#config length ?
Results 1 to 8 of 8
    Aug 2004
    Default #config length ?
    Dear friends:
    In PBP3,all pics are assembled with MPLAB,
    EXAMPLE:
    For the PIC 16F886 I am using
    __config _CONFIG1,_INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _LVP_OFF & _CP_ON
    __config _CONFIG2, _BOR21V
    It works OK,but the first line excceds the 80 chars for line.
    Can I separate the second part "_LVP_OFF & _CP_ON " maybe with
    another line as:
    __CONFIG _CONFIG1,_LVP_OFF & _CP_ON ?
    I tried that ,but it generates a compiler error.
    The new reference manual states the fuses separated for the PICS18...
    This works for the PIC16 too ?
    Thanks in advance...
    Ruben de la Pena Valdes.
    Aug 2010
    Maryland, USA
    Default Re: #config length ?
    I count 76, are you sure that's the error?
    -Bert
    You can use something like that
    CFG1    = _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF
    CFG11   = _LVP_OFF & _CP_ON
            __config _CONFIG1, CFG1 & CFG11
    cnc, it's not an error, it's just over the IDE gutter (which you can still move to whatever else but 80).
    Oct 2009
    Utah, USA
    I would like to know the same thing... That is, how can one break long "__CONFIG" lines into shorter lines?
    Below is an example of how to compile your program for two different PIC's, 16F1828 and 16F690. It works NOW... but getting the config statements right cost me a lot of time.
    Specifically the fact that "__CONFIG _CONFIG1," works for 16F1828 and "__CONFIG" (no comma) had to be used for the 16F690.
    Is the fact that some PIC's require a comma in the config line and some do not determined by MPLAB??
    #IF __PROCESSOR__ = "16F1828"
               __CONFIG _CONFIG1, _FOSC_INTOSC & _WDTE_ON & _PWRTE_OFF & _MCLRE_OFF & _CP_ON & _CPD_OFF & _BOREN_OFF & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF
               __CONFIG _CONFIG2, _WRT_OFF & _PLLEN_OFF & _STVREN_OFF & _BORV_25 & _LVP_OFF
        #endconfig
        #else
           #IF __PROCESSOR__ = "16F690"
               __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_OFF & _MCLRE_OFF & _CP_ON & _CPD_OFF & _BOD_OFF & _IESO_OFF & _FCMEN_OFF
             #endconfig
               #ELSE
               #ERROR "Program does not support " + __PROCESSOR__
           #ENDIF
    #endif
    #msg "compiling for target " + __PROCESSOR__
    Dwight
    If the chip only has one config word, you don't specify the word's name because it doesn't have one.
    For chips with more than one config word, you must specify the word with _CONFIG1 or _CONFIG2 etc.
    If you like commenting everthing really well, you can do the configs like this ...
    #if __PROCESSOR__ = "16F1828"
        #config
    CFG =       _FOSC_INTOSC         ; Oscillator
    CFG=CFG&    _WDTE_ON             ; Watch Dog Timer
    CFG=CFG&    _PWRTE_OFF           ; Power-on Timer
    CFG=CFG&    _MCLRE_OFF           ; Master Clear Reset
    CFG=CFG&    _CP_ON               ; Code Protect
    CFG=CFG&    _CPD_OFF             ; EEPROM Data Protect
    CFG=CFG&    _BOREN_OFF           ; Brown-out Detect
    CFG=CFG&    _CLKOUTEN_OFF        ; FOSC/4 Output
    CFG=CFG&    _IESO_OFF            ; Internal External Switchover
    CFG=CFG&    _FCMEN_OFF           ; Fail-Safe Clock Monitor
       __CONFIG _CONFIG1, CFG
    CFG =       _WRT_OFF             ; Flash table writes
    CFG=CFG&    _PLLEN_OFF           ; 4xPLL OSC multiplier
    CFG=CFG&    _STVREN_OFF          ; Stack Over/Underflow
    CFG=CFG&    _BORV_25             ; Brown-out voltage
    CFG=CFG&    _LVP_OFF             ; Low Voltage Programming
       __CONFIG _CONFIG2, CFG
        #endconfig
    #else
        #config
    CFG =       _INTRC_OSC_NOCLKOUT  ; Oscillator
    CFG=CFG&    _WDT_ON              ; Watch Dog Timer
    CFG=CFG&    _BOD_OFF             ; Brown-out Detect
      __CONFIG  CFG
        #endconfig
        #else
            #error "Program does not support " + __PROCESSOR__
        #endif
    #endif
    Aug 2004
    Hi:
    Thanks Steve, it works now !.
    Greetings...
    Still doable the long way, still easy though
           __CONFIG _CONFIG1, B'11111101010100'
                              ; 1------------- CP:    Code Protection off
                              ; -1------------ CPMX:  CCP1 on RB0
                              ; --1----------- DEBUG: Disabled.  RB<7:6> are general purpose i/o
                              ; ---11--------- WRT:   Write Protection off
                              ; -----1-------- CPD:   Code Protection off
                              ; ------0------- LVP:   Disabled.  RB3 Is General I/O
                              ; -------1------ BOREN: Enable Brown Out Reset
                              ; --------0----- MCLRE: Disable MCLR, RA5 Is digital I/O
                              ; ----------0--- PWRTE: Enable Power-Up Timer
                              ; -----------1-- WDTEN: Enable Watch Dog Timer
                              ; ---------1--00 FOSC:  INTRC, NOCLKOUT
           __CONFIG _CONFIG2, b'11111111111100'
                              ; xxxxxxxxxxxx-- unimplemented
                              ; ------------0- IESO: Disable Internal/External Swichover
                              ; -------------0 FCMEN: Disable Fail-Safe Clock Monitor
    Not too hot with that method, but neat
