DT_Ints w/18F26K22 stop if incorrect baud rate
Results 1 to 22 of 22
    OK
    Default Re: DT_Ints w/18F26K22 stop if incorrect baud rate
    Quote Originally Posted by Mike2545 View Post
    I found that you need to point the Include to the location like,
    INCLUDE "C:\PBP\DT_INTS-18.bas"
    Mike
    And to think I have like over 100 copies of DT_INTS[-18] because I made sure there was one in each folder I saved code in! That was worth the time spent reading this whole thing right there. Thanks Mike.
    If the file is in the PBP folder there's no need to specify the path. If no path is specified the compiler looks for the file in the source file folder, and then in the PBP folder.
    Jul 2009
    Ohio, USA
    Henrik, apparently Pic Basic Pro 3 does not do that you need to specify the folder.
    Mike
    Mine works exactly as I describe, just tested it again....
    Place the file to be included either in source folder or in the root of the PBP3 folder and then doing INCLUDE "ThisOrThat.pbp" works just fine.
    If the file exists in BOTH locations it uses the one in the source file folder so that's where it looks first - as expected.
    ditto
    same for pbpmod files for user_commands
    Jul 2009
    Ohio, USA
    I don't know why mine needs the path specified but it does. The DT_INTS-18 is in the PBP folder but I need to tell it INCLUDE "C:\PBP\DT_INTS-18.bas" for the file to be found.
    Mike
    Just an idea, you don't happen to have multiple installations of PBP do you. If you've upgraded to PBP3 then perhaps the compiler that's actually executing resides in the PBP3 folder while you place the include file in the "old" PBP folder.
    Other than that, could it be a a "virtual folder" issue of some sort.
