Capacitive Touch Button by using ADC channel (the CVD system)
Results 1 to 40 of 43
    Aug 2004
    Default Capacitive Touch Button by using ADC channel (the CVD system)
    I would like to use one touch button (or pad) with pic and I read the pdf file of Microchip AN1298 about that matter.
    The document gives the following instructions to do the job;
    * 1. Set 2nd channel to output, set high (VDD)
    * 2. Select 2nd channel on ADC (charges CHOLD to VDD).
    * 3. Set sensor line to output, set low (GND)
    * 4. Select sensor line as input (TRISx = 1)
    * 5. Select sensor channel on ADC (V-div sensor:CHOLD)
    * 6. Begin ADC conversion
    * 7. Reading is in ADRESH:ADRESL
    I decided to write a program for 12F676 considering these explanations.
    Here is the program . Could you pls someone check the program and let me know if there are some mistakes or missed points. Because the program does not work as I want.
    @ DEVICE pic12F675
    @ DEVICE pic12F675, WDT_ON
    @ DEVICE pic12F675, PWRT_ON
    @ DEVICE pic12F675, PROTECT_OFF
    @ DEVICE pic12F675, MCLR_off
    @ DEVICE pic12F675, INTRC_OSC_NOCLKOUT
    DEFINE OSCCAL_1K 1
    DEFINE ADC_BITS 8
    'DEFINE ADC_CLOCK 1
    DEFINE ADC_SAMPLEUS 10
    CMCON = 7
    RAW VAR byte 56
    OPTION_REG=%01001111
    GPIO=0
    TRISIO=0
    ANSEL = %01011111
    ADCON0=%00001001
    WPU=0
    START:
           ANSEL.2=1         'GPIO.2 Analog selected  This is secondary channel
           GPIO.2=1          'GPIO.2=HIGH this is for charging the C_hold capacitor
           OUTPUT GPIO.2     'GPIP.2 is output now
           ADCON0=%00001001  'AN2 (GPIO.2) selected for ADC purpose
           PAUSEus 10
           TRISIO.4=0        'AN3=is output , this is sensor pin
           GPIO.4=0          'AN3 is LOW yapıldı This for discharging the sensor capacitor
           TRISIO.4=1        'AN3= is input now
           ANSEL.3=1         'AN3 is analog input now
           ADCON0=%00001101  'ADC =AN3 redierected to AN3 and  C_hold voltage is divided (CVD )
           pauseus 10        'wait 10 us
           ADCIN 3,RAW
           ANSEL.2=0         'GPIO.2 is Digital for re-use it on next cycle
           OUTPUT GPIO.4          'Sensor pin is Output now
           GPIO.5=1               'GPIO.5=HIGH , sensor pin is HIGH
           PAUSE RAW              'wait as HAM value (ms)
           GPIO.5=0               'GPIO.5=LOW Output is LOW now.
           pause 10
           GOTO START
    Jul 2011
    Hawaii
    Default Re: Capacitive Touch Button by using ADC channel (the CVD system)
    Ero
    GPIO.2 must remain an input all the time. Tie this input to Vcc. Tell the ADC to select GPIO.2 input pin as an analog input to charge the C_hold cap.
    - Martin
    Aug 2004
    Thank you for the reply. I will do them.
    Ero
    Jun 2008
    Milwaukee, WI
    ero, Martin, or anybody
    I've been trying to do this with a PIC16F819, with only mediocre results. My 819 has a 10 bit A2D, while I see that you are trying it with a 8 bit A2D, so theoretically, your results should be even worse than mine, if that's possible. so, I'm interested in what your typical RAW value is, what it drops to with a finger press, and if it stays relatively constant while your finger is near, because mine does not.
    I started out not tying any of the A2D inputs directly to VCC, and my program began with the A2D pins TRIS being outputs. It worked, sort of, but the A2D value was not constant while my finger was near the pad. Then, I read Martin's suggestion, tied my 'dummy' A2D channel to VCC, modified the code, and ... same thing.
    I've got my PIC16F819 on a olimex 18 pin dev board. I have two copper tape pads, about 1 inch square, covered with electrical tape, on pins 2 and 18.
    my debug statement spits out usually 30 for my untouched S2_AVE (which is not really an average) and when i put my finger on the sensor, it jumps (rings) between 1 and 37. :-(
    I tried putting 10uS delays all over my sense subroutine, tried a longer or no pause before running the A2D, and I tried messing with the A2D clock source, which now doesn't match the define statement.
    oh yeah, I tried to manually control the A2D, but that didn't work. I think I'm pointing to the wrong bits
    If anybody is still with me, here is my down-n-dirty, non-averaging, non-optimized, soon to be pitched, code.
