concatenating 4 bytes into one pseudo 32 bit counter?
Results 1 to 12 of 12
    Mar 2009
    Default concatenating 4 bytes into one pseudo 32 bit counter?
    So having read up about DDS to get sufficient frequency accuracy, it seems most people typically use a 24 bit or 32 bit accumuator.
    Every interrupt a fixed number/value is added to the number held in the accumulator - the accumulator is basically a 32 bit counter.
    Can this be kludged in picbasic - concatenate 4 bytes into one 'pretend' 32 bit counter - then add a fixed value to it everytime an interrupt happens?
    Here's what one guy does in his assembly interrupt routine for a 16f628 PIC (original source - http://www.g4jnt.com/PIC_DDS.zip )...
    ints   ;Using  divide by  prescalar,  Interupt service runs at at Fosc / 200
       ; when set to count 25 before overflowing, ie  every 50 clocks = sampling rate
          bcf     INTCON , T0IF   ;reset the interrupt flag
            bsf TESTSTRB        ;Spare instruction needed to make up 8 clocks total, up to the point of reloading TMR0
        ;So use it to pulse a test point
            movlw   d'235'          ; Load in value to count up to 256 FROM (= NNN)
            movwf   TMR0            ;Timer restarts counting 2 cycles after here.
                                    ;Up to this point takes 8 clocks from Interrupt trigger
                                    ;So NNN = 256 - [Wanted count] + 8 / Prescale
        ;  ie =   256 - 25 + 8 / 2 = 235
     ;Below here is not time-critical, but must be less than than about 42 clocks total
     ;   so the whole interrupt takes < 50 clocks and doesn't overrun.
     movf D3, W  ;First output the D/A value from the LAST pass though so there is
     call SineTable ;   no jittering due to variable timing of the addition routine
     movwf PORTB
     movf F0, W  ;Now add the frequency data stored in F3/2/1/0 to D3/2/1/0
     addwf D0
     btfss STATUS, C ;Add lowest order byte and check for and carry at each stage
     goto Add1Done ;  that could ripple right through to MS byte
     incf D1
     btfsc STATUS, Z
     incf D2
     btfsc STATUS, Z
     incf D3
    Add1Done
     movf F1, W  ;Add the next byte
     addwf D1
     btfss STATUS, C
     goto Add2Done
     incf D2
     btfsc STATUS, Z
     incf D3
    Add2Done
     movf F2, W  ;... and the next
     addwf D2
     btfsc STATUS, C
     incf D3
     movf F3, W  ;MS Byte now added in.  If it has overflowed, its is exactly what we want
     addwf D3  ;D0-3 are now updated ready for next pass through, with D3 only sent to D/A converter.
    OutInt
     bcf TESTSTRB ;Reset the Test Point
     retfie   ;This  interrupt takes a max of 35 clocks for worst case addition, so does leave
        ;  a bit of scope for extra tasks or faster sampling.
    ....it doesn't mean a lot to me, but the gist of it seems to be add the fixed number to the lowest byte, then when that byte fills up, add a 'carry bit' to the second byte of the four ....rinse repeat until the the whole 32 bits are full, then start again from zero.
    If it can be donekludged in Picbasic, would anyone be gracious enough to get me started?!!
    If it can't be done, I guess I could try and work out what bits of his code to put in PICBasic ASM interrupt plus other supporting code! (that'll be me gone for a few months!)
    Mar 2009
    Default Re: concatenating 4 bytes into one pseudo 32 bit counter?
    Straying off a little here, on my journey towards having accurate sine waves under precise frequency control, here's the 16f1828's 5 bit DAC pin outputting a sawtooth - won't win any fidelity awards, but very simple to do at least!..
    Sep 2009
    Why not use LONG variable? PBP will do everything for you.
    Before LONG I use something like this
    A var byte
    B var byte
    C var byte
    etc
    GOTO main
    Init: ' start value of each byte
    A=0
    B=0
    etc...
    Inc:
    A=A+1
    IF A=0 THEN
      B=B+1
      IF B=0 THEN
       C=C+1
       IF C=0 THEN
          D=D+1
    A is lowest byte, D is highest.
    A,B,C,D is 0 only on overflow, so if lowest byte overflow(IT go from 255 to 0) you need to add 1 to second byte.
    For example if you want to calculate actual value of counter you need to do it like this:
    32bitResult=D*2^24+C*2^16+B*2^8+A
    Hope that I understand what exactly you need.
    EDIT:
    Sorry for long, you use 16F. I didn't use 16F since LONG variable is added to PBP...
    Mar 2009
    Excellent, it was this bit that is all I needed...
    Inc:
    A=A+1
    IF A=0 THEN
      B=B+1
      IF B=0 THEN
       C=C+1
       IF C=0 THEN
          D=D+1
    obvious when you see someone else type it!
    I then just use the value of the final variable (D) as lookup towards extracting a value in a preloaded 256 byte array - great stuff, I'll have a dabble with this later - many thanks!
    Sep 2009
    I'm glad that I helped.
