Using ASM with PBP variables.
Results 1 to 6 of 6
    Default Re: Using ASM with PBP variables.
    The easiest way is to use PBP macro, so you don't need to bother about BANK switching.
    MOVE?WW TMR1L, _YourWordVariable
    MOVE?BB TMR1L, YourWordVariable
    MOVE?BB TMR1H, (YourWordVariable +1)
    you can still use the asm way, but you do not gain any codespace, the MOVE?xx macro are pretty tight.
    The whole set of MOVE?xx macro are listed in the .lib fil in the PBP installation folder.
    for simple maths... hard to tell, what you consider to be simple... division by 7 seems to be easy, but nightmare to code in asm the first time :s
    check out the piclist website. Or come with a specific requirement and some may give this a shot.
    Feb 2005
    Holmfirth England
    Thank's for that. I had no idea about the .lib files. Very interesting stuff.
    Will also check out the piclist website.
    Bob...
    Feb 2005
    Holmfirth England
    Ok, I have been doing a little more delving into asm. So I now have a specific question.
    How do I use a macro?
    I have tried using it in PBP, and inbetween the ASM, ENDASM commands, but I can't seem to get the syntax right.
    Which macro? the one of PBP or your own?
    If PBP one well, no real problem
    ByteA VAR BYTE
    ByteB VAR BYTE
    @ MOVE?CB 123, _ByteA
    @ MOVE?BB _ByteA, _ByteB
    ByteB is now equal to 123
    don't forget, it is CASE SENSITIVE. Try it, and if you still have problem, post your code here, we will have a look to it.
    Also, you can refer to various DT include files, or my KeyPad or my Nokia GLCD. Lot's of macro use in those
    Feb 2005
    Holmfirth England
    Ahh I see what I was doing wrong. I thought the asm part saw all pbp names as _CAPITALS.
    Thanks.
