Capacitive Touch Button by using ADC channel (the CVD system)
Results 1 to 40 of 43
Threaded View
  1. #32
    Mar 2009
    Default Re: Capacitive Touch Button by using ADC channel (the CVD system)
    Quote Originally Posted by Max Power View Post
    Hank, I'm so glad you chimed in. I've been reading your posts about your relaxation osc. and the 16F690 with great interest, and I watched your youtube video. the 690 seemed like an easy way to get multiple channels. I've done a few single channel, relaxation osc, cap sensors using a comparator and a timer in the 16F628A, but I was always limited to 1 channel. Then, I got the 16 channel mux and SOIC breakout board from sparkfun and I made a 16 key piano - thats probably my most fun project yet. I really should post the code, it could be so much better.
    You were up and running in 20 min?!? jeez, what am I waiting for! did you use PBP? 2.6 or 3? or... (shudder) C code? :-) what did you program it with? pickit2 pickit3? I might pick your brain a little more later.
    The 20 minutes on the 12f1822 was probably becuase I'd had to go through the ordeal of getting the 16f690 to work with capacitive touch (& for all even now I'm just one rung up from n00besque territory, back then I wasn't even that!)....and it's not the most beginner friendly! (perhaps it was a rite of passage, to 'grasp' the cap touch basics?!) Seriously, it's incredibly easy to get 4 channel cap touch working on a 12f1822, 16f1824,1827, 1829 etc, what I strongly recommend though is getting the PIC to send info to you PC so you can see the cap module output into TMR1 count
    To your other questions, I was using picbasic V2.6, pickit2 - I'll try & post something soon(ish) to get you started.
    As it goes i was searching the globe yesterday trying to track down a PIC16LF1829 (XLP variant) - nobody seems to stock them, 'microchip direct' do...but they charge about £15 delivery ($23!) - stuff that!
