Newbie help. PIC18F45k20 pickit debug express
Results 1 to 20 of 20
    Aug 2011
    Default Re: Newbie help. PIC18F45k20 pickit debug express
    Is it a demo version of 2.4, 2.5, 2.6, 3.0 or what? As long as it's not 3.0 editing the .inc file like I showed should work. In 3.0 Melabs have provided us with a better way to handle the CONFIG bits but lets not get into that if you're not using 3.0.
    Im using PBP3.0 the latest release.
    I still ween into the INC file for PIC18f45k20 and made the changes like you stated, however it still didn't work. I tryed some other PBP example codes that came with the installation files and those didn't work either so I feel like theres something else in the INC file that needs to be changed because as I said before, all the hex example codes that are for the pic18f45k20 debug kit work fine. Only the PBP example ones don't. I scanned over the datasheet last night to try and see if there was any other config bits that looked like they might need to be changed but alot of them are over my head right now and I don't really understand them. Got any other suggestions?
    I am microcontroller stupid!!
    with PBP3 you no longer need to edit the .INC files. you need to use the new method stated in the migration document.(#CONFIG, #ENDCONFIG)
    http://www.pbp3.com/downloads/Migrat...0to%20PBP3.pdf
    Aug 2011
    What is the configuration block. Is that a insert of the program code?
    For example
    ;***************header
    __config _XT_OSC & _WDT_ON & _LVP_OFF & _CP_OFF
    bla bla bla bla bla
    Goto Main
    Yes, that's how you do it, as long as it's indented. Looks like the forum takes out the formatting.... so you probably had it perfect to begin with...
    But the rest is perfect!
    Except the 45K20 will want it in this format:
            __CONFIG    _CONFIG1H, _FOSC_HS_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
            __CONFIG    _CONFIG2H, _WDTEN_ON_2H & _WDTPS_512_2H
            __CONFIG    _CONFIG3H, _CCP2MX_PORTC_3H & _PBADEN_OFF_3H & _LPT1OSC_OFF_3H & _HFOFST_ON_3H & _MCLRE_ON_3H
            __CONFIG    _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _XINST_OFF_4L
    OR anything else list in the p18F45k20.inc file with the new CONFIG directive
    CONFIG FOSC = INTIO7, FCMEN = OFF, IESO = OFF, PWRT = OFF, BOREN = OFF CONFIG BORV = 18, WDTEN = OFF, WDTPS = 1, MCLRE = ON, HFOFST = ON CONFIG LPT1OSC = OFF, PBADEN = OFF, CCP2MX = PORTC, STVREN = OFF CONFIG LVP = OFF, XINST = OFF, CP0 = OFF, CP1 = OFF, CP2 = OFF CONFIG CP3 = OFF, CPB = OFF, CPD = OFF, WRT0 = OFF, WRT1 = OFF CONFIG WRT2 = OFF, WRT3 = OFF, WRTB = OFF, WRTC = OFF, WRTD = OFF CONFIG EBTR0 = OFF, EBTR1 = OFF, EBTR2 = OFF, EBTR3 = OFF CONFIG EBTRB = OFF
    All config are now also available in
    C:\PBP3\DEVICE_REFERENCE
    for each device, you have a .INFO file
    Slick!
    Well, Section 4.9 of the manual will explain...
    Aug 2011
    Just wanted to think you guys for your help. I never did get it to work, however I think I have decided to not purchase the PBP3. My trial is about to expire anyway.
    The main reason for not purchasing it is due to the price. I also just learned that the PBP3 gold edition is the only one that will support my pic18f45k20 debug kit and I feel like the gold edition is really more then I need. I think the product is outstanding though, but for a hobbiest, its more then I want to spend. I have some other hobbys that I need to use the money for. I have decided to try and find another solution.
    Im sure I can take what Iv learned here and apply it.
    Thanks again
