HID USB on 18F87J50
Results 1 to 40 of 57
    Default Re: HID USB on 18F87J50
    Thanks Pedja,
    We have some of those chips, but no boards to put it on.
    At least none that would be easy to use.
    I think the 67J50 should be good enough since it's in the same family as the 87J50.
    We shall see this weekend.
    Sep 2009
    Dear sir,
    Thank you for support.
    There is something seriously messed up with these chips. And it's all Microchip.
    The SFR's from address F40h to F5Fh cannot be accessed with either the MOVFF opcode or indirectly through the FSR's.
    They can only be accessed by setting BSR to bank15 and using "banked" opcodes like movf, movwf, bcf etc.
    I realize that those SFR's are outside of the ACCESS bank, but that should not affect MOVFF or indirect addressing thru FSR's.
    That range of SFR's contains many of the USB modules registers.
    Other USB module registers such as UCON USTAT etc that reside in the access bank can be written/read with all 3 methods FSR, MOVFF and banked. So it's not related to the USB module itself.
    The USB libraries rely heavily on MOVFF and FSR's.
    I have found nothing in the errata or datasheet that mentions this behavior.
    To illustrate the issue, here is a program for the Olimex PIC_LCD3310.
    It attempts to read several SFR's using all 3 methods and displays the result on the GLCD. With anything in the affected range, only the banked method (GetR on the display) returns a value. Any other SFR's work fine.
    Use Up and Down on the joystick to scroll thru the SFR's.
    '*  Name    : 18F67J50USB.pbp                                              *
    '*  Author  : Darrel Taylor                                                *
    '*  Notice  : Copyright (c) 2009                                           *
    '*  Date    : 8/21/2011                                                    *
    '*  Notes   : The FSR's from F40 to F5F are not accessable using either    *
    '*          : MOVFF or indirectly with FSR's.                              *
    #config         ;pic18F67J50 on Olimex PIC_LCD3310 usb board
        CONFIG PLLDIV = 5    ;for 20 mhz crystal
        CONFIG XINST = OFF
        CONFIG STVREN = off    ;stack overflow reset
        CONFIG WDTEN = OFF    ;added
        CONFIG CP0 = OFF    ;added
        CONFIG IESO = OFF    ;added
        CONFIG FCMEN = OFF    ;added
        CONFIG CCP2MX = DEFAULT    ;added
        CONFIG WDTPS = 32768
        CONFIG CPUDIV = OSC1  ;DIVIDE BY 1 MODE
        CONFIG FOSC = HSPLL
        CONFIG MSSPMSK = MSK5   ;add
    #endconfig
    DEFINE OSC 48
    clear
    OSCTUNE.6 = 1  ' Enable PLL for 18F87J50 family
    PAUSE 200
    ;--- For the 3310 display---------------------------------------------------
    include "AllDigital.pbp"
    ;DEFINE SHOWDIGITAL 1
    include "modedefs.bas"
    include "LCD_3310v32.inc"
    GOSUB Lcd_Clear
    ;--- Setup Interrupts ------------------------------------------------------
    INCLUDE "DT_INTS-18.bas"     ; Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas"    ; Allows re-entry to PBP from ASM interrupts
    INT_LIST  macro    ; IntSource,          Label,  Type, ResetFlag?
