Another math problem for PBP
Results 1 to 3 of 3
    Feb 2005
    Bellevue
    Question Another math problem for PBP
    I have two 24LC512 chips used in a memory array controlled by an 18F2525. I am trying to compute the %age 'full' the memory chips are together. I can do it in MS Excel, but not in PBP...
    Here is what I am trying to do.
    Chipselect = the chips - can be a '1' or a '2'. (Byte)
    Memperc = %age of memory used (byte)
    Address = current memory pointer (on either chip). Increments in 128 (Word)
    Addrsm = address/1000 (byte)
    When I want to compute memory %age, I use this:
    if chipselect = 1 then
    addrsm = address/1000
    memperc = (addrsm/2)/64 ' 0-50%
    memperc = (addrsm+64)/128 '50-100%
    IN EXCEL, this works fine - for example: lets say Address = 40832 and Chipselect = 2
    Addrsm = 40832/1000 - > gives 40.832
    Chipselect is = '2' so,
    memperc = 40.832+64 = 104.832, /128 = .819
    What I get is '0'.... I want 81.9% so I can display the memory.. REALLY I want to get a number like '819' so I can display using:
    LCDout $fe, L4, "Memory%",#memperc dig 2, #memperc dig 1, ".", dec1 memperc,
    Any PBP Math gurus out there?
    Excel file with how I want it to work is attached.
    Just SCALE everything up so there are NO decimals to get in the way.... for a start, why are you dividing by 1000? Lose it and save some bytes...
    Your example...
    Addrsm = 40832
    Chipselect is = 2
    memperc=Addrsm/128 (answer will be 319 - memperc is a WORD of course)
    If Chipselect=2 then memperc=memperc+500
    You don't need to deal with calculating all of 100% of memory, just calculate the lower 50% block or the upper 50% block, and in the case of the upper block just add 50% to get the final answer. Then to display...
    LCDOut "Memory="
    If memperc>999 then LCDOut #memperc DIG 3
    If memperc>99 then LCDOut #memperc DIG 2
    LCDOut #memperc DIG 1,".",#memperc DIG 0,"%"
    Your display should show "Memory=81.9%" with leading zeros surpressed.
    Feb 2005
    Bellevue
    Thumbs up
    THANK YOU!!! I was too close to the flame to see the answer... Excellent! The only tweak I had was adding a "#" in front of the display digits...
    Tom
  1. Line Graph, math problem...
    By TerdRatchett in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 05:20
  2. Math problem with string result
    By Lotondo in forum mel PIC BASIC Pro
    Last Post: - 15th November 2006, 11:06
  3. PicBasic Pro Math Problem??
    By Glen65 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2006, 05:36
  4. Math Formula / Variable Problem! Help!
    By bwarp in forum mel PIC BASIC Pro
    Last Post: - 18th February 2006, 08:59
  5. Math problem...with picbasic pro
    By pcaccia in forum mel PIC BASIC Pro
    Last Post: - 15th October 2005, 20:28
