PIC 16F877A and RB out
Results 1 to 8 of 8
    Default Re: PIC 16F877A and RB out
    There's no such thing as best method, all of them will work, the PWM one is the easiest but probably not the easiest one to predict the final value. R2R is also simple, but to get really good accuracy you need at least 1% resistor. The DAC is easy but usually not the cheaper method.
    "How much accuracy you need" is the keyword I guess.
    Forum Rule: Please, do not double post your code all over the place, I'v already reply to that in your second thread.
    Aug 2011
    I have +5 V on my jack input with car radio remote .
    So i can't use a r2r (no voltage is possible , only resistor )
    What is the method for it ?
    Regards.
    Is there a Resistor chart or voltage chart available? Case not have you tried with a potentiometer? I mean if you tie a x Resistor to Vdd (or GND) it works?
    If so, there's a thread in here made last week or so.
    Aug 2011
    Normaly, it is a resistor , i tried with resistors .
    There is already voltage in Jack female (behind radio)
    It is a voltage with r2r ,not ?
    a voltage +2v (for example) to +5v , is it right ?
    We can produce voltage with R2R or not. It really depend the way we code it. The previous link didn't but tied resistor to GND.
    You need to know which resistor value you need for each function on the radio side. And next step, do you need to tie them between the jack and GND or between the jack and VDD (5Volts). High like ln between the jack and GND. The previous link show and explain how it works.
    Next you just need to play on the remote/steering side. Follow my code, it read AN0 and AN1, then evaluate ONLY AN0 value and jump to some routines.