            INT_Handler   USB_Handler
            INT_Handler   TMR1_INT,    _TMR1_ISR,   PBP,  yes
        INT_ENABLE  TMR1_INT     ; Enable Timer 1 Interrupts
    endasm
    ;--- Setup USB -------------------------------------------------------------
    INCLUDE "DT_HID260.pbp"
    DEFINE USB_VENDORID    6017
    DEFINE USB_PRODUCTID   2000
    DEFINE USB_VERSION     1
    DEFINE USB_VENDORNAME  "Darrel Taylor"
    DEFINE USB_PRODUCTNAME "DT_HID"
    DEFINE USB_SERIAL      "001"
    DEFINE USB_INSIZE      32   ;  IN report is PIC to PC (8,16,32,64)
    DEFINE USB_OUTSIZE     16   ; OUT report is PC to PIC
    DEFINE USB_POLLIN      10   ; Polling times in mS, MIN=1 MAX=10
    DEFINE USB_POLLOUT     10
    ; --- Each USB LED is optional, comment them if not used ----
    ;DEFINE USB_LEDPOLARITY 1       ; LED ON State [0 or 1]  (default = 1)
    DEFINE USB_PLUGGEDLED  PORTE,3 ; LED indicates if USB is connected
    ;DEFINE USB_TXLED       PORTC,2 ;  "      "     data being sent to PC
    ;DEFINE USB_RXLED       PORTC,1 ;  "      "     data being received from PC
    OutCount    VAR  WORD : OutCount = 0
    Value       VAR  WORD
    X           VAR  WORD
    ;--- The Main Loop ---------------------------------------------------------
    TRISD = 0
    PORTD.0 = 1   'turn on g sensor
    PORTD.1 = 0   'select scale for g sensor
    PORTD.2 = 0   'select scale for g sensor
    T1CON = $31                ; Prescaler = 8, TMR1ON
    LCD_Value VAR BYTE
    UCFG_VAL  CON EXT
    B0        VAR BYTE         ; Button Var
    B1        VAR BYTE         ; Button Var
    GetReg macro Regin, VarOut
        banksel  Regin
        movf     Regin, W
        banksel  VarOut
        movwf    VarOut
        banksel  0
    PAUSE 100
    Left   VAR PORTB.1
    Right  VAR PORTA.4
    Up     VAR PORTB.4
    Down   VAR PORTB.5
    Center VAR PORTB.0
    ShowUCON:
    GOSUB Lcd_Clear
    @ PrintStr  0,0, "  UCON - F65h"
    @ PrintStr  0,2, "FF  = "
    LCD_Value = UCON
    GOSUB LCD_BIN8
    @ PrintStr  0,3, "GetR= "
    @ GetReg  UCON, _LCD_Value
    GOSUB LCD_BIN8
    @ LFSR 0, UCON
    @ movff INDF0, _LCD_Value
    @ PrintStr  0,4, "FSR = "
    GOSUB LCD_BIN8
    UCON_Wait:
    PAUSE 10
    BUTTON Down,0,255,255,B0,0,UCON_Wait
    ShowUSTAT:
    GOSUB Lcd_Clear
    @ PrintStr  0,0, " USTAT - F64h"
    LCD_Value = USTAT
    GOSUB LCD_BIN8
    @ GetReg  USTAT, _LCD_Value
    GOSUB LCD_BIN8
    @ LFSR 0, USTAT
    GOSUB LCD_BIN8
    USTAT_Wait:
    PAUSE 10
    BUTTON Up,0,255,255,B1,1,ShowUCON
    BUTTON Down,0,255,255,B0,0,USTAT_Wait
    ShowUEIR:
    GOSUB Lcd_Clear
    @ PrintStr  0,0, "  UEIR - F63h"
    LCD_Value = UEIR
    GOSUB LCD_BIN8
    @ GetReg  UEIR, _LCD_Value
    GOSUB LCD_BIN8
    @ LFSR 0, UEIR
    GOSUB LCD_BIN8
    UEIR_Wait:
    PAUSE 10
    BUTTON Up,0,255,255,B1,1,ShowUSTAT
    BUTTON Down,0,255,255,B0,0,UEIR_Wait
    ShowUIR:
    GOSUB Lcd_Clear
    @ PrintStr  0,0, "   UIR - F62h"
    LCD_Value = UIR
    GOSUB LCD_BIN8
    @ GetReg  UIR, _LCD_Value
    GOSUB LCD_BIN8
    @ LFSR 0, UIR
    GOSUB LCD_BIN8
    UIR_Wait:
    PAUSE 10
    BUTTON UP,0,255,255,B1,1,ShowUEIR
    BUTTON Down,0,255,255,B0,0,UIR_Wait
    ShowUCFG:
    GOSUB Lcd_Clear
    @ PrintStr  0,0, "  UCFG - F5Fh"
    LCD_Value = UCFG
    GOSUB LCD_BIN8
    @ GetReg  UCFG, _LCD_Value
    GOSUB LCD_BIN8
    @ LFSR 0, UCFG
    GOSUB LCD_BIN8
    UCFG_Wait:
    PAUSE 10
    BUTTON Up,0,255,255,B1,1,ShowUIR
    BUTTON Down,0,255,255,B0,0,UCFG_Wait
    ShowUADDR:
    GOSUB Lcd_Clear
    @ PrintStr  0,0, " UADDR - F5Eh"
    LCD_Value = UADDR
    GOSUB LCD_BIN8
