Serial UART and Interupts on a 16F87X
Results 1 to 14 of 14
    Aug 2011
    Default Serial UART and Interupts on a 16F87X
    I have been trying to get interupts to work for a few days now. I kind of understand them but seem to have a sticking point somewhere. Maybe the "OPTION" register. Not sure. Been all over the net reading. This seems to be quite common. Anyway can someone help. I have been using PB PRO for a while but not for bidirectional RS-232.
    I am simply trying to engage 6 relays based on commands. Then while not doing that continuosly send data back down to a PC. When serial command arrives, act on it. Below is my code.
    Thanks. Scott.C.
    '* Name : Antenna_ROTOR.BAS *
    '* Date : 5/23/2011 *
    '* Version : 1.0 *
    '* Notes : PIC 16F873A *
    '* Notes : Pin Outs are as follows
    '* MCLR ******1 28*****
    '* Position Sense ******2 27*****
    '* ******3 26***** CTS (FUTURE)
    '* ******4 25***** RTS (FUTURE)
    '* ******5 24***** ANT 4
    '* ******6 23***** ANT 3
    '* ******7 22***** ANT 2
    '* GND ******8 21***** ANT 1
    '* CLK ******9 20***** +5VDC
    '* *****10 19***** GND
    '* *****11 18***** RS-232 RX
    '* *****12 17***** RS-232 TX
    '* *****13 16***** C-CW RELAY
    '* *****14 15***** CW RELAY
    '* Notes : Interface between Alliance HD-73 rotor and PC Serial Port
    '* : 2400 8, N, 1
    '* : Provides constant rotor position, status feedback
    '* : Responds to serial commands to move rotor CW or CCW via 2 relays
    DEFINE OSC 4 ' 4 MHz clock
    DEFINE ADC_BITS 10 ' Set number of bits in result
    DEFINE ADC_CLOCK 3 ' Set clock source (3=rc)
    DEFINE ADC_SAMPLEUS 20 ' Set sampling time in uS
    DEFINE HSER_SPBRG 25 ' 2400 Baud @ 4MHz, 0.17%
    TRISA = %000001 ' Set PORTA
    TRISB = %01100000 ' Set PORTB
    TRISC = %10000000 ' Set PORTC
    INTCON = %10010000
    PIE1 = %00100000
    '**************** DEFINE VARIABLES ***************************************
    relay VAR BYTE 'relay number storage variable
    stat VAR BYTE 'relay status ON/OFF variable
    POTADC VAR WORD 'ADC Result
    RXBYTE var byte
    '**************** PORT B Setup *******************************************
    ANT4 VAR PORTB.3 'ANT4 Relay
    ANT3 VAR PORTB.2 'ANT3 Relay
    ANT2 VAR PORTB.1 'ANT2 Relay
    ANT1 VAR PORTB.0 'ANT1 Relay
    '**************** PORT C Setup *******************************************
    CCW VAR PORTC.5 'CCW Relay
    CW VAR PORTC.4 'CW Relay
    '****************** PORT SETUP *******************************************
    CW=0 ' CW Relay Off
    CCW=0 ' CCw Relay Off
    ANT1=0
    ANT2=0
    ANT3=0
    ANT4=0
    ADCON0=0 ' Set up ADCON1
    '***************** Main Program ******************************************
    on interrupt goto RECEIVE
    LOOP:
    TRANSMIT:
    ADCIN 0, POTADC 'convert ADC value to a byte value:
    HSEROUT [DEC POTADC,32] 'TX DATA on PORTC.6
    PAUSE 50
    GOTO loop
    DISABLE
    RECEIVE:
    IF (RCSTA.2=1) THEN
    HSERIN [RXBYTE]
    HSERIN 500,TRANSMIT,[WAIT(254),relay,stat] 'serial data in on Portc.7
    IF relay = 1 THEN outr1 ' if relay#1 then goto relay#1 routine
    IF relay = 2 THEN outr2 ' if relay#2 then goto relay#2 routine
    IF relay = 3 THEN outr3 ' if relay#3 then goto relay#3 routine
    IF relay = 4 THEN outr4 ' if relay#4 then goto relay#4 routine
    IF relay = 5 THEN outr5 ' if relay#5 then goto relay#5 routine
    IF relay = 6 THEN outr6 ' if relay#6 then goto relay#6 routine
    RESUME
    ENABLE
    '***************** DRIVE RELAYS ******************************************
    outr1:
    IF stat = 1 THEN high1
    LOW CW: GOTO LOOP
    high1:
    HIGH CW: GOTO loop ' Turn on CW Relay
    outr2:
    IF stat = 1 THEN high2
    LOW CCW: GOTO loop
    high2:
    HIGH CCW: GOTO loop ' Turn on CCW Relay
    outr3:
    IF stat = 1 THEN
    HIGH ANT1: LOW ANT2: LOW ANT3: LOW ANT4
    GOTO loop ' Turn On Relay for Antenna 1
    outr4:
    IF stat = 1 THEN
    HIGH ANT2: LOW ANT1: LOW ANT3: LOW ANT4
    GOTO loop ' Turn On Relay for Antenna 2
    outr5:
    IF stat = 1 THEN
    HIGH ANT3: LOW ANT1: LOW ANT2: LOW ANT4
    GOTO loop ' Turn On Relay for Antenna 3
    outr6:
    IF stat = 1 THEN
    HIGH ANT4: LOW ANT1: LOW ANT2: LOW ANT3
    GOTO loop ' Turn On Relay for Antenna 4
    Aug 2010
    Maryland, USA
    Default Re: Serial UART and Interupts on a 16F87X
    In your isr you check for relay =1..6. Then you GOTO a routine to turn the proper relay on. Then from there you GOTO back to loop.
    Isr is never re-enabled. Plus you goto out of your isr sub routine so there is no way to get back and properly return.
    That's my thoughts.
    -Bert
    Ok probably I am wrong again:
    DISABLE
    RECEIVE:
    I think Disable should go inside this sub directory
    like
    RECEIVE:
    DISABLE
    Cause if you goto receive then do not you sail past the disable?
    Also you have if then loops for condition 1:6,
    where does it go if NOT 1:6?
    WW6PAC
    Aug 2011
    If it is not 1 thru 6 then it loops back to the start. I will look at this again in the AM as I start work early.
    I put an ENABLE after the RESUME. Does that in itself not restart the checking for an interupt? But maybe I need a GOTO loop just after that. I noticed I missed a goto loop just after the ENABLE. Looks like it has no where to go! Maybe that is what I missed.
    DO I need to set the option reg for a rising edge for the incomming serial?
    Scott
    Aug 2011
    I also agree that the disable goes inside, but all the code I see eaxamples of always put it just before the subroutine, so that is what I did.
    Aug 2010
    Maryland, USA
    Ok maybe a better way for me to explain is this:
    Think about the ISR as a subroutine. As such it MUST be returned from. In the case of ON INTERRUPT, this is the RESUME statement. But in your case you jump past the resume with the GOTO's in the ISR. I don't know if the interrupt get re-enabled, but I don't think so because of this. You have 2 choices IMHO.
    1. make all the goto's gosub's in the IF's, then change the GOTO loop in each RELAY action to return.
    2 This is my favorite:
    Loop:
    HSEROUT stuff
    IF Relay > 0 then
       If relay = 1 then outr1
       If relay = 2 then outr2
       If ....
    Endif
    Then in each outr routine, set relay = 0 before you goto loop.
    Last thing, Don't use loop for a label. It is reserved in later releases of PBP.
    -Bert
