Mistake in my 2 first example. Change made in RED
Code:Red var GPIO.0 Green var GPIO.1 Blue var GPIO.2 SwitchPin var GPIO.3 ButtonCount VAR BYTE ButtonCount = 1 ;Make sure LEDs are off HIGH Red HIGH Green HIGH Blue MAIN: IF SwitchPin THEN If ButtonCount = 1 THEN GOSUB RedProgram If ButtonCount = 2 THEN GOSUB GreenProgram If ButtonCount = 3 THEN GOSUB BlueProgram If ButtonCount = 4 THEN ButtonCount = 1 else ButtonCount = ButtonCount + 1 endif endif GOTO MAIN RedProgram: PWM Red,127,100 RETURN GreenProgram: PWM Green,127,100 RETURN BlueProgram: PWM Blue,127,100 RETURNsorryCode:Red var GPIO.0 Green var GPIO.1 Blue var GPIO.2 SwitchPin var GPIO.3 ButtonCount VAR BYTE ButtonCount = 1 ;Make sure LEDs are off HIGH Red HIGH Green HIGH Blue MAIN: IF SwitchPin THEN If ButtonCount = 1 THEN PWM Red,127,100 ENDIF If ButtonCount = 2 THEN PWM Green,127,100 ENDIF If ButtonCount = 3 THEN PWM Blue,127,100 ENDIF If ButtonCount = 4 THEN ButtonCount = 1 else ButtonCount = ButtonCount + 1 endif endif GOTO MAIN![]()
