Newbie help. RGB Led on a PIC10F202
Results 1 to 40 of 42
Threaded View
  1. #13
    Aug 2010
    Maryland, USA
    Default Re: Newbie help. RGB Led on a PIC10F202
    Now let's make sure that button is working. Modify the main to be this:
    Gosub red
    If button =1 then goto skipgreen
    Gosub green
    Skipgreen:
    Gosub blue
    Goto main
    That should have all three lit as before unless you press the button, then it should skip the green gosub. Btw, is the tris for the button set to input? Also I am a lazy typer, so I assume you will make the names be what they need to be like button shoud really be switchpin (i think)
    -Bert
