Your LEDs are conected to Vdd instead of GND.
And GPIO is set to 0, so initially all pins are low at the beginning and thus LEDs are on.
When a PWM cycle is done, the pin stays low again and the LED is still on.
I am guessing Steve forgat to add these in his last posted code above.
Before "pwm ButtonCount,127,100", insert these:
HIGH RED
HIGH GREEN
HIGH BLUE
So the new code will be as below:
MAIN:
IF !SwitchPin THEN ' Switch down?
' - YES
If ButtonCount = 3 THEN ButtonCount = 0 ' - Currently on GP3 (MCLR)? If so, pass go, claim 200$
HIGH RED
HIGH GREEN
HIGH BLUE
pwm ButtonCount,127,100 ' - Light Show
WHILE !SwitchPin : wend ' - Spin 'till button is released
pAUSE 50 ' - arbitrary debouince delay
ButtonCount = ButtonCount + 1 ' - Point to next LED
endif '
GOTO MAIN
