As far as I know, the timeout/label option has always used a GOTO to get to the label after the timeout period has expired. I can't say why it would have worked on an earlier version. Maybe luck...![]()
time out....go sit on the bench,
timeout only needed for serin !
don
amgen
NL2TTL, The statement: Funny in 2.47 version of the compiler the timeout lable works with returns
I see that 3.00 does not accept the return. Only makes sense if the timeout actually happened inside of a subroutine. Otherwise, where are you returning to?
EN82fn
could check PARITY BIT 13 in mode, manual says must=1
don
