Newbie help. RGB Led on a PIC10F202
Results 1 to 40 of 42
Threaded View
  1. #15
    Aug 2010
    Maryland, USA
    Default Re: Newbie help. RGB Led on a PIC10F202
    Well thats just wierd that it skips blue always. but the the whole circuit turning off makes perfect sense. If you look at the gp3 pin, it is input only because it is shared with MCLR. that is the external reset pin. Since you have no configs listed, I assume you are using the defaults. I went and looked at 10f202.inc in the PBP folder and the default config has MCLR_ON. this means GP3 is set to be the reset when low. so I am sure you are reseting the chip, or at least not looking at it as an input.
    2 choices here: Assuming you are NOT using PBP3, you can change the .inc file to MCLR_OFF and leave it as that, or you can comment the configs all together and put them in your code;
    If you are using PBP3, you can use the brand new #config block format and set your configs in your code
    BTW, I am going to assume the blue not working may have something to do with the MCLR issue for now. Also I guess you are right about the TRIS, but I would get in the habit of just ALWAYS setting it. Life will be easier later for you that way.
    Last edit: Please post your current code now so we know where you are.
    -Bert
