok, I made the following changes and it is not responding to any data now. It does continue to send data, just won't receive.
    Also the code from the PC sets the corosponding relay back to 0 at the end of the command.
    Example TX 2,1 then TX 2,0 meaning relay 2 HIGH then relay 2 LOW. Relays 3 thru 6 are latching and are unlatched when a differint relay is selected. Only relays 1 and 2 are momentary.
    Intersting thing is I had this working great when connecting to a PC directly using COM Port with OUT interupts. I was using RTS/CTS but now that I am going thru a LAN to serial adapter it does not behave the same. I just recently added a RS-232 level converter that has a MAX232 of some flavor on board, so maybe I'll give the RTS/CTS deal a try again. I would love to get a handle on this interupt thing though so I can grow my PIC projects!
    I also took out the wait statement, because I understand the UART can only grab 2 bytes at a time. Changed loop to MAIN.
    Thanks for the info on ENABLE/DISABLE. It is for the compiler! I'll keep grinding away here.
    on interrupt goto RECEIVE
    MAIN:
    TRANSMIT:
    ADCIN 0, POTADC 'convert ADC value to a byte value:
    HSEROUT [DEC POTADC,32] 'TX DATA on PORTC.6
    PAUSE 300
    GOTO MAIN
    DISABLE
    RECEIVE:
    IF (RCSTA.2=1) THEN
    HSERIN [RXBYTE]
    HSERIN 500,TRANSMIT,[relay,stat] 'Serial data in on PortC.7
    IF relay = 1 THEN GOSUB outr1 ' Process relay#1 routine
    IF relay = 2 THEN GOSUB outr2 ' Process relay#2 routine
    IF relay = 3 THEN GOSUB outr3 ' Process relay#3 routine
    IF relay = 4 THEN GOSUB outr4 ' Process relay#4 routine
    IF relay = 5 THEN GOSUB outr5 ' Process relay#5 routine
    IF relay = 6 THEN GOSUB outr6 ' Process relay#6 routine
    RESUME
    ENABLE
    GOTO MAIN
    '***************** DRIVE RELAYS ******************************************
    outr1:
    IF stat = 1 THEN high1
    LOW CW: RETURN
    high1:
    HIGH CW: RETURN ' Turn on CW Relay
    outr2:
    IF stat = 1 THEN high2
    LOW CCW: RETURN
    high2:
    HIGH CCW: RETURN ' Turn on CCW Relay
    outr3:
    IF stat = 1 THEN
    HIGH ANT1: LOW ANT2: LOW ANT3: LOW ANT4
    RETURN ' Turn On Relay for Antenna 1
    outr4:
    IF stat = 1 THEN
    HIGH ANT2: LOW ANT1: LOW ANT3: LOW ANT4
    RETURN ' Turn On Relay for Antenna 2
    outr5:
    IF stat = 1 THEN
    HIGH ANT3: LOW ANT1: LOW ANT2: LOW ANT4
    RETURN ' Turn On Relay for Antenna 3
    outr6:
    IF stat = 1 THEN
    HIGH ANT4: LOW ANT1: LOW ANT2: LOW ANT3
    RETURN ' Turn On Relay for Antenna 4
    Here's a untested/simplfied version that should work. Compare it to your original to see the changes.
    DEFINE OSC 4 ' 4 MHz clock
    DEFINE ADC_BITS 10 ' Set number of bits in result
    DEFINE ADC_CLOCK 3 ' Set clock source (3=rc)
    DEFINE ADC_SAMPLEUS 20 ' Set sampling time in uS
    DEFINE HSER_SPBRG 25 ' 2400 Baud @ 4MHz, 0.17%
    TRISA = %000001     ' Set PORTA
    TRISB = %01100000   ' Set PORTB
    TRISC = %10000000   ' Set PORTC
    ADCON1 = %10001110  ' RA0 A/D input. +Vref=Vdd, -Vref=Vss. Right justified for 10-bit
    INTCON = %11000000  ' Global & peripheral ints enabled. Not RB0/INT
    PIE1 = %00100000
    '**************** DEFINE VARIABLES ***************************************
    relay VAR BYTE 'relay number storage variable
    stat VAR BYTE 'relay status ON/OFF variable
    POTADC VAR WORD 'ADC Result
    RXBYTE var byte
    '**************** PORT B Setup *******************************************
    ANT4 VAR PORTB.3 'ANT4 Relay
    ANT3 VAR PORTB.2 'ANT3 Relay
    ANT2 VAR PORTB.1 'ANT2 Relay
    ANT1 VAR PORTB.0 'ANT1 Relay
    '**************** PORT C Setup *******************************************
    CCW VAR PORTC.5 'CCW Relay
    CW VAR PORTC.4 'CW Relay
    '****************** PORT SETUP *******************************************
    CW=0 ' CW Relay Off
    CCW=0 ' CCw Relay Off
    ANT1=0
    ANT2=0
    ANT3=0
    ANT4=0
    ADCON0=0 ' Set up ADCON1
    ON INTERRUPT GOTO RECEIVE
    MAIN:
      PAUSE 300
      GOTO MAIN
    DISABLE  ' <-- doesn't matter if DISABLE is before or after the label
             ' just as long as it's before any CODE.
    RECEIVE:
      IF RCSTA.2=1 THEN
         HSERIN [RXBYTE]
         HSERIN 500,IntExit,[relay,stat] 'Serial data in on PortC.7
      ' Simplified version without gosubs, gotos, etc.
      IF relay = 1 THEN CW = Stat.0       ' Process relay#1
      IF relay = 2 THEN CCW = Stat.0      ' Process relay#2
      IF relay = 3 THEN PORTB = %00000001 ' Process relay#3
      IF relay = 4 THEN PORTB = %00000010 ' Process relay#4
      IF relay = 5 THEN PORTB = %00000100 ' Process relay#5
      IF relay = 6 THEN PORTB = %00001000 ' Process relay#6
    IntExit:
      RESUME
      ENABLE ' <-- You only need ENABLE if you place more code below
             ' it and you want interrupt checking code there.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
