HID USB on 18F87J50
Page 1 of 2 12 LastLast
Results 1 to 40 of 57
    Sep 2009
    Default HID USB on 18F87J50
    Does someone have example for this PIC?
    I can't get it to work...
    Sep 2009
    Default Re: HID USB on 18F87J50
    I searched the whole forum and I only found examples for the PIC18f2550 and 4550.
    Does PBP2.60 support USB on 18F87J50?
    For the second day of trying all possible examples and with all possible fuse configuration but nothing show in device menager, not even device not recognised...
    I bought this development system from mikroe, thinking that the is a hardware problem, but still nothing...
    What are my other options
    Should work. I had the 18F67J50 (same family) running CDC. I can try to get an example for it going for HID. By the way, are you using DT_HID260 ? Will try to get something up tonight, or tomorrow morning.
    Sep 2009
    Yes, I tried that and DT_HID. But nothing happen if cable is plugged or unplugged.
    For now, CDC will be good starting point.
    I would be very grateful if you could send me CDC example with fuse configuration.
    Thank you very much.
    Well, now I am starting to wonder if I ever had it working on CDC. I had a cdc labeled program for it, but what I had does not work. I had a fairly quick time with the 47J53 in CDC as well as HID, but for the 67J50, I can't seem to get either to work, and I have spent a fair amount of time at it.
    These were the configs I used for other programs for the 67J50, which pretty much matches Microchip's HID bootloader software.
    'DEFINE LOADER_USED 1
    'DEFINE RESET_ORG 1000h ' For Microchip USB Bootloader
    #config
        CONFIG PLLDIV = 5       ;for 20 mhz chip
        CONFIG XINST = OFF
        CONFIG STVREN = ON    ;stack overflow reset
        CONFIG WDTEN = OFF
        CONFIG CP0 = OFF
        CONFIG IESO = OFF
        CONFIG FCMEN = OFF
        CONFIG CCP2MX = DEFAULT
        CONFIG WDTPS = 32768
        CONFIG CPUDIV = OSC1  ;DIVIDE BY 1 MODE
        CONFIG FOSC = HSPLL
        CONFIG MSSPMSK = MSK5
    #endconfig
    DEFINE OSC 48
    clear
    OSCTUNE.6 = 1  ' Enable PLL for 18F87J50 family
    I will try a few more things, but I wanted to give you a heads up.
    Sep 2009
    I try cdc from pbp/usb18 and add config, but still nothing...
    I use 8MHz crystal, so PPLDIV is 2 is that correct?
    What are the chances that the USB module on 3 PIC are broken?
    Not very high. But (speaking for myself), the chances of the problem being behind the keyboard is pretty high! Just not sure what I could be missing here, doing it two different ways hid, and cdc, and with a USB bootloader, and without. So I am running out of things I can think of to try....
    Yes, divide by two would be correct for a 8 mhz.
    Sep 2009
    Angry Re: HID USB on 18F87J50
    I check hardware and recheck, and everything seems ok.
    Here is code for cdc from pbp/usb18:
        asm
        CONFIG PLLDIV = 2       ;for 8 mhz chip
        CONFIG XINST = OFF
        CONFIG WDTEN = OFF
        CONFIG CP0 = OFF
        CONFIG IESO = OFF
        CONFIG FCMEN = OFF
        CONFIG FOSC = HSPLL
        endasm
        Include    "cdc_desc.bas"    ' Include the HID descriptors
    Define  OSC     48
    buffer    Var    Byte[16]
    cnt    Var    Byte
        Pause 10
        USBInit            ' Get USB going
    ' Wait for USB input
    idleloop:
        USBService        ' Must service USB regularly
        cnt = 16        ' Specify input buffer size
        USBIn 3, buffer, cnt, idleloop
    ' Message received
        buffer[0] = "H"
        buffer[1] = "e"
        buffer[2] = "l"
        buffer[3] = "l"
        buffer[4] = "o"
        buffer[5] = " "
        buffer[6] = "W"
        buffer[7] = "o"
        buffer[8] = "r"
        buffer[9] = "l"
        buffer[10] = "d"
        buffer[11] = 13
        buffer[12] = 10
        buffer[13] = 0
    outloop:
        USBOut 3, buffer, 14, outloop
        Goto idleloop        ' Wait for next buffer
    I spend another day on it, and nothig, rely, nothin on usb...