    I'd love to hear any suggestions.
    							'    PIC BASIC PRO 2.6 & MPLAB v8.40 PIC16F819
    @ __CONFIG  _HS_OSC & _MCLR_OFF  &  _LVP_OFF & _WDT_OFF & _PWRTE_OFF  & _BODEN_OFF
    DEFINE DEBUG_REG PORTB        ' asyncronous RS-232 output on PORTB...
    DEFINE DEBUG_BIT 7        ' bit 7
    DEFINE DEBUG_BAUD 19200        ' 19200 Baud,
    DEFINE DEBUG_MODE 0        ' 1 = inverted,  0 = true,like for using max232, or pickit2
    DEFINE DEBUG_PACING 1000    ' 1mS delay
    DEFINE  ADC_BITS        10    ' Set number of bits in result
    DEFINE  ADC_CLOCK       3    ' Set clock source (3=rc)
    DEFINE  ADC_SAMPLEUS    50    ' Set sampling time in uS
    DEFINE OSC 20
    PORTA = 0
    PORTB = 0
    TRISA = %00000100        ' dummy channel = PortA.2 = tied to VCC
    TRISB = %00000100           ' pushbutton input
    PUSHB          var PORTB.2        ' Pushbutton    (OLIMEX 18 pin PIC dev board - active low)
    REDLED        var PORTB.3        ' Indicator LED (OLIMEX 18 pin PIC dev board)
    YELLOWLED     var PORTB.5
    GREENLED     var PORTB.6
    S1_AVE        var word
    S2_AVE        var word
    S1value        var word
    S2value        var word
    counter        var word
    ADGO    VAR ADCON0.0
    ADDONE    VAR ADCON0.2
    DEBUG REP $00\8,13,10,"Starting Up"
    ADCON0 = %10010000            '10 = A2D freq FOSC/64
                        '010 = point to the dummy channel, AN2
                        '0 = status bit
                        '0 = unused
                        '0 = "ADON", 1 = on
    ADCON1 = %11000000              '1 = right justified
                        '1 = A/D clock divide by 2 is used
                        '00 = unused
                        '0000 = all analog inputs
    PAUSE 1000
    counter = 0
    GOSUB SENSE1
    GOSUB SENSE1
    GOSUB SENSE1
    S1_AVE = S1value
    GOSUB SENSE2
    GOSUB SENSE2
    GOSUB SENSE2
    S2_AVE = S2value
    mainloop:
    GOSUB SENSE1
    IF S1value < (S1_AVE-3) THEN
        GREENLED =1
        GREENLED =0
    GOSUB SENSE2
    IF S2value < (S2_AVE-3) THEN
        YELLOWLED =1
        YELLOWLED =0
    IF PUSHB = 0 THEN
        DEBUG DEC S1_AVE, ", ",DEC S1value,", ", DEC S2_AVE, ", ",DEC S2value,13,10
    counter = counter +1
    IF counter > 3000 THEN
        TOGGLE REDLED
        counter = 0
    GOTO mainloop
    ' *   Microchip AN1298: CVD Touch Sensing using two ADC channels
    ' *  1. Set 2nd channel to output, set high (VDD)
    ' *  2. Select 2nd channel on ADC (charges CHOLD to VDD).
    ' *  3. Set sensor line to output, set low (GND)
    ' *  4. Select sensor line as input (TRISx = 1)
    ' *  5. Select sensor channel on ADC (V-div sensor:CHOLD)
    ' *  6. Begin ADC conversion
    ' *  7. Reading is in ADRESH:ADRESL
    SENSE1:
    'setup and read the first sensor (PORTA1, AN1, pin 18)
    'TRISA.2 = 0           'Set Dummy channel to digital output
    'PORTA.2 = 1         ' Dummy channel goes high
    ADCON0 = %10010000    ' set A/D to dummy channel
    PAUSEUS 10        ' let it charge
    PORTA.1 = 0         'Sensor line gets set low
    TRISA.1 = 0        'Sensor line gets set to digital output
    TRISA.1 = 1        'Sensor line gets set to digital/analog input
    ADCON0 = %10001000     'Point A/D to sensor line
    PAUSEUS 10        'wait for voltage to stabilize
    ADCIN 1, S1value    ' Read channel 1 to variable
    'ADGO = 1        'turn on A/D
    'WHILE ADDONE = 1
    'WEND
    'S1value = ADRESL
    TRISA.1 = 0           'return sense line to be digital output
    SENSE2:
    'setup and read the 2nd sensor (PORTA3, AN3, pin 2)
    PORTA.3 = 0         'Sensor line gets set low
    TRISA.3 = 0        'Sensor line gets set to digital output
    TRISA.3 = 1        'Sensor line gets set to digital/analog input
    ADCON0 = %10011000     'Point A/D to sensor line
    ADCIN 3, S2value    ' Read channel 3 to variable
    'WHILE ADDONE = 1
    'WEND
    'S2value = ADRESL
    TRISA.3 = 0           'return sense line to be digital output
    Aug 2004
    Max Power,
    I need to make a correction. 12F675 having 10 bit ADC channels but I was using them as 8 bit. Because in that job I do not need 10 bit conversation.
