HID USB on 18F87J50
Results 1 to 40 of 57
    Default Re: HID USB on 18F87J50
    Thanks Darrel. I had some weird behavior in my computer. PBP3 kept defaulting to MPASMX, no mater how I set it, I'd check back, and it was set to MPASMX. So after removing the Microchip directory, and re-installing MPLAB 8.76, I was able to get PBP to settle on C:\Program Files\Microchip\MPASM Suite . Now CDC and HID work for the 18F67J50 with PBP3.0! Thanks for routing that out for us!
    I have to say I'm glad for Melabs it's not another Microchip twist who had to implement another .HWLIB thing.
    Finger crossed for the next USB pic though... BTW, it's about time Microchip release USB3 AND/OR Thunderbolt.
    Sep 2009
    Darrel,
    I try your DT_HID260, and it work on first attempt. It's very simple to use.
    But I have question.
    If I want to use 64 byte, #define USB_EP0_BUFF_SIZE should be 64, is that correct?
    No, endpoint 0 is for setup and control transfers. You should not change that.
    And you should not change anything inside the DT_HID260.pbp file.
    Set the report sizes with the defines...
    ;--- Setup USB -------------------------------------------------------------
    INCLUDE "DT_HID260.pbp"
    DEFINE USB_VENDORID    6017
    DEFINE USB_PRODUCTID   2000
    DEFINE USB_VERSION     1
    DEFINE USB_VENDORNAME  "Darrel Taylor"
    DEFINE USB_PRODUCTNAME "DT_HID"
    DEFINE USB_SERIAL      "001"
    DEFINE USB_INSIZE      64   ;  IN report is PIC to PC (8,16,32,64)
    DEFINE USB_OUTSIZE     16   ; OUT report is PC to PIC
    DEFINE USB_POLLIN      10   ; Polling times in mS, MIN=1 MAX=10
    DEFINE USB_POLLOUT     10
    Sep 2009
    Ok. Everything working fine.
    Thanks again.
    Sep 2009
    Here is my template. Maybe it will be useful for someone.
    Application for PC is done in VB6. Screen shot:
    Name:  Screen Shoot.JPG
    PBP & VB6 files:
    DT_HID260 Template.zip
    If knobs doesn't appear in vbForm, you need to add it in components.