    I really don't know what to do.
    Well, I am not having any luck over here either. Here is my try at using DT_HID260. I have been successful in getting it running on another J chip, the PIC18F47J53, and looking at the two data sheets, the USB doesnt seem to differ much between these two chips. Except on one the USB data memory is below the buffer descriptors, and the other the USB data memory is above the buffer descriptors. The DEV files seem to point to the USB buffer descriptors (67J50 here): USBMEMORYADDRESS Con $400 ' USB RAM starts here
    Here is my code (that does not work)
    '*  Name    : BasicUSB.pbp                                                 *
    '*  Author  : Darrel Taylor                                                *
    '*  Notice  : Copyright (c) 2009                                           *
    '*  Date    : 7/23/2009                                                    *
    '*  Version : 1.x ' Modified by scalerobotics                              *
    '*  Notes   : I tried to edit it to work on a PIC18F67J50 and I failed     *
    '*          : Worked great on other chips, but I can't seem to figure out  *
    '*          : the problem for PIC18F67J50. Board is PIC_LCD3310, which does*
    '*          : work with the USB bootloader,so probably not a hardware issue*
    ;--- if you un-comment these, you must comment the ones in the .inc file ---
    ASM  ; 18F2550/4550, 20mhz crystal
    ;   __CONFIG    _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
    ;   __CONFIG    _CONFIG1H, _FOSC_HSPLL_HS_1H
    ;   __CONFIG    _CONFIG2H, _WDT_ON_2H & _WDTPS_512_2H
    ;   __CONFIG    _CONFIG3H, _PBADEN_OFF_3H
    ;   __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
    ;ASM  ; 18F13K50/14K50  Only 12mhz crystal can be used for USB
    ;    CONFIG CPUDIV=NOCLKDIV ; CPU runing at full speed
    ;    CONFIG USBDIV=OFF ; Low speed USB clock diviser disabled, not used here
    ;    CONFIG FOSC=HS ; Use of High Speed crystal oscillator
    ;    CONFIG PLLEN=ON ; Enable PLL multiplier, 12Mhz oscilator x 4
    ;    CONFIG PCLKEN=ON ; Primary clock source is enabled
    ;    CONFIG FCMEN=OFF ; Failsafe clock off
    ;    CONFIG IESO=OFF ; Oscillator switchover mode disabled
    ;    CONFIG WDTEN=ON ; Watchdog timer on
    ;    CONFIG WDTPS=512 ; Watchdog divider is 512
    ;    CONFIG MCLRE=OFF ; Disable MCLR pin, enable RC3
    ;    CONFIG STVREN=ON ; Stack full/underflow will cause reset
    ;    CONFIG LVP=OFF ; Low voltage programming disabled
    ;    CONFIG BBSIZ=OFF ; 512kW block boot size
    ;    CONFIG XINST=OFF ; Extended instruction mode disabled
    ;ENDASM
    #config         ;pic18F67J50 on Olimex PIC_LCD3310 usb board
        CONFIG PLLDIV = 5    ;for 20 mhz crystal
        CONFIG XINST = OFF
        CONFIG STVREN = off    ;stack overflow reset
        CONFIG WDTEN = OFF    ;added
        CONFIG CP0 = OFF    ;added
        CONFIG IESO = OFF    ;added
        CONFIG FCMEN = OFF    ;added
        CONFIG CCP2MX = DEFAULT    ;added
        CONFIG FOSC = HSPLL
        CONFIG MSSPMSK = MSK5   ;add
    #endconfig
    DEFINE OSC 48
    clear
    ;--- Setup Interrupts ------------------------------------------------------
    INCLUDE "DT_INTS-18.bas"     ; Base Interrupt System
    INT_LIST  macro    ; IntSource,          Label,  Type, ResetFlag?
