RS232 serial commands
Results 1 to 16 of 16
    Question RS232 serial commands
    Hi everyone,
    It's maybe a dumbass question, but how to convert these incorrect commands:
    IF HSERIN ["start"]=1 then
    HIGH PORTD.4
    into a correct syntax?
    It's a very simple program, when I send the word "start" from HyperTerminal, I would turn on a LED connected on the PORTD.4.
    Notice that my communications between my PC and the PIC works already in both ways (receive/transmit).
    Thanks for your help.
    Sep 2005
    Campbell, CA
    Default Re: RS232 serial commands
    It depends a lot on whether or not your program is going to wait around for
    the input, or if it needs to do something else while waiting. Or whether or not your input will come from a keyboard (time between characters) or all at once.
    One way would be to -
    LookForStart:
    FoundStart = 0
    HSERIN 1000,NoData,[WAIT ("start")] : FoundStart=1
    NoData:
    FoundStart will = 1 if the "start" was received after waiting for 1 second.
    Charles Linquist
    Quote Originally Posted by Charles Linquis View Post
    LookForStart:
    FoundStart = 0
    NoData:
    I use this :
    DEFINE OSC 40
    DEFINE LCD_DREG PORTD
    DEFINE LCD_EREG PORTB
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_EBIT 6
    DEFINE LCD_RSBIT 7
    DEFINE ADC_BITS 10
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 20h
    DEFINE HSER_BAUD 9600
    DEFINE HSER_SPBRG 64
    char var WORD
    foundstart var bit
    HIGH PORTE.2
    LCDOUT $fe,1
    Hserout ["Program has started."]
    LookForStart:
    FoundStart = 0
    HSERIN 5000,noData,[WAIT ("start")] : FoundStart=1
    nodata:
    if FoundStart=1 then
       HIGH PORTD.4
       Lcdout $fe,2,"Backlight ON."
    And it doesn't work, every 5 seconds I receive "Program has started".
    Now I'm using Terminal v1.9b by Bray, it's far better because I can send a word at once. So no time between characters.
    And yeah, my program have a lot things to do (interrupts, etc.) during this time. Here I'm using a very simple program to get started.
    try something like that
            DEFINE OSC 40
    Start:
            Hserout ["Program has started.",13,10]
            gosub LookForStart
            Goto Start
    LookForStart:
            hserout ["Got it! Backlight ON",13,10]
    nodata:
            HSEROUT ["NOPE... Life's so cruel...",13,10]
            DEFINE OSC 40
    Start:
            gosub LookForStart
            Goto Start
    LookForStart:
    nodata:
    Thanks!
    HSERIN command remind me the BUTTON command (with the label).
    So I use this :
    DEFINE OSC 40
    DEFINE LCD_EBIT 6
    DEFINE LCD_RSBIT 7
    DEFINE ADC_BITS 10
    Hserout ["Varidrive V2011.00 has started"]
    mainlp:
    LCDOUT $fe,2,"Main loop"
    HSERIN ret,[WAIT ("blon")]
           HIGH PORTD.4
    ret:
    HSERIN ret1,[WAIT ("bloff")]
           LOW PORTD.4
    ret1:
    Goto mainlp
    And it works flawlessly.
    However, when I type "blonn" instead of "blon", the backlight is activated.
    Same thing with "blofffff" instead off "bloff", the backlight is disabled.
    So I need a stop bit or something like that?
    OK, so you need to check a couple of different Strings possibilities and act upon right?
    Is this really need to be string? Did you built the "Transmitting unit" or it's just for learning purpose?
    Most common and easiest way to implement such thing is to wait for a specific header and then use the next Byte for specific command.
    ex:
    Transmitter send: "NextCommandIs", 10
    Receiver Wait for "NextCommandIs" and store 10 in a byte variable. Depending the value of that Byte Variable, it process various task.
    So Easy as
    Transmitter Side:
    HSEROUT ["NextCommandIs", 10]
    Receiver Side:
    HSERIN [WAIT ("NextCommandIs"), ByteA]
    SELECT CASE ByteA
    Should you really need to wait for a specific String, then you'll need to build a string with each single character you receive parse them. Not hard, just a tad longer to implement.
    Also, depending of how you send the whole thing, you may also check for a "end" character. If the string is right but the next character/byte is false, you discard the result.
    All the time, you want to implement a structured "serial data message" on both side.
    Here's some inspiration, not 100% efficient but easy to follow.
            DEFINE OSC 40
            WaitFor     var byte [4]
            CounterA    VAR BYTE
            clear
            Hserout ["Varidrive V2011.00 has started",13,10]
            GOSUB ClearArray
            HSEROUT ["Main loop",13,10]
            HSERIN  5000, main,[WAIT ("blo")]
            HSERIN 500, testit, [str waitFor\3]
    testit:
            SELECT CASE WaitFor[0]
                    CASE "n"
                            if WaitFor[1]=0 then
                                    HIGH PORTD.4
                                    HSEROUT ["ON",13,10]
                                        GOSUB FAIL
                    CASE "f"
                            if WaitFor[1]="f" then
                                    if WaitFor[2]=0 then
                                            LOW PORTD.4
                                            HSEROUT ["OFF",13,10]
                                                    GOSUB FAIL
                    CASE ELSE
                            GOSUB FAIL
                    END SELECT
    ClearArray:
            FOR CounterA = 0 TO 3
                    WaitFor[CounterA]=0
                    next
    FAIL:
            HSEROUT ["FAIL!",13,10]
    Another Variant...
            DEFINE OSC 40
            WaitFor     var byte [6]
            CounterA    VAR BYTE
            clear
            PORTD = 0
            TRISD = 0
            GOSUB ClearArray
            HSERIN   1000,Test_bloff,[str waitFor\6]
    Test_bloff:
            ARRAYREAD  WaitFor,6, Test_blon,[WAIT ("bloff",0)]
            LOW PORTD.4
    Test_blon:
            ARRAYREAD  WaitFor,6, FAIL,[WAIT ("blon",0)]
            HIGH PORTD.4
    FAIL:
            GOTO main
    ClearArray:
            FOR CounterA = 0 TO 5
                    WaitFor[CounterA]=0
                    next
    now tell me it's not hard
    Sep 2005
    Campbell, CA
    Wow! Next time I need some code written, I'll just state what I want to do, and let you guys write it.
    Charles Linquist
    good karma... that is
    Another Variant...
            DEFINE OSC 40
            CounterA    VAR BYTE
            clear
            PORTD = 0
            TRISD = 0
            GOSUB ClearArray
    Test_bloff:
            LOW PORTD.4
    Test_blon:
            HIGH PORTD.4
    FAIL:
            GOTO main
    ClearArray:
                    WaitFor[CounterA]=0
                    next
    Thanks a lot, your code is perfectly understandable.
    ... And have a deliberate small mistake in before receiving the bomb-proof approval... but this... i'll let you the pleasure find it
    Enjoy!
    Sep 2005
    Campbell, CA
    Steve.... I put lots of "deliberate" mistakes in my code as well.
    Charles Linquist
    Good grief, nice to know some of them are in Orbit
    Sep 2005
    Campbell, CA
    Or at least they are supposed to be....
    Charles Linquist