    I'm afraid it's not quite THAT easy :-(
    Yes, it works OK as long as the value you add to the accumulator is 1 but what about when you want to add 2? Well, then A goes 0, 2, 4, 6....252, 254, 1 which means that B won't increment.
    And what about adding a value larger than 255?
    Of course it can be done in PBP but it involves a little bit more.
    Sep 2009
    I use similar code for numbers greater then 1.
    Something like this:
    A VAR WORD
    B,C,D,Add VAR BYTE
    INC:
    A=A+Add
    IF A>255 THEN
        A=A-255
        B=B+1
        IF B=0 THEN
          C=C+1
            IF C=0 THEN
              D=D+1
    Here's a piece of code working with a 32bit accumulator, the lookuptable from the code Hank linked to and the resulting waveform plotted in Excel with addvalues of:
    1) 512500
    2) 128500
    3) 22825
    LSW  VAR WORD              ' Least significat word of accumulator
    MSW  VAR WORD              ' Most significatn word of accumulator
    ADDL VAR WORD              ' Least significant work of value to add
    ADDH VAR WORD              ' Most significant word of value to add
    Out VAR BYTE                    ' This is the actual output from the lookup table
    Temp VAR WORD
    OverFlow VAR BIT             ' Gets set when 32bit accumulator overflows.
    i VAR WORD
    Init:
      LSW = 0
      MSW = 0
      AddL = 500
      AddH = 2000   ' 50*256+500=768500
    Pause 3000
    For i = 1 to 1000
      OverFlow = 0
      TMR1H = 0
      TMR1L = 0
      Gosub Add
      Gosub GetValue
      HSEROUT["Count: ", DEC4 i, "  MSW: ", DEC5 MSW, "   LSW: ", DEC5 LSW, "   Overflow: ", BIN Overflow, "  Out: ", DEC Out, "  Ticks: ", DEC5 TMR1H*256+TMR1L, 13]
      Pause 5
    NEXT
    Add:
      T1CON = 1             ' This is just used to measure the execution time
      Temp = LSW            ' Remember least significant word
      LSW = LSW + ADDL      ' Add low word
      If LSW < Temp Then ' Did we wrap around/overflow?
        MSW = MSW + 1       ' Increment high word
        If MSW = 0 Then OverFlow = 1  ' Did we overflow high word?
      Temp = MSW            ' Remember high word
      MSW = MSW + ADDH      ' Add high word
      If MSW < Temp Then ' Did we wrap around/overflow?
        OverFlow = 1     ' Set flag
    T1CON = 0
    GetValue:
    Lookup MSW.HighBYTE, [$80,$83,$86,$89,$8C,$8F,$92,$95,$98,$9C,$9F,$A2,$A5,$A8,$AB,$AE,$B0,$B3,$B6,$B9,$BC,$BF,$C1,$C4,_
    $C7,$C9,$CC,$CE,$D1,$D3,$D5,$D8,$DA,$DC,$DE,$E0,$E2,$E4,$E6,$E8,$EA,$EC,$ED,$EF,$F0,$F2,$F3,$F5,$F6,$F7,$F8,$F9,$FA,$FB,$FC,$FC, _
    $FD,$FE,$FE,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FE,$FE,$FD,$FC,$FC,$FB,$FA,$F9,$F8,$F7,$F6,$F5,$F3,$F2,$F0,$EF,$ED,$EC, _
    $EA,$E8,$E6,$E4,$E2,$E0,$DE,$DC,$DA,$D8,$D5,$D3,$D1,$CE,$CC,$C9,$C7,$C4,$C1,$BF,$BC,$B9,$B6,$B3,$B0,$AE,$AB,$A8,$A5,$A2,$9F,$9C, _
    $98,$95,$92,$8F,$8C,$89,$86,$83,$7F,$7C,$79,$76,$73,$70,$6D,$6A,$67,$63,$60,$5D,$5A,$57,$54,$51,$4F,$4C,$49,$46,$43,$40,$3E,$3B, _
    $38,$36,$33,$31,$2E,$2C,$2A,$27,$25,$23,$21,$1F,$1D,$1B,$19,$17,$15,$13,$12,$10,$0F,$0D,$0C,$0A,$09,$08,$07,$06,$05,$04,$03,$03, _
    $02,$01,$01,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$01,$01,$02,$03,$03,$04,$05,$06,$07,$08,$09,$0A,$0C,$0D,$0F,$10,$12,$13, _
    $15,$17,$19,$1B,$1D,$1F,$21,$23,$25,$27,$2A,$2C,$2E,$31,$33,$36,$38,$3B,$3E,$40,$43,$46,$49,$4C,$4F,$51,$54,$57,$5A,$5D,$60,$63, _
    $67,$6A,$6D,$70,$73,$76,$79,$7C],Out
    The add routine works with two words instead of four bytes and takes ~86 cycles normally but 121 cycles when it overflows. Not the most effecient code for sure but it does seem to work. If you're running at 32Mhz and interrupting at 20kHz that's still 400 cycles between interrupts.