            INT_Handler   USB_Handler
    endasm
    ;--- Setup USB -------------------------------------------------------------
    INCLUDE "DT_HID260.pbp"
    DEFINE USB_VENDORID    6017
    DEFINE USB_PRODUCTID   2000
    DEFINE USB_VERSION     1
    DEFINE USB_VENDORNAME  "Darrel Taylor"
    DEFINE USB_PRODUCTNAME "DT_HID"
    DEFINE USB_SERIAL      "001"
    DEFINE USB_INSIZE      32   ;  IN report is PIC to PC (8,16,32,64)
    DEFINE USB_OUTSIZE     16   ; OUT report is PC to PIC
    DEFINE USB_POLLIN      10   ; Polling times in mS, MIN=1 MAX=10
    DEFINE USB_POLLOUT     10
    ; --- Each USB LED is optional, comment them if not used ----
    ;DEFINE USB_LEDPOLARITY 1       ; LED ON State [0 or 1]  (default = 1)
    ;DEFINE USB_PLUGGEDLED  PORTB,0 ; LED indicates if USB is connected
    ;DEFINE USB_TXLED       PORTC,2 ;  "      "     data being sent to PC
    ;DEFINE USB_RXLED       PORTC,1 ;  "      "     data being received from PC
    OutCount    VAR  WORD : OutCount = 0
    Value       VAR  WORD
    X           VAR  WORD
    ;--- Setup ADC -------------------------------------------------------------
    DEFINE ADC_BITS 10 ; Number of bits in ADCIN result
    '       Configure ADC
    '   See thread http://www.picbasic.co.uk/forum/showthread.php?t=11128&highlight=18f67j50
    '   for more information about setting analog, and the WDTCON.4 on this chip
    WDTCON.4 = 1   ' Switch to Alternate SFR
    ANCON0_ALT = %10011110
               '  -xx------ Not Implemented
               '  1--1111-- AN7, & AN<4:1> = Digital
               '  -------0- AN0 = Analog
    ANCON1_ALT = %11111111
               '  11111111- AN<15:10> = Digital
    WDTCON.4 = 0    ' Back to Default SFR
    ADCON0 = %00000001
           '  0-------- VCFG1, Vref- 0 = AVss (1=AN2)
           '  -0------- VCFG2, Vref+ 0 = AVdd (1=AN3)
           '  --0000--- CHS<3:0>, Channel select -- 0
           '  ------0-- Go/Done, don't care for now
           '  -------1- ADON, Enable ADC
    ADCON1 = %10000111
           '  1-------- ADFM, Right justified result
           '  -0------- ADCAL, Normal A/D converter operation
           '  --000---- ACQT<2:0>, A/D Aquisition time = 0 Tad
           '  -----111- ADCS<2:0>, A/D conversion clock = FRC
    ;--- The Main Loop ---------------------------------------------------------
    TRISD = 0
    PORTD.0 = 1   'turn on g sensor
    PORTD.1 = 0   'select scale for g sensor
    PORTD.2 = 0   'select scale for g sensor
    TRISA = %00000111   'set porta.0, 1, and 2 as inputs
    TRISB = 0
    CM1CON1 = 7   'CM1CON in PBP3 as CM1CON1
    CM2CON1 = 7   'CM2CON in PBP3 as CM2CON1
    TRISC = 0
    TRISE = 0
        FOR X = 0 to 1000           ; Check for incomming USB data while pausing
    @     ON_USBRX_GOSUB  _HandleRX
          PAUSE 1
        NEXT X
        ADCIN 10, Value
        OutCount = OutCount + 1
        ARRAYWRITE USBTXBuffer,["AN0=",DEC Value," -",DEC OutCount,"  "]
        IF Plugged THEN GOSUB DoUSBOut     ; only send when USB is connected
    GOTO Main
    ;---- This just sends the received packet back to the PC -------------------
    HandleRX:
        ARRAYWRITE USBTXBuffer,[STR USBRXBuffer\USBBufferSizeRX]
    Sep 2009
    I try similar thing, but same result.