    @ GetReg  UADDR, _LCD_Value
    GOSUB LCD_BIN8
    @ LFSR 0, UADDR
    GOSUB LCD_BIN8
    UADDR_Wait:
    PAUSE 10
    BUTTON Up,0,255,255,B1,1,ShowUCFG
    BUTTON Down,0,255,255,B0,0,UADDR_Wait
    ShowUEIE:
    GOSUB Lcd_Clear
    @ PrintStr  0,0, "  UEIE - F5Dh"
    LCD_Value = UEIE
    GOSUB LCD_BIN8
    @ GetReg  UEIE, _LCD_Value
    GOSUB LCD_BIN8
    @ LFSR 0, UEIE
    GOSUB LCD_BIN8
    UEIE_Wait:
    PAUSE 10
    BUTTON Up,0,255,255,B1,1,ShowUADDR
    BUTTON Down,0,255,255,B0,0,UEIE_Wait
    ShowUIE:
    GOSUB Lcd_Clear
    @ PrintStr  0,0, "   UIE - F5Ch"
    LCD_Value = UIE
    GOSUB LCD_BIN8
    @ GetReg  UIE, _LCD_Value
    GOSUB LCD_BIN8
    @ LFSR 0, UIE
    GOSUB LCD_BIN8
    UIE_Wait:
    PAUSE 10
    BUTTON Up,0,255,255,B1,1,ShowUEIE
    BUTTON Down,0,255,255,B0,0,UIE_Wait
    ShowPIE2:
    GOSUB Lcd_Clear
    @ PrintStr  0,0, "  PIE2 - FA0h"
    LCD_Value = PIE2
    GOSUB LCD_BIN8
    @ GetReg  PIE2, _LCD_Value
    GOSUB LCD_BIN8
    @ LFSR 0, PIE2
    GOSUB LCD_BIN8
    PIE2_Wait:
    PAUSE 10
    BUTTON Up,0,255,255,B1,1,ShowUIE
    BUTTON Down,0,255,255,B0,0,PIE2_Wait
    ShowUEP0:
    GOSUB Lcd_Clear
    @ PrintStr  0,0, "  UEP0 - F4Ch"
    LCD_Value = UEP0
    GOSUB LCD_BIN8
    @ GetReg  UEP0, _LCD_Value
    GOSUB LCD_BIN8
    @ LFSR 0, UEP0
    GOSUB LCD_BIN8
    UEP0_Wait:
    PAUSE 10
    BUTTON Down,0,255,255,B0,0,UEP0_Wait
        FOR X = 0 to 1000           ; Check for incomming USB data while pausing
    @     ON_USBRX_GOSUB  _HandleRX
          PAUSE 1
        NEXT X
        ADCIN 10, Value
        OutCount = OutCount + 1
        ARRAYWRITE USBTXBuffer,["AN0=",DEC Value," -",DEC OutCount,"  "]
        IF Plugged THEN GOSUB DoUSBOut     ; only send when USB is connected
    GOTO Main
    ;---- This just sends the received packet back to the PC -------------------
    HandleRX:
        ARRAYWRITE USBTXBuffer,[STR USBRXBuffer\USBBufferSizeRX]
    ;----[Timer1 interrupt blinks an LED]--------------------------------------
    TMR_DIV  VAR BYTE
    TMR1_ISR:
        TMR_DIV = TMR_DIV + 1
        if TMR_DIV = 12 THEN
            TOGGLE PORTE.2
            TMR_DIV = 0
    @ INT_RETURN
    LCD_BIN8:
        Lcd_Data = LCD_Value.7 + $30
        Gosub Lcd_SendChar
        Lcd_Data = LCD_Value.6 + $30
        Gosub Lcd_SendChar
        Lcd_Data = LCD_Value.5 + $30
        Gosub Lcd_SendChar
        Lcd_Data = LCD_Value.4 + $30
        Gosub Lcd_SendChar
        Lcd_Data = LCD_Value.3 + $30
        Gosub Lcd_SendChar
        Lcd_Data = LCD_Value.2 + $30
        Gosub Lcd_SendChar
        Lcd_Data = LCD_Value.1 + $30
        Gosub Lcd_SendChar
        Lcd_Data = LCD_Value.0 + $30
        Gosub Lcd_SendChar
    Walter,
    My PIC_LCD3310 arrived with a solder bridge between pins 13-14 (D+, RF5).
    Sometimes those are intentional, does your have a bridge there too.
    I've attached the .hex file for the above program.
    Weirdness! Will have to check your program out tonight! Thanks Darrel!
    No, mine do not have a solder bridge on any of the PIC pins.
    Here is a USB HID bootloader, just to make sure your USB portion (still)works.
    (Hold joystick in down position at power up to go to bootload mode)
    Aug 2010
    Maryland, USA
    Just went and looked at 1 of mine(I have 2 but must have put the other in a safe place). I see no bridges on the pins anywhere. So Darrel is it safe to assume you will create a workaround for microchips shortcoming? Haha just poking at you. Seems now that you have done the hard part and identified the issue, we need to make an asm routine to talk to those sfr's?
    -Bert
