Chip Selection
Results 1 to 9 of 9
Thread: Chip Selection
    Default Re: Chip Selection
    What is the source of the inputs? Maybe there is a spike now and then.
    Aug 2005
    Houston, TX
    The power comes from the trickle charge to a 12 v alarm battery. I have a pretty well filtered supply because of the supply wires running parallel to 120v AC wires.
    I've never, and will never trust any Pull-up thing. As per their definition they are weak. nuff said. In a shielded enclosure with no external inputs, running off battery maybe they're fine... but not something I would use again on a final product since I already got issue with some handheld car instruments I've made years ago. Ununsed i/o are set to input and tied to GND directly, or with low value pull-down.
    Some will say set them as output and left them floating... ok .. could be fine as long as you always have supply on your board.
    GOOD ground plane will also help.
    Quote Originally Posted by AMay View Post
    The input pins will not handle 12 volts. It is a wonder it works at all.
    Or.
    You misunderstood the question....
    Dec 2010
    Or.
    Or maybe you missed the original post where he states:
    "I have a 100uf cap at the input, and a 78L05 regulator, a .1 cap on the 5v side."