    So is it possible there are some bug in PBP for this PIC family?
    I'm looking into it too.
    Trying to build a board.
    But first I have to ask ...
    Do you have VDD (3.3V) tied to VUSB?
    There's no internal regulator on those chips.
    Aug 2010
    Maryland, USA
    I can't speak for Pedja's board, But I am pretty sure Walter is using the PIC_LCD3310. If so that DOES show Vusb tied to 3.3V on the schamatic.
    -Bert
    Thanks!
    Yes, I am using Olimex's PIC_LCD3310. Making a board for this family is a little bit of a pain. Darrel, do you want me to send you the Olimex board? I can ship it out tomorrow.
    Walter
    Thanks Walter, that's a nice offer.
    But I ordered one from sparkfun. They're only 50 miles away so I should have it by friday, shipped ground.
    That's sure easier than building one.
    I'm going to try a 26J50 too.
    The 87J50 may still be a question mark.
    Now that's what I call support! Thanks Darrel.
    I can vouch for the PIC18F46J50 working with DT_HID260 and PBP3. I have Micochip's mini demo board http://www.microchip.com/stellent/id...cName=en540669 going. But the 67J50 is elusive for me. Not ruling out my own operator error here, but this operator is running out of ideas ..
    Sep 2009
    Darrel, thank for support.
    I have 3.3V om Vusb... That was first thing to check...
    I can send you PIC. Just give me adress.
    Thanks Pedja,
    We have some of those chips, but no boards to put it on.
    At least none that would be easy to use.
    I think the 67J50 should be good enough since it's in the same family as the 87J50.
    We shall see this weekend.
    Sep 2009
    Dear sir,
    Thank you for support.
    There is something seriously messed up with these chips. And it's all Microchip.
    The SFR's from address F40h to F5Fh cannot be accessed with either the MOVFF opcode or indirectly through the FSR's.
    They can only be accessed by setting BSR to bank15 and using "banked" opcodes like movf, movwf, bcf etc.
    I realize that those SFR's are outside of the ACCESS bank, but that should not affect MOVFF or indirect addressing thru FSR's.
    That range of SFR's contains many of the USB modules registers.
    Other USB module registers such as UCON USTAT etc that reside in the access bank can be written/read with all 3 methods FSR, MOVFF and banked. So it's not related to the USB module itself.
    The USB libraries rely heavily on MOVFF and FSR's.
    I have found nothing in the errata or datasheet that mentions this behavior.
    To illustrate the issue, here is a program for the Olimex PIC_LCD3310.
    It attempts to read several SFR's using all 3 methods and displays the result on the GLCD. With anything in the affected range, only the banked method (GetR on the display) returns a value. Any other SFR's work fine.
    Use Up and Down on the joystick to scroll thru the SFR's.