    I made a system which is working without any problem. But it was not so easy to do that. Because as I told on my first message the system does not work with stability. Let say if you touch the touch point it is not coming the same result all the time. There is like a loop and after that loop you obtain again the same result.
    For instance the ADC value is depend on what you use as touch point (cable , cupper plate etc) The capacity of that equipments are changing the ADC value.
    I was using one short (about 25 cm) thick cable (single line inside). With that cable I was getting $85 value without touching to the cable. If I touch the ADC value was going down as zero ("0") This was the trick for me to catch the touch moment. BUt as I told you it was not stabil. Finally I decided to use also one loop to eliminate the false signals. Finally my siystem is working very well without any problem. I made both TOGGLE system and also NON-TOGGLE system.
    Here is the codes for Toggle system;
    * : TOGGLE *
    @ DEVICE pic12F675
    DEFINE OSCCAL_1K 1
    DEFINE ADC_BITS 8
    'DEFINE ADC_CLOCK 1
    CMCON = 7
    RAW VAR byte 56
    TOP VAR WORD
    SINIR VAR BYTE
    I VAR BYTE
    BUYUK var byte
    KUCUK VAR BYTE
    poz var bit
    GPIO=0
    TRISIO=0
    ANSEL = %01011111
    ADCON0=%00001001
    WPU=0
    GPIO.2=1
    SINIR=132 'This is the sensibility value can reach up to 136 according to my touching cable and it can be changed for the different material.
    BUYUK=0
    KUCUK=255
    START:
    GOSUB TUSBAK
    '------------------------do not use these lines I was used them to see the ADC values-------------------------------
    IF RAW>BUYUK THEN BUYUK=RAW
    IF RAW>0 and RAW<KUCUK THEN KUCUK=RAW
    WRITE $10,BUYUK
    WRITE $11,KUCUK
    IF RAW<SINIR and POZ=0 THEN 'this is the lines to eliminate the false loop
    TOGGLE GPIO.5
    I=0oz=1
    BIR: gosub tusbak
    IF RAW<SINIR then
    I=0
    GOTO BIR
    I=I+1
    IF I<SINIR then BIR
    pause 50
    I=0
    goto start
    pause 10
    poz=0
    GOTO START
    TUSBAK: 'means check if there is a touch
    GPIO.2=0
    ANSEL.2=0
    HIGH GPIO.2
    ADCON0=%00001001 ' The direction of ADC channel is now GPIO.2 and C_hold is charging by the signal coming from AN2.
    ANSEL.0=0 'sensor pin is digital
    TRISIO.0=0 'sensor pin is now output pin
    GPIO.0=0 'sensor pin is LOW and it was discharged
    TRISIO.0=1 'Sensor pin is again input
    ANSEL.0=1 'sensor pin is analog input now
    ADCIN 0,RAW
    BAK:
    TRISIO.0=0
    ANSEL.0=0
    GPIO.0=0
    I hope everything is clear now.
    Ero
    Dec 2010
    I've made a touch controlled dimmer with touch up/touch down controls using this method. There is a lot of variability in the measurement, but empirically I determined a range of values that the result always falls within when touched. I then implemented a "tell me three times" loop to eliminate noise. I'm happy with the result and there are several complete units in use with no complaints.
    I can't post the code because I sold the rights to it, but the only tricks to making it work are in the paragraph before this one.
    Quote Originally Posted by ero View Post
    See Microchip AN1298 - Capacitive Touch using only an ADC
    I have been using this for years without any problems.
    Warning: Other compiler
    Norm
    Thank you Dave and Norm.
    Isn’t that just “fishy”?
    It looks like we got the complementary fish and learn how to fish in one strike.
    Nick
    Mar 2009
    Just in case someone was wanting to deploy a cap touch solution for fish to use - it won't work.....their enviroment is already grounded...which negates the use of cap touch under the water.....probably best going with a sealed hall effect switch, but some intensive training of the fish involved will be needed. (where to actuate, how to actuate etc)
    Miami, Florida USA
    Anonymous
    Oct 2011
    please send me the code for capacitive touch button by using adc channel with pic16f877a controller.
