HEX byte to ASCII output...
Results 1 to 6 of 6
    Default HEX byte to ASCII output...
    Hello,
    I am using the Dallas 18S20 to measure temperature. My code is working and I can display the decimal temp on the LCD screen.
    My problem is:
    The 18S20 provides the temp in HEX (example. $31), I convert that to decimal 49. I then divide 49 by 2 and obtain the temprature of 29degs C.
    I need to transmit the "2" and "9" in ASCII. How do I strip the "2" and "9" from the decimal byte 29 in (INTTEMP.LOWBYTE / 2)....?
    INTERNALTEMP:
    OWOut DQI,1,[$CC,$44] 'REQUEST FOR INT TEMP AD CONVERSION
    PAUSE 750 'WAIT FOR CONVERSION TO COMPLETE
    OWOut DQI,1,[$CC,$BE] 'REQUEST XMIT OF TEMP DATA
    OWIn DQI,0,[INTTEMP.LOWBYTE,INTTEMP.HIGHBYTE] 'REC TEMP DATA
    Lcdout $fe, 1, DEC INTTEMP.HIGHBYTE, " ", DEC (INTTEMP.LOWBYTE / 2)
    GOTO INTERNALTEMP
    John
    Default Re: HEX byte to ASCII output...
    Probably a better way...
    To strip out place values
    code snip from project with four digits.
        C_THOS = TempC / 1000
        C_HUNS = (TempC - C_THOS * 1000) /100
        C_TENS = (TempC-((C_THOS * 1000) + (C_HUNS * 100)))/10
        C_ONES = TempC - ((C_THOS * 1000) + (C_HUNS * 100)+ C_TENS * 10)
    Then convert to..
    Again, snipped from a project using an array.
        FAT_src[40] = $30+C_THOS
        FAT_src[41] = $30+C_HUNS
        FAT_src[42] = $30+C_TENS
        FAT_src[43] = $30+C_ONES
    Does that help?
    Does that help?
    Yes it does...thank you!
    John
    Works great now!
    INTERNALTEMP:
    IF INTTEMP.HIGHBYTE = $00 THEN INTTEMPSIGN = 43  'CHECK HIGHBYTE SET SIGN +
    IF INTTEMP.HIGHBYTE = $FF THEN INTTEMPSIGN = 45  'CHECK HIGHBYTE SET SIGN -
    IF INTTEMP.HIGHBYTE = $FF THEN INTTEMP.LOWBYTE = ($FF - INTTEMP.LOWBYTE) 'INVERT LOWBYTE FOR NEG
    INTTEMP.LOWBYTE = INTTEMP.LOWBYTE / 2    'DIV BY 2 FOR DEGREES C
    INTC_TENS = INTTEMP.LOWBYTE / 10 'CALC TENS DIGIT
    INTC_ONES = INTTEMP.LOWBYTE - (INTC_TENS * 10)   'CALC ONES DIGIT
    INTTX(1) = $30 + INTC_TENS                       'CONVERT TO ASCII
    INTTX(2) = $30 + INTC_ONES                       'CONVERT TO ASCII
    GOTO INTERNALTEMP
    Jul 2011
    Hawaii
    John,
    The sensor has .5 degree resolution. You can store INTTEMP.LOWBYTE into a NEW VAR of length WORD then multiply the new variable by 5. In your example 49 X 5 is 245. HEX "31" actually represents +24.5 degrees C. Use "DIG" to isolate the digits of the NEW VAR WORD. WORD size is suitable because the maximum of INTTEMP.LOWBYTE is HEX "AA", 170 X 5 = 850 which represent +85.0 degrees C.
    - Martin
    Hi Martin,
    Thanks for the DIG tip. That eliminates all that math.
    Yes, I know I can get the .5 resolution, but I don't need it for this simple project. But, that doesn't mean I won't incorporate it in my code sometime in the future.
    Thank again....
    John