    '*  Name    : 18F67J50USB.pbp                                              *
    '*  Date    : 8/21/2011                                                    *
    '*  Notes   : The FSR's from F40 to F5F are not accessable using either    *
    '*          : MOVFF or indirectly with FSR's.                              *
        CONFIG XINST = OFF
        CONFIG FOSC = HSPLL
    #endconfig
    DEFINE OSC 48
    clear
    PAUSE 200
    ;--- For the 3310 display---------------------------------------------------
    include "AllDigital.pbp"
    ;DEFINE SHOWDIGITAL 1
    include "modedefs.bas"
    include "LCD_3310v32.inc"
    GOSUB Lcd_Clear
    INCLUDE "ReEnterPBP-18.bas"    ; Allows re-entry to PBP from ASM interrupts
            INT_Handler   TMR1_INT,    _TMR1_ISR,   PBP,  yes
        INT_ENABLE  TMR1_INT     ; Enable Timer 1 Interrupts
    endasm
    DEFINE USB_PLUGGEDLED  PORTE,3 ; LED indicates if USB is connected
    Value       VAR  WORD
    X           VAR  WORD
    TRISD = 0
    T1CON = $31                ; Prescaler = 8, TMR1ON
    LCD_Value VAR BYTE
    UCFG_VAL  CON EXT
    B0        VAR BYTE         ; Button Var
    B1        VAR BYTE         ; Button Var
    GetReg macro Regin, VarOut
        banksel  Regin
        movf     Regin, W
        banksel  VarOut
        movwf    VarOut
        banksel  0
    PAUSE 100
    Left   VAR PORTB.1
    Right  VAR PORTA.4
    Up     VAR PORTB.4
    Down   VAR PORTB.5
    Center VAR PORTB.0
    ShowUCON:
    GOSUB Lcd_Clear
    @ PrintStr  0,0, "  UCON - F65h"
    @ PrintStr  0,2, "FF  = "
    LCD_Value = UCON
    GOSUB LCD_BIN8
    @ PrintStr  0,3, "GetR= "
    @ GetReg  UCON, _LCD_Value
    GOSUB LCD_BIN8
    @ LFSR 0, UCON
    @ movff INDF0, _LCD_Value
    @ PrintStr  0,4, "FSR = "
    GOSUB LCD_BIN8
    UCON_Wait:
    PAUSE 10
    BUTTON Down,0,255,255,B0,0,UCON_Wait
    ShowUSTAT:
    GOSUB Lcd_Clear
    @ PrintStr  0,0, " USTAT - F64h"
    LCD_Value = USTAT
    GOSUB LCD_BIN8
    @ GetReg  USTAT, _LCD_Value
    GOSUB LCD_BIN8
    @ LFSR 0, USTAT
    GOSUB LCD_BIN8
    USTAT_Wait:
    PAUSE 10
    BUTTON Up,0,255,255,B1,1,ShowUCON
    BUTTON Down,0,255,255,B0,0,USTAT_Wait
    ShowUEIR:
    GOSUB Lcd_Clear
    @ PrintStr  0,0, "  UEIR - F63h"
    LCD_Value = UEIR
    GOSUB LCD_BIN8
    @ GetReg  UEIR, _LCD_Value
    GOSUB LCD_BIN8
    @ LFSR 0, UEIR
    GOSUB LCD_BIN8
    UEIR_Wait:
    PAUSE 10
    BUTTON Up,0,255,255,B1,1,ShowUSTAT
    BUTTON Down,0,255,255,B0,0,UEIR_Wait
    ShowUIR:
    GOSUB Lcd_Clear
    @ PrintStr  0,0, "   UIR - F62h"
    LCD_Value = UIR
    GOSUB LCD_BIN8
    @ GetReg  UIR, _LCD_Value
    GOSUB LCD_BIN8
    @ LFSR 0, UIR
    GOSUB LCD_BIN8
    UIR_Wait:
    PAUSE 10
    BUTTON UP,0,255,255,B1,1,ShowUEIR
    BUTTON Down,0,255,255,B0,0,UIR_Wait
    ShowUCFG:
    GOSUB Lcd_Clear
    @ PrintStr  0,0, "  UCFG - F5Fh"
    LCD_Value = UCFG
    GOSUB LCD_BIN8
