Newbie help. RGB Led on a PIC10F202
Results 1 to 40 of 42
    Jan 2006
    Istanbul
    Default Re: Newbie help. RGB Led on a PIC10F202
    Your LEDs are conected to Vdd instead of GND.
    And GPIO is set to 0, so initially all pins are low at the beginning and thus LEDs are on.
    When a PWM cycle is done, the pin stays low again and the LED is still on.
    I am guessing Steve forgat to add these in his last posted code above.
    Before "pwm ButtonCount,127,100", insert these:
    HIGH RED
    HIGH GREEN
    HIGH BLUE
    So the new code will be as below:
    MAIN:
            IF !SwitchPin THEN                              ' Switch down?
                                                            ' - YES
                    If ButtonCount = 3 THEN ButtonCount = 0 ' - Currently on GP3 (MCLR)?  If so, pass go, claim 200$
                    HIGH RED
                    HIGH GREEN
                    HIGH BLUE
                    pwm ButtonCount,127,100                 ' - Light Show
                    WHILE !SwitchPin : wend                 ' - Spin 'till button is released
                    pAUSE 50                                ' - arbitrary debouince delay
                    ButtonCount = ButtonCount + 1           ' - Point to next LED
                    endif                                   '
            GOTO MAIN
    Aug 2011
    I have one RGB LED with a common anode thats hooked up to VDD. The individual pins are connected to the I/O ports on the chip. I entered in the code above but all colors are still on. The even funnier part is i even commented out those lines including the PWM line and all three are still on. I commented out just the PWM line, same thing. I even erased the chip, verified erase and reprogrammed.
    Jan 2006
    Istanbul
    cmcon0 = 0
    Aug 2011
    Error[113] c:\pbp\pbppic12.lib 423 : Symbol not previously defined (CMCON0). A have a whole bunch of these.
    The 10F202 doesn't have a CMCON0 register so leave that out.
    See if this works;
    @  __config _WDT_OFF & _MCLRE_OFF & _CP_OFF
      Red       var GPIO.0
      Green     var GPIO.1
      Blue      var GPIO.2
      SwitchPin var GPIO.3  ' Active low
      RD CON %11111110  ' red
      GR CON %11111101  ' green
      BL CON %11111011  ' blue
      YL CON GR & RD      ' green + red = yellow
      CY CON GR & BL      ' green + blue = cyan
      PR CON BL & RD      ' blue + red = purple
      WT CON GR & BL & RD   ' green + blue + red = white
      OF con %11111111  ' all LEDs off
      ButtonCount VAR BYTE
      OPTION_REG = %00000000  ' GPIO.2 for GP use
      TRISIO = %00001000  ' GP3: Input, other pin: Output
      GPIO = %00000111    ' LEDs off
      ButtonCount = 0
    MAIN:
         PAUSE 50                                ' - arbitrary debouince delay
         SELECT CASE ButtonCount
           CASE 1
             GPIO = RD
           CASE 2
             GPIO = GR
           CASE 3
             GPIO = BL
           CASE 4
             GPIO = YL
           case 5
             GPIO = CY
           case 6
             GPIO = PR
           case 7
             GPIO = WT
           case IS > 7
             GPIO = OF
             ButtonCount = 0
         END SELECT
      GOTO MAIN
    The PWM command returns the output pin to an input after it finishes so that might be causing some funkiness. Try just placing color values on the port and see if this helps.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Aug 2011
    Switch works. Just not following the colors you have in each of the case statements. In order of presses in goes: Red, Green,Blue, Yellow for a split second, White, Cyan, Red, No White then cycles over again as it should.
    We are getting closer though and very much appreciate this. This is my first project with any of PIC MCUs as well as my first with PICBASIC Pro.
    My bad. Change the + to & in the color mix constants...;o)
    YL CON GR & RD, etc,,
    -Bruce
    tech at rentron.com
