RS232 serial commands
Results 1 to 16 of 16
    Default Re: RS232 serial commands
    try something like that
            DEFINE OSC 40
            DEFINE HSER_RCSTA 90h
            DEFINE HSER_TXSTA 20h
            DEFINE HSER_BAUD 9600
            DEFINE HSER_SPBRG 64
    Start:
            Hserout ["Program has started.",13,10]
            gosub LookForStart
            Goto Start
    LookForStart:
            HSERIN 5000,noData,[WAIT ("start")]
            hserout ["Got it! Backlight ON",13,10]
    nodata:
            HSEROUT ["NOPE... Life's so cruel...",13,10]
            DEFINE OSC 40
    Start:
            gosub LookForStart
            Goto Start
    LookForStart:
    nodata:
    Thanks!
    HSERIN command remind me the BUTTON command (with the label).
    So I use this :
    DEFINE OSC 40
    DEFINE LCD_DREG PORTD
    DEFINE LCD_EREG PORTB
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_EBIT 6
    DEFINE LCD_RSBIT 7
    DEFINE ADC_BITS 10
    Hserout ["Varidrive V2011.00 has started"]
    mainlp:
    LCDOUT $fe,2,"Main loop"
    HSERIN ret,[WAIT ("blon")]
           HIGH PORTD.4
    ret:
    HSERIN ret1,[WAIT ("bloff")]
           LOW PORTD.4
    ret1:
    Goto mainlp
    And it works flawlessly.
    However, when I type "blonn" instead of "blon", the backlight is activated.
    Same thing with "blofffff" instead off "bloff", the backlight is disabled.
    So I need a stop bit or something like that?
    OK, so you need to check a couple of different Strings possibilities and act upon right?
    Is this really need to be string? Did you built the "Transmitting unit" or it's just for learning purpose?
    Most common and easiest way to implement such thing is to wait for a specific header and then use the next Byte for specific command.
    ex:
    Transmitter send: "NextCommandIs", 10
    Receiver Wait for "NextCommandIs" and store 10 in a byte variable. Depending the value of that Byte Variable, it process various task.
    So Easy as
    Transmitter Side:
    HSEROUT ["NextCommandIs", 10]
    Receiver Side:
    HSERIN [WAIT ("NextCommandIs"), ByteA]
    SELECT CASE ByteA
    Should you really need to wait for a specific String, then you'll need to build a string with each single character you receive parse them. Not hard, just a tad longer to implement.
    Also, depending of how you send the whole thing, you may also check for a "end" character. If the string is right but the next character/byte is false, you discard the result.
    All the time, you want to implement a structured "serial data message" on both side.
    Here's some inspiration, not 100% efficient but easy to follow.
            DEFINE OSC 40
            WaitFor     var byte [4]
            CounterA    VAR BYTE
            clear
            Hserout ["Varidrive V2011.00 has started",13,10]
            GOSUB ClearArray
            HSEROUT ["Main loop",13,10]
            HSERIN  5000, main,[WAIT ("blo")]
            HSERIN 500, testit, [str waitFor\3]
    testit:
            SELECT CASE WaitFor[0]
                    CASE "n"
                            if WaitFor[1]=0 then
                                    HIGH PORTD.4
                                    HSEROUT ["ON",13,10]
                                        GOSUB FAIL
                    CASE "f"
                            if WaitFor[1]="f" then
                                    if WaitFor[2]=0 then
                                            LOW PORTD.4
                                            HSEROUT ["OFF",13,10]
                                                    GOSUB FAIL
                    CASE ELSE
                            GOSUB FAIL
                    END SELECT
    ClearArray:
            FOR CounterA = 0 TO 3
                    WaitFor[CounterA]=0
                    next
    FAIL:
            HSEROUT ["FAIL!",13,10]
    Another Variant...
            DEFINE OSC 40
            WaitFor     var byte [6]
            CounterA    VAR BYTE
            clear
            PORTD = 0
            TRISD = 0
            GOSUB ClearArray
            HSERIN   1000,Test_bloff,[str waitFor\6]
    Test_bloff:
            ARRAYREAD  WaitFor,6, Test_blon,[WAIT ("bloff",0)]
            LOW PORTD.4
    Test_blon:
            ARRAYREAD  WaitFor,6, FAIL,[WAIT ("blon",0)]
            HIGH PORTD.4
    FAIL:
            GOTO main
    ClearArray:
            FOR CounterA = 0 TO 5
                    WaitFor[CounterA]=0
                    next
    now tell me it's not hard
    Sep 2005
    Campbell, CA
    Wow! Next time I need some code written, I'll just state what I want to do, and let you guys write it.
    Charles Linquist
    Another Variant...
            DEFINE OSC 40
            CounterA    VAR BYTE
            clear
            PORTD = 0
            TRISD = 0
            GOSUB ClearArray
    Test_bloff:
            LOW PORTD.4
    Test_blon:
            HIGH PORTD.4
    FAIL:
            GOTO main
    ClearArray:
                    WaitFor[CounterA]=0
                    next
    Thanks a lot, your code is perfectly understandable.
