16F727 ADC problem
Results 1 to 6 of 6
    Default 16F727 ADC problem
    Hello
    I cant get get ADC to work on my 16F727 already tried alot for 3 hours
    Im trying to get it to work on E1 and E0
    Default Re: 16F727 ADC problem
    Hi and welcome aboard!
    Rule #1: post your code here and we will help you to spot the problem... unless you may end up with comments like "My crystal is broken..." and plah plah plah
    Mar 2006
    China
    Rule #2: Have you checked with a voltmeter that the desired signal is present on the legs of the PIC and that the level is less than VDD.
    Could find a edit button.
    Device 16F727
    Config1 DEBUG_OFF, BOR_OFF, CP_OFF, MCLRE_OFF, WDT_OFF, INTOSCIO
    Xtal 16
    ;         76543210
    PORTB  = %00000000
    TRISB  = %00000010
    ANSELB = %00000000  ;Or %00000001 or %00000010 or %00000000
    ;         76543210
    ANSELE = %00000010
    PORTE  = %00000000
    TRISE  = %00000010
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 3
    DEFINE ADC_SAMPLEUS 10
    ADCON0 = %00011001
    ADCON1 = %01110011
    Declare LCD_ENPin = PORTB.3   ;De EN aansluiting moet nu aan PORTA.6
    Declare LCD_RSPin = PORTB.2   ;De RS aansluiting moet nu aan PORTA.7
    Symbol potmeter   = PORTE.1
    Symbol voltmeting   = PORTE.2
    Dim var1 As Word
    Dim var2 As Word
    '-------[INITIALISE THE PICMICRO]----------------------------------------
    Clear                         ;Wis alle RAM geheugen
    DelayMS 500    ' Wait for the PICmicro to stabilise
    Cls
    Print "Rdy"
    GoTo main   ' Jump over the subroutines
    While 1 = 1
      ADCIN 5, var1
      ADCIN 6, var2
      Print At 1,1, Dec var1
      Print At 2,1, Dec var2
    Wend
    yes the signal is present on the leg of the pic but i just get a 3 diget number that keeps changeing and doesnt respond when i turn on my potmeter
    I think you will have better luck on the Proton forum.
    http://www.protonbasic.co.uk/
    When you post there you will want to describe how you have the hardware setup along with the code.