    @ GetReg  UCFG, _LCD_Value
    GOSUB LCD_BIN8
    @ LFSR 0, UCFG
    GOSUB LCD_BIN8
    UCFG_Wait:
    PAUSE 10
    BUTTON Up,0,255,255,B1,1,ShowUIR
    BUTTON Down,0,255,255,B0,0,UCFG_Wait
    ShowUADDR:
    GOSUB Lcd_Clear
    @ PrintStr  0,0, " UADDR - F5Eh"
    LCD_Value = UADDR
    GOSUB LCD_BIN8
    @ GetReg  UADDR, _LCD_Value
    GOSUB LCD_BIN8
    @ LFSR 0, UADDR
    GOSUB LCD_BIN8
    UADDR_Wait:
    PAUSE 10
    BUTTON Up,0,255,255,B1,1,ShowUCFG
    BUTTON Down,0,255,255,B0,0,UADDR_Wait
    ShowUEIE:
    GOSUB Lcd_Clear
    @ PrintStr  0,0, "  UEIE - F5Dh"
    LCD_Value = UEIE
    GOSUB LCD_BIN8
    @ GetReg  UEIE, _LCD_Value
    GOSUB LCD_BIN8
    @ LFSR 0, UEIE
    GOSUB LCD_BIN8
    UEIE_Wait:
    PAUSE 10
    BUTTON Up,0,255,255,B1,1,ShowUADDR
    BUTTON Down,0,255,255,B0,0,UEIE_Wait
    ShowUIE:
    GOSUB Lcd_Clear
    @ PrintStr  0,0, "   UIE - F5Ch"
    LCD_Value = UIE
    GOSUB LCD_BIN8
    @ GetReg  UIE, _LCD_Value
    GOSUB LCD_BIN8
    @ LFSR 0, UIE
    GOSUB LCD_BIN8
    UIE_Wait:
    PAUSE 10
    BUTTON Up,0,255,255,B1,1,ShowUEIE
    BUTTON Down,0,255,255,B0,0,UIE_Wait
    ShowPIE2:
    GOSUB Lcd_Clear
    @ PrintStr  0,0, "  PIE2 - FA0h"
    LCD_Value = PIE2
    GOSUB LCD_BIN8
    @ GetReg  PIE2, _LCD_Value
    GOSUB LCD_BIN8
    @ LFSR 0, PIE2
    GOSUB LCD_BIN8
    PIE2_Wait:
    PAUSE 10
    BUTTON Up,0,255,255,B1,1,ShowUIE
    BUTTON Down,0,255,255,B0,0,PIE2_Wait
    ShowUEP0:
    GOSUB Lcd_Clear
    @ PrintStr  0,0, "  UEP0 - F4Ch"
    LCD_Value = UEP0
    GOSUB LCD_BIN8
    @ GetReg  UEP0, _LCD_Value
    GOSUB LCD_BIN8
    @ LFSR 0, UEP0
    GOSUB LCD_BIN8
    UEP0_Wait:
    PAUSE 10
    BUTTON Down,0,255,255,B0,0,UEP0_Wait
          PAUSE 1
        NEXT X
        ADCIN 10, Value
    GOTO Main
    HandleRX:
    ;----[Timer1 interrupt blinks an LED]--------------------------------------
    TMR_DIV  VAR BYTE
    TMR1_ISR:
        TMR_DIV = TMR_DIV + 1
        if TMR_DIV = 12 THEN
            TOGGLE PORTE.2
            TMR_DIV = 0
    @ INT_RETURN
    LCD_BIN8:
        Lcd_Data = LCD_Value.7 + $30
        Gosub Lcd_SendChar
        Lcd_Data = LCD_Value.6 + $30
        Gosub Lcd_SendChar
        Lcd_Data = LCD_Value.5 + $30
        Gosub Lcd_SendChar
        Lcd_Data = LCD_Value.4 + $30
        Gosub Lcd_SendChar
        Lcd_Data = LCD_Value.3 + $30
        Gosub Lcd_SendChar
        Lcd_Data = LCD_Value.2 + $30
        Gosub Lcd_SendChar
        Lcd_Data = LCD_Value.1 + $30
        Gosub Lcd_SendChar
        Lcd_Data = LCD_Value.0 + $30
        Gosub Lcd_SendChar
    Walter,
    My PIC_LCD3310 arrived with a solder bridge between pins 13-14 (D+, RF5).
    Sometimes those are intentional, does your have a bridge there too.
    I've attached the .hex file for the above program.
    Weirdness! Will have to check your program out tonight! Thanks Darrel!
    No, mine do not have a solder bridge on any of the PIC pins.
    Here is a USB HID bootloader, just to make sure your USB portion (still)works.
    (Hold joystick in down position at power up to go to bootload mode)
    Aug 2010
    Maryland, USA
    Just went and looked at 1 of mine(I have 2 but must have put the other in a safe place). I see no bridges on the pins anywhere. So Darrel is it safe to assume you will create a workaround for microchips shortcoming? Haha just poking at you. Seems now that you have done the hard part and identified the issue, we need to make an asm routine to talk to those sfr's?
    -Bert
    I found this on page 81: But I guess you found that already.
    Note: Addresses, F40h through F5Fh, are not
    part of the Access Bank, therefore specifying
    a BSR should be used to access these
    registers.
    See, its a feature, not a bug!
    I tried to head off that question in my earlier post.
    I understand that it's outside of the access bank, but that only affects the "banked" opcodes (movf, movwf, bcf, bsf, iorwf etc). Banked opcodes are the only ones that work in that range on the 67J50.
    MOVFF and indirect addressing are not affected by the BSR register.
    They use the full address of the register.
    From the MOVFF Instruction definition ...
    Location of source ‘fs’ can be anywhere
    in the 4096-byte data space (000h to
    FFFh) and location of destination ‘fd’
    can also be anywhere from 000h to
    FFFh.
    I think it is sort of interesting that in both the PIC18F47J53, and the PIC18F46J50 (both known to work with PBP USB) it states:
    Note: The SFRs located between EB0h and
    F5Fh are not part of the Access Bank.
    Either BANKED instructions (using BSR) or
    the MOVFF instruction
    should be used to
    access these locations. When programming
    in MPLAB® C18, the compiler will
    automatically use the appropriate
    addressing mode.
    However, for the PIC18F67J50, they leave the MOVFF part out of this statement. I wonder if Microchip knows its errata and just didn't add it to the errata list. Or it's just a coincidence.
    Hmmmm, very interesting indeed.
    Sep 2009
    I was out of town, now I'm reading posts, and i tested hardware with HID boot loader, and it works.
    When can I expect solution?
    Is this will be corrected in PBP2.60(which I currently use), or I must upgrade to PBP3?
    I really appreciate your efforts.
    Thanks to all
    There's no good reason to not upgrade to PBP3... forum is free... now say to Melabs & Crownhill you appreciate the forum because it saved your butt a couple of times... get the upgrade
    Sep 2009
    Yes, you're right, I'll get update
    Oct 2003
    Australia
    I just saw the PBP 3 update too. Everybody - time to open your wallets. Is it really that more stable than PB2?
    Good boy
    Quote Originally Posted by Squibcakes View Post
    I can't confirm as of yet, but PBP2 always have been bomb proof to me... Sure enough, the little money invested in the upgrade worth it! 50$/Year? Who cares? less than 1$/Week.
    I have not seen a version of PBP that was not stable. So far PBP 3.0 has not given me any trouble.
    UPGRADE UPGRADE UPGRADE
    Maybe the faster folks upgrade the faster they will come out with more bells and whistles.
    I didn't get very far on the Microchip forum. http://www.microchip.com/forums/tm.a...mpage=1#597082 They wanted me to try the simulator, and see if the simulator thought that should work or not. I couldn't get far enough in Mplab to find out. Though I am not sure how useful that would be. Does a simulator always sim what it should?
    MPSIM worked with PBP 2.x, will try with PBP3. It has to.
    And NO a simulator do not always give you the good results, some are worst than others. As a guideline they are usually decent tool or pure toy, not much.
    What did you try in MPSIM?
    I'm finding that it's reversed in MPSIM.
    MOVFF and FSR's work, but banked instructions don't.
    I haven't tried this specific PIC yet. I try to stay away of Sims
    OK, I'm getting closer.
    I think I can make USB work on it.
    What a screwy chip.
    Aug 2011
    This is all very interesting. Care to share what you've been able to find out so far?
    How is this chip different than the others?
